04-15-2019, 05:18 PM | #1 |
43
Rep 236
BimmerCode cheat sheet
Anyone know how I can obtain the cheat sheet for expert mode? Never used expert mode before is this straightforward to use or is there a big chance of bricking the car?
Thanks |
04-20-2019, 02:52 AM | #4 | |
96
Rep 165
R. |
Paul SR42.50 |
04-28-2019, 04:53 AM | #5 | |
Rep 11
This may help |
04-29-2019, 10:38 AM | #6 |
43
Rep 236
Wanted to see if I could code in the changes rather than using a coder. I will have a look at the above but looking at expert mode on BimmerCode appears to be really difficult and no idea what it all means lol.
04-30-2019, 06:31 AM | #7 |
Rep 11
It may look complicated, but it is very straight forward. Bear in mind that every time you use Bimmercode, it makes a backup so if you are not happy you can always restore the backup. I coded video in motion a few months ago and decided last week to reverse it by restoring from backup. So it's great in that respect, as you can access all the backups going back many months
Paul SR42.50 |
05-06-2019, 04:22 AM | #10 | |
Rep 11
05-06-2019, 04:48 AM | #12 | ||
13398
Rep 7,484
05-09-2019, 01:48 PM | #14 |
Rep 11
05-09-2019, 02:21 PM | #15 |
979
Rep 2,071
No mate. It's engine ECU.
/// BM3 + M-Power ///
05-10-2019, 10:09 AM | #16 |
43
Rep 236
05-10-2019, 10:17 AM | #17 |
979
Rep 2,071
Easier way is to code it out with Bimmercode. I did this initially. When I fitted my additional amplifier I then unplugged the ASD module. It's a pain to get to just to unplug it if you're not doing anything else...
Paul SR42.50 |
05-10-2019, 10:22 AM | #18 |
43
Rep 236
You are probably right although I was sure someone had an issue with the coding out. Need to put the BMC filters in shortly.
05-10-2019, 10:35 AM | #19 |
979
Rep 2,071
Thing is, with Bimmercode, it's so easy. You'll know straight away if it's worked, as once it's disabled, you'll be surprised just how much artificial sound was being pushed through your speakers.
I don't suppose you can beat actually unplugging the module though for true certainty it's disabled. Just be careful unplugging it if you don't have HK audio, as I think it causes issues with other sounds. ie. radio & chimes...
05-10-2019, 10:39 AM | #20 | |
43
Rep 236
AIRHEIR443.50 |
05-10-2019, 12:01 PM | #21 |
979
Rep 2,071
Lol, honestly, no need to practice, it's a doddle
08-10-2019, 03:35 AM | #22 | |
Rep 6
