10-28-2023, 04:40 AM | #1 |
Rep 8
Correct fuse location for dashcam connection in series 2
Hi.
I have a 2017 218d and am wanting to connect my dashcam hardwire kit correctly for '24-hr parking monitoring' mode use - ie with just a 2-wire ground and yellow (battery) connection therefore according to the kit manual. For ease of installation of the required additional piggy-back connector in the fusebox behind the front passenger glovebox, I'd like to select fuse position number 61. However, although everything seems functional wrt the correct operation of the front display/instrument cluster/radio, I'm only getting 12v from the left-hand side of the fuse location - which should be the same on the RHS (shouldn't it?) as an "always on" connection? Clarification gratefully appreciated. Steve |
10-29-2023, 03:42 AM | #2 |
2473
Rep 4,653
Wrong forum…
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
10-30-2023, 07:24 AM | #4 |
978
Rep 2,069
Because you're asking a question about a 2 series - On the M3/M4 forum...
/// BM3 + M-Power ///
SteveChester2473.00 |
11-16-2023, 03:23 PM | #6 |
2473
Rep 4,653
But you have still created a new post which is the same as your last one??
As above WRONG FORUM……………..
Steve Roberts UK
t5pilot977.50 |
