08-23-2021, 09:35 AM | #1 |
299
Rep 542
EDC delete: can I just replace with a 100w 2.5ohm?
One of my EDC delete modules appears to have died. Instead of spending ~$100 on a replacement from KW, is there any reason I can't just get a 100w 2.5ohm* resistor at $8 for 2 off Amazon and use that? I'm not sure if I'm missing something.
*Per KW, the spec on these is 2.56ohm +/- 0.5.
Sakhir Orange F10 M5 | KW V3s | Dinan Swaybars | Turner Monoballs | Soul Exhaust | Mishimoto Oil Cooler
08-28-2021, 09:10 PM | #2 |
299
Rep 542
well I've replaced the dead one with said 100w 2.5ohm. light is off but it does get quite hot. not sure how hot the other one got as I never touched it, though.
TinCanSailor633.00 |
03-15-2024, 09:16 PM | #3 |
Resident Pedant
503
Rep 792
did it ever burn to the ground? i'm about to build my own.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ |
03-24-2024, 08:21 AM | #4 |
299
Rep 542
It worked, but eventually died. If I did it again I'd have attached it to the car with double-sided heat transfer tape in an attempt to keep it cooler. Possibly could try two 100w 5ohms in parallel, but I'm not an electrical engineer.
Something else I've wondered is whether having the suspension set to comfort, sport, or sport+ makes a difference in longevity. Edit: instead of parallel 100w I'd just try this 200w: Last edited by vafan13; 03-24-2024 at 09:53 AM.. |
