10-07-2014, 10:52 AM | #67 | |
12
Rep 144
Drives: 2015 SS M5
Thanks.
2015 M5 Silverstone, black full leather, 20s.
2008 M3 Sparkling Graphite, black extended (gone) Everything else but the 19s and HD radio. 2003 M3 Titanium Silver (gone) |
10-07-2014, 02:04 PM | #68 |
117
Rep 1,625
Here's a pic from anothers post, but you can see it in the corner. Its next to screw 5.
Removed that single Torx screw, being careful not to drop it into the pit of despair. Loosen the jubilee clip post MAF and remove the snake hose with convolutions. Pop the single top clip/hook of the ducting air coming from the grill and lift straight up.
2014 Individual /// M5 Competition AW/AB || Vorsteiner FF-103 || BMS JB4 || Meisterschaft GTC || RPI || IND || Challenge || |
10-07-2014, 06:52 PM | #69 |
12
Rep 144
Drives: 2015 SS M5
Thanks. I see what you mean. I have to bring the car for break in service soon and will see if they can remove them at the dealer. If not I will take care of it. If I get into trouble I can be in Buckhead in 10 minutes so maybe we can meet up.
E
12-14-2014, 10:27 PM | #70 |
98
Rep 550
I re-read this thread today after a couple months and still not sure I understand the reason/benefit of the charcoal filter deletion. Can someone shed some light? If it is helping in some way, I'd also be interested in removing it right away.
2014 AW F10 M5, mostly stock
12-19-2014, 04:22 PM | #71 | |
85
Rep 1,489
Current: '16 GT4
Past ///Ms: '13 F10 M5, Alpine Weiss III/Sakhir Orange Full '10 E60 M5, Space Gray/Black |
12-27-2014, 01:52 PM | #72 | ||
98
Rep 550
02-03-2015, 12:58 PM | #73 |
Command Sergeant Major of the Army
142
Rep 639
I had a dropsie...anyone know the p/n of a new airbox screw or have an extra they good help a guy out with?
If not, I'll call my SA and see if he can scrounge one up for me. Driver side...seems the ONLY one that didn't have the stop to keep it retained. Did not hit the ground but fell down and I'm hoping it'll fall out on my first drive. Grrrr.. Plus side is I got the charcoal filters out by removing that single Torx bolt and pulling the whole airbox out. Edit: Found a new screw at GetBMWParts.com p/n:13717545438
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone) 2013 F10 M5 (gone) 2008 E90 M3 (gone) Last edited by Lerxst M4; 02-03-2015 at 03:21 PM.. Reason: Update to post. |
03-29-2015, 11:31 AM | #74 | |
167
Rep 501
Brad
2016 McLaren MSO 570S | 2018 Ford Raptor | @alpha7even
06-11-2015, 03:45 PM | #75 |
The Illustrious
24
Rep 104
I read somewhere that the M6 has a plate, the M5 has a snorkle... not sure why they have different airbox internal pieces blocking that but thats been the trend.
05-23-2016, 05:19 PM | #76 |
390
Rep 1,152
Do you just pull the rubbers pieces off or do you need to unscrew it?
01-20-2019, 06:32 PM | #77 |
20
Rep 21
Removal of Air Filter Box.
DESIGNED TO BE REMOVED AS PER BELOW!
REMOVAL 1) disconnect air-intake connector just passed the air box. 2) SINGLE Hex on the outside of the box (BIG) remove, careful DO NOT DROP. 3) Remove stowed hoses from the clips 4) Look in the front there is a LEVER press away from the box and lift up gently. 5) Now you don't have to kill yourself disassembling the box. Reinstall: The box should separate from the front right at the BOX. (You tube video shows the incorrect additional intake that should remain in the car, disconnect and attach back before placing box back) They slide in from the top. Reverse above order to reinstall. PS I just removed my charcoal secondary air filters. i) turbo suction noise more prominent ii) revup feels swifter iii) I do NOT see any power gains. (Gauges in Car). iv) Have Akrapovich Titanium Ex. It sounds a touch brighter, NOT Louder. Some people same EMISSION Part for USA.....I wonder?!?!?! $360 for one so DO NOT TROW AWAY if taking it out! Last edited by ToteHosen; 01-20-2019 at 06:58 PM.. |
01-21-2019, 03:37 AM | #78 |
811
Rep 1,847
The gauges in the car are set by the ECU dependent on accelerator position, load etc etc and wont be effected by this.
I believe that even if you have a remap the gauges wont change as they are not based on real world readings only pre-set input data |
01-23-2019, 04:18 PM | #79 |
20
Rep 21
That is very helpful information. I have been driving with them out for two days......
I feel like there maybe a little bit more turbo-lag, but once active the turbos feel quicker to rev up. |
01-23-2019, 05:12 PM | #80 |
559
Rep 1,071
Drives: i5 M60, M5's, 535.335, M550i
I did mine and changed filter and sure turbo louder but didn't notice any extra power, lag or butt dyno results, but at our power level 5-10hp would be hard to tell
2013 535i M, Carbon black 20' 6 M wheels, totaled.
2018 750M , 2013 M5 , Individual Silver, Bolt ons-Straight piped 2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete 2024 i5 M60 Cape York Green |
rockyfeller117.50 |
02-03-2020, 10:02 AM | #82 |
85
Rep 170
I have a Canadian car and it sounds like this was only needed for US cars, do you guys think there is any advantage for me to do this just to change to either the BMC or the K&N drop in filter? Eventually, I do plan on going Dinan or may be RK for intake but maybe I could free up some flow changing my filter for now?
02-11-2021, 10:30 PM | #84 |
Rep 2
I found it quicker to use a flexible extension to get to the hard to reach bolt than to pull the entire air box.
NEIKO 00239A Flexible Extension Bar Set | 2 Piece | 1/4" x 6" & 3/8" x 8” https://smile.amazon.com/dp/B001223O...ing=UTF8&psc=1 This set is for light duty and perfect for this application. Last edited by ps4570; 02-11-2021 at 10:43 PM.. |
