11-08-2016, 09:41 PM | #1 |
118
Rep 393
front end question
Featured on BIMMERPOST.com |
11-08-2016, 10:46 PM | #2 | |
Curmudgeon and Pedant
692
Rep 3,488
The bottom center is the A/C Condenser. The upper center is the main radiator. The reason for so much cooling is that the Intercooler is water-to-air rather than air-to-air. Last edited by floydarogers; 11-08-2016 at 10:58 PM.. Reason: correct condenser |
11-09-2016, 04:50 AM | #3 | |
118
Rep 393
11-09-2016, 10:03 AM | #4 |
692
Rep 3,488
11-09-2016, 12:39 PM | #5 |
Two many diffs
43
Rep 120
11-09-2016, 02:51 PM | #6 | |
692
Rep 3,488
http://www.realoem.com/bmw/enUS/show...diagId=11_6422 That's one reason (as I already said the charge-air cooling is the main one) that there are so many COOLANT radiators. |
11-09-2016, 04:40 PM | #7 |
692
Rep 3,488
Look again, genius. I posted the link, all you have to do is actually follow the link to discover it's NOT OIL.
11-10-2016, 07:16 PM | #9 |
151
Rep 240
From the looks of things that appears to be a pre-LCI F30 M Sport..
Which means: -Top center (immediately behind the kidney grills) is a Auto Trans Cooler (Air-to-Oil); -Bottom center (immediately behind the lower grill opening) is the Air-to-Air Intercooler; -Behind both of the above is which spans the whole height of the front of the car is an A/C condenser stacked in front of the normal engine radiator; -The passenger side lower "mini" radiator is for Engine oil cooling; and -The drivers side lower "mini" radiator is an auxiliary Radiator for engine coolant. ______________________ disclaimer.. the parts manuals sucks at part labelling http://www.realoem.com/bmw/enUS/show...diagId=17_0674 Last edited by zibbit; 11-10-2016 at 07:41 PM.. |
11-10-2016, 07:48 PM | #10 |
692
Rep 3,488
A rational reply; I was looking at LCI parts. Note that the B58 engine has a heat-exchanger for the oil cooler rather than the older oil cooler.
11-10-2016, 08:05 PM | #11 | |
118
Rep 393
11-11-2016, 02:05 PM | #13 |
1519
Rep 5,102
11-11-2016, 04:02 PM | #14 |
3086
Rep 4,210
11-11-2016, 04:47 PM | #15 |
692
Rep 3,488
Only accidentally, as he appeared to make no effort to follow either link I provided, nor provide any counter argument regarding LCI vs. pre-LCI equipment. Argument from ignorance is a logical fallacy; any conclusion reached by logical fallacy is invalid.
My exasperation at people using logical fallacies has been sorely tested over the last 18 months or so. |
11-11-2016, 05:29 PM | #16 | |
118
Rep 393
11-11-2016, 06:07 PM | #17 | |
794
Rep 1,628
M4 in MG | 6 MT
11-11-2016, 06:50 PM | #18 | |
1519
Rep 5,102
"They all have a transmission fluid heat exchanger. 328i Sport lines have one auxiliary engine coolant radiator in the passenger side front wheel well and M Sport lines have a second auxiliary engine coolant radiator in the driver side front wheel well. All 335i's have an engine oil cooler in the passenger side front wheel well. The 335i M Sport also has an engine oil heat exchanger in addition to the oil cooler in the wheel well and it has an auxiliary engine coolant radiator in the driver side front wheel well. " Last edited by bavarianride; 11-11-2016 at 06:56 PM.. |
11-11-2016, 07:20 PM | #19 | |
118
Rep 393
11-11-2016, 08:13 PM | #20 |
18871
Rep 14,141
Drives: G82 M4C X-Drive
I thought it was only the Track Handling Package... or does that just delete the fogs to allow more airflow to the radiators that are already there?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
11-11-2016, 08:14 PM | #21 | |
1519
Rep 5,102
The trans oil heat exchange looks distinct. The aux radiator and oil cooler look similar(their brackets look alike too), but tracking the coolant hose versus oil line will distinguish the two. |
11-12-2016, 10:23 AM | #22 |
692
Rep 3,488
Yeah, yeah, yeah. It was a stupid post.
Yeah, I woke up this morning thinking: what a stupid reply.
Especially since I, too was "ignorant" in not recognizing that an LCI car might be different than a pre-LCI. Guess what: I apologize for being a bit of a jerk in this thread. |
