08-15-2023, 09:25 AM | #1 |
362
Rep 552
Mission Performance - M-Link Install and Review
I have recently received and utilize the M-link from Mission performance to unlock my 2020 M340i :-)
I will be breaking it down here on this page and updating as the process goes. —————————————————————————————————————— Right from the start it arrived quick from USPS and I was able to power it up with a USB-c and update the M-link from their platforms page. After messing with the unit and getting comfortable I took the post warranty plunge and went for the unlock. (Still waiting on what tuning platform I want to use ) After following the prerequisites on their page (Disconnecting all battery's and letting it sit open for 10 minutes) I started unlocking the harness. Easy step just take a picture to know where the OEM plugs go back Advice - Make sure your plugs are fully seated and give them a light pull to make sure that they are connect. Plugging into port 1 and port 5 was easy. If you wonder which plug goes into port 1 it has all the pin connectors on it (use your eyes and see which has the most pin holes) after plugging in, power on the device and let it do a full cloud backup of the DME. follow that up with downloading the DME data for safe keeping. Final step is hitting unlock and you are all set. Overall the process is extra simple. I would give it a 4.8 out of 5 - the plugs should have more color coding to know which goes in what socket for ease of use. They should have a confirmed unlock feature also to confirm you didn't mess it up. I will report back post tune in the next couple days ----------------------------------------------------------------------------- UPDATE (Flash Tuning) - I decided to start with a stage 1 tune with Bootmod3. The BM3 flasher said I was still locked but it aloud me to flash no problems Easy flashing process thanks to the M-Link unlock. No issues at all and the car runs great -Tom J
2020 - M340i RWD | Executive
(Retired 2015 - 335i RWD A8 | MP LSD, BM3, MP Exhaust, M Sport Conversion, 245/35/18 square, VRSF Chargepipe, Rear Brembo upgrade) (Retired - 2010 328i) (Retired - 1987 325i Vert) Last edited by TheJungatron; 08-24-2023 at 06:19 PM.. Reason: Update for tuning |
12
dancing__narwhal141.50 RTPenland428.00 imported_nick83.00 MissionPerformance1506.00 m340ninja288.00 AddictedTo///M220.00 weinerbarn735.50 kai201.50 Burr0013371.00 JP.BSB9.00 pdxdbo331.00 Chubbiejones892.50 |
08-15-2023, 10:50 AM | #2 |
Joint Chiefs of Staff
24454
Rep 191,382
TheJungatron362.00 |
08-15-2023, 12:11 PM | #3 |
1506
Rep 676
Drives: '17 F31 340xi US Spec
TheJungatron Thanks for your review, that is very much appreciated! Funny that you mentioned the confirmation message after unlock: That is something a few others suggested and is currently being worked on. Should be added to the withe 2.1.4 or 2.1.6 update and will make a post-unlock messaging be much more prominent and assertive.
Regarding the plugs: We are looking for a better way to mark them, however we are using the OEM connectors which limits the color choices to black. The red harness ziptie was added to make it a bit more distinguishable, though still a bit hard to see. That is something being looked into but no promisses. However, each plug and connector are unique to each other, which means it is not possbile (aside from hammering them in) to place a wrong plug on the DME terminal. |
08-15-2023, 12:48 PM | #4 |
83
Rep 160
+1 to this. Just did mine. Super happy; what an amazing tool!!!
MissionPerformance1506.00 RTPenland428.00 |
08-15-2023, 12:49 PM | #5 |
83
Rep 160
Now the question is... which flash tune will you get?
08-15-2023, 01:58 PM | #6 | |
362
Rep 552
Thanks for a fun product Tom J
(Retired 2015 - 335i RWD A8 | MP LSD, BM3, MP Exhaust, M Sport Conversion, 245/35/18 square, VRSF Chargepipe, Rear Brembo upgrade) (Retired - 2010 328i) (Retired - 1987 325i Vert) |
Chubbiejones892.50 RTPenland428.00 |
08-15-2023, 02:00 PM | #7 |
362
Rep 552
Just ordered a tune from Mike at x-ph.com
Great quick turn around service from them as a long time customer from my F30 days Should prove to be fun!
08-15-2023, 02:00 PM | #8 |
1506
Rep 676
RTPenland428.00 TheJungatron362.00 |
08-15-2023, 02:06 PM | #9 |
24454
Rep 191,382
08-15-2023, 03:24 PM | #10 |
14
Rep 16
How do I find my Build Date?
I have a 2020 M340i xDrive, but I am not sure how I determine what my actual build date is. Is it the "In Service Date," or something else.
The reason I ask is I'm trying to determine whether my car was built before the June 2019 cut-off for unlockable DMEs (to see if my car is currently supported for the MP M-Link). Any insights are much appreciated. |
08-15-2023, 04:39 PM | #11 | |
1506
Rep 676
The M-Link supports DMEs upto June 2020, so your vehicle is suported. Pretty much as long as your registration doesnt say 2021 on the vehicle, you are good. |
RTPenland428.00 |
08-15-2023, 04:49 PM | #12 |
Unapologetic Tool Hoarder
736
Rep 966
Colorful shrink tubing would work, be durable and not look cheap. You could use yellow and lime green. I don't think these connections have a color on the factory DME connections, otherwise I'd suggest to just match those.
08-15-2023, 06:31 PM | #13 |
893
Rep 1,515
Not to hijack the thread but were you able to get all settled in after your transition to Texas??
08-16-2023, 08:07 AM | #14 |
1506
Rep 676
Got a little delayed due to the M-Link development, however we are all here now but keeping Cali location still open for now most likely. What a crazy year for sure!
08-16-2023, 08:16 AM | #15 | |
362
Rep 552
BootMod3 Stage1 Flashed without a problem :-) M-Link was great!
08-16-2023, 08:21 AM | #16 | |
1506
Rep 676
And Im glad the M-link worked well for you |
TheJungatron362.00 MAKH 588.50 |
08-16-2023, 03:17 PM | #17 | |
14
Rep 16
Many thanks, Sherman |
08-16-2023, 03:21 PM | #18 |
1506
Rep 676
That all good, things happen! And thank you for the order. Next batch is already in production and will be shipping this week for sure.
08-16-2023, 11:25 PM | #19 |
Rep 2
MissionPerformance Pardon my noobness, but I’m struggling to determine whether or not this will work for my car. 2020 M340i and the date on the door says 07/20. With supported DME’s being ‘All Pre-June 2020 MG1’, does that mean I’m hosed? Or can my DME have a different date than what the inside of my door is telling me?
This just had me confused - “Pretty much as long as your registration doesnt say 2021 on the vehicle, you are good” Thanks in advance! Last edited by EM340EYE; 08-17-2023 at 12:22 AM.. |
08-17-2023, 07:16 AM | #21 |
736
Rep 966
08-17-2023, 08:12 AM | #22 | ||
1506
Rep 676
