04-06-2024, 11:54 PM | #1 |
13
Rep 72
KW HAS Long Term Reliability
Hi all, I'm sitting at stock height w/ the 437Ms and pretty close to pulling the trigger on some KW HAS for the F80 w/ adaptive suspension based on what other's have said on the forums.
1) How's the long-term reliability? The longest I could find someone be able to speak on them was 5k miles, how do they fare after 30-40k miles? Any owners able to chime in here? 2) I understand they will get softer and dampen less as time goes on, but is it as bad as people make it out to be? I'm not too particular about my dampening and spring rates, just want something that gives a good drop aesthetically and slightly better cornering/handling, I won't be tracking the car at all. If I wanted the best possible ride and modularity, I'd just move to V3s, but at 3x the cost, it doesn't seem to appeal to me unless someone can provide some wisdom why it's worth saving up for them. 3) Any REAL horror stories with strut wear or is it mostly just an understanding that you're putting more wear on the suspension system and something to be aware of? Last edited by BigFatRaccoon; 04-06-2024 at 11:54 PM.. Reason: added section |
04-07-2024, 11:28 AM | #2 |
BimmerPost Supporting Vendor
24491
Rep 191,486
KW offers top-quality parts, so reliability will not be an issue.
I have used HAS kits on my cars for years (different brands), and never had any issues.
04-07-2024, 06:19 PM | #3 |
2483
Rep 5,950
Ride quality and longevity are based on how much you lower your car. If it’s close to what BMW recommends (10-15 mm) then you’ll have decent ride quality and longevity. F8x has limited suspension travel at stock height and BMW uses the bump stops to control suspension travel. However, if you’ve lowered the car by the max amount (30-50 mm) then you’ll constantly be riding on the stiffer (more compressed) portion of the bump stops. This will worsen ride quality and likely reduce the longevity of the dampers. The HAS kits work well if the car isn’t lowered too much and they also allow you to corner balance the car which is a huge advantage over lowering springs.
04-10-2024, 09:03 PM | #4 |
629
Rep 896
Drives: OG M2
I've had mine on my F87 non-EDC struts for 25k miles/2.5 years with no issues at all. I really haven't noticed any degredation in ride quality at all tbh. To be fair tho, I didn't lower it all the way; I've had them set 4 threads from the bottom of the collar on all 4 corners. I've def got my money's worth out of the KW HAS. Although, given how many good things I hear about the MSS HAS, I'd probably go for that instead of the KWs if I had to do it again.
OG M2 with the OEM M mirror retrofit
04-18-2024, 11:54 AM | #5 | |
13
Rep 72
04-19-2024, 08:12 PM | #6 |
629
Rep 896
Drives: OG M2
I literally have never heard any bad things about MSS. Look at some of Evolve’s videos on their products - they seem really advanced for what they are. If I was starting from stock and wanted to keep OEM struts, I’d go for the MSS. Now that my cars getting older though, I want actual coils
