M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      09-14-2021, 12:26 AM   #1
ara544@aol.com
Drives: bmw m4 & bmw m5
Exclamation boost solenoid
I was recently driving on the freeway and got the drive train malfunction message. i got home and plugged in and the code says i need to change the boost solenoids. Can anyone shed some light on where the boost solenoid is on the 2013 M5?
      09-14-2021, 01:37 AM   #2
arucano
arucano's Avatar
252
Drives: 2014 M6 Grand Coupe CP
2014 BMW M6 GC  [10.00]
Functional description
The blow-off valve prevents ”pumping” against the closed throttle valve, thus improving engine acoustics. In addition, the blow-off valve protects the exhaust turbocharger against damage. Another effect: the exhaust turbocharger reacts quickly when the throttle valve is opened again. Without the blow-off valve, the exhaust turbocharger would work against the ram pressure of the closed throttle valve and become slower. On opening the throttle valve, the exhaust turbocharger would react with a delay.
The engine control activates the blow-off valve. The blow-off valve has the positions: open and closed (no intermediate positions).
See the attached word document.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
M5Rick60267.00
      09-15-2021, 01:53 PM   #3
m5rosco
211
Drives: 2016 F10 M5
Behind/under the chargecooler on right hand side of car.
      11-13-2022, 01:21 AM   #4
turboslut
27
Drives: '14 M5, '18 GT3, '08 911 Turbo
Does the charge cooler need to be removed to change them out?
      12-06-2022, 12:48 PM   #5
crosbycail
crosbycail's Avatar
Drives: 2013 BMW M5, 2010 Audi A4
Here’s a diagram for the vacuum lines including the 2 boost solenoid. Easiest way is to probably just follow the lines from the turbo waste gates to the solenoids to locate them.
https://www.realoem.com/bmw/enUS/sho...diagId=11_5038
m5post
