09-14-2016, 10:58 AM | #1 |
28
Rep 104
Enabling M-Track mode on a Z4MC (Toronto area)
I've tracked my coupe over 6-7 days this summer and found the normal DSC to be fairly aggressive at cutting power on corner exit.
I think my tire choice further exacerbates this, since running 245/40/18 front and 265/35/18 rear puts the relative circumference of the rear tires something like 2% lower than stock. I think this makes DSC thinks there is always an extra 2% of wheel spin and so it intervenes earlier. For those of you that have it (Mirko and a few others from BMW Trillium days), is it worth getting the M-track mode enabled? Does it limit yaw rate/rotation but allow for wheel slip/spin under that limit? More importantly, can I get the coding for it done somewhere in the Toronto/GTA area? |
09-14-2016, 03:14 PM | #2 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
I think, at 6-7 days with the M, it's time to take off the training wheels. Especially if you're confident with your car control skills.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
09-14-2016, 05:05 PM | #3 | |
28
Rep 104
I know from example that I should be able to get there on my current tires, stock suspension and M-track enabled rather than DSC fully off. Most track day instructors / coaches / organizers like to see DSC enabled unless maybe you run slicks. |
09-14-2016, 07:01 PM | #4 | |
1821
Rep 5,337
If I was sitting in your passenger seat? I would tend to agree with the other "coaches" and leave some form of "safety net" on for myself. If you're chasing a lap time? Take the training wheel off. Otherwise you'll never know if it's you doing the driving, or if traction control is doing it for you.
09-14-2016, 09:44 PM | #5 | |
2435
Rep 11,669
What groups do you run with, I don't think I've seen you out there. I'm out there with 6th Gear on Oct 5th and Trillium Oct22-23 Any chance you'll be out for either?
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
Boosted 193.50 |
09-14-2016, 09:55 PM | #6 |
26
Rep 195
09-14-2016, 10:32 PM | #7 | |
28
Rep 104
I was looking at both of 6th Gear and Trillium (and an Apex day on the 6th), am still weighing having to go mid-week vs. chance of near-freezing temps by late October. |
09-14-2016, 10:55 PM | #8 |
891
Rep 2,556
Drives: Z4MC-X3-35i-525i, Corrado G60
M track mode will allow some more sideways action and some more wheel spin. Take several laps with track mode enabled, then when you're comfortable with the track, turn all help off.
09-15-2016, 09:22 AM | #9 | |
2435
Rep 11,669
It would be great to see you out too.
09-15-2016, 06:14 PM | #10 |
182
Rep 1,031
Yes, 100% enable it!! I highly recommend it. You get so much more control over the car on the track.
I found in corner 5 and 10 I was not able to get on the power. With DTC mode I can get on the power and I still get my DSC light flashing here and there (down turn 2 near the second apex) to help when I overdo it. Did you have the black M coupe? I think we met at those events.
08 M Coupe • Ceramic Black Fabspeed Headers • MCS 1WNR • Poly FCAB • Stoptech BBK • Vibra-Tech • Epic Tune • Apex EC7 • RPI Scoop • Eventuri • Stromung • Rogue X Pipe • Varis Diffuser • CF E92 GTS Wing • CF Roof
09-15-2016, 08:01 PM | #11 | |
256
Rep 928
DSC off is the only choice if you truly want your car to do what you want it to do ( with square setup or any other setup that isn't close to stock). It drives pretty good the speedo is quite off (10%). Square setups where all the rage during the days of the E39 and E46 M3/M5. That's because they suffered from a lot of under steer. It now understeers less but it's not perfect.
Gone but not forgotten:
2007 E63 M6 SMG, 1999 996 Carrera Cab AT, 2007 & 2008 E90 335xi AT, 2011 E93 M3 DCT, 2X 2002 E46 M3 SMG & 6MT, 2016 F80 M3 DCT |
09-16-2016, 10:08 AM | #12 |
1821
Rep 5,337
DSC doesn't care whether or not you're squared up. It doesn't work that way.
09-16-2016, 09:26 PM | #13 | |
249
Rep 758
The only thing that matters is the difference in the diameters of the tires. DSC is looking at the outputs from the wheel speed sensors and tire width is immaterial so long as the diameters are close.
Top Down 365
mercedesc63256.00 |
09-17-2016, 12:43 AM | #14 | ||
256
Rep 928
I see his diameters are quite different front 25.7 and rear 25.3 wouldn't be surprised if it drove ok but m track mode would improve it. Ideally you want your diameters as close as stock as possible. I think this is definitely your current issue. Change your tires make sure they are all 4 the same diameter or close.
09-17-2016, 01:34 AM | #15 |
1821
Rep 5,337
Stock diameter is not 27". It's 26.
DSC is "calibrated" to ignore rotational differences of 5% or less. The difference between 25.7" and 25.3" is well within margin. 245/40/18 and 265/35/18 are common tire sizes MANY of us have run with on and off track. "M-track mode" will make zero difference regarding his tire size.
09-17-2016, 11:17 AM | #16 |
28
Rep 104
mercedesc63256.00 |
Tags |
m-track mode, track, z4m coupe |
