05-07-2014, 06:22 AM | #90 |
84
Rep 307
Hi guys
Can someone please tell me in simple terms what the below means... Other than my car is knackered! 2739 - Secondary air Mini-HFM electr Diagnostic 27C5 - Secondary air mini-HFM Plausibility Thansk for your help. M |
05-07-2014, 10:29 PM | #91 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
427
Rep 1,947
27bb - P0174, P0175, P2179, P2180
27BB - P0174
27BB - P0174
27BB - P0175
27BB - P0175
27BB - P2179
27BB - P2179
27BB - P2180
27BB - P2180
05-07-2014, 10:37 PM | #92 | ||||||||||||||||||||||||||||||
427
Rep 1,947
27c5 - P2430
27C5 - P2430
05-07-2014, 10:42 PM | #94 | |
427
Rep 1,947
27C5 - P2430, Post-92 Two different codes, but kind of look like the same thing. They share the same "P" code. |
05-08-2014, 01:05 AM | #95 |
894
Rep 9,034
Great thread. THanks.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
06-16-2014, 09:26 PM | #98 | ||||||||||||||||||||||||||||
427
Rep 1,947
27c9 - P0160
27C9 - P0160
06-21-2014, 09:19 PM | #99 |
Mr. Nice Says Hello
637
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
Some help on this: 2712 and what does the CDB6 mean exactly?
06-26-2014, 10:49 PM | #100 |
Rep 8
271C - P000C
Information saved in DME Fault code 271C - P000C Fault text VANOS control, intake bank 2 Fault description 'A' Camshaft Position Slow Response (Bank 2) Condition for fault identification Test condition: Oscillating controller > 3.0 °Crankshaft Terminal condition: Terminal 15 Voltage condition: Battery voltage > 9V (k_ed_ubmin) Condition for fault memory entry 1 Action in service Clear fault memory, VANOS system test Check valves, check adjuster Fault effect and breakdown warning MIL on after engine runs 2x Driver information Warning light: MIL |
09-29-2014, 11:15 AM | #102 |
Rep 8
Are you sure it is 279F?
09-30-2014, 03:23 AM | #103 |
35
Rep 100
09-30-2014, 04:09 PM | #104 |
Rep 8
That is weird, since my BMW software is updated until 05/14... What's the production year of your car? Let me know and I will check some sources I have. Also, it is an E92 right?
10-01-2014, 05:41 AM | #105 |
35
Rep 100
10-01-2014, 07:17 PM | #106 |
Rep 8
Ok, I found it.
There are two descriptions for this code. 1. 00279F DME: Activation , Fan A a. It can be the electric cooling fan that is not operating properly. How I would diagnose it? A primitive way to test it - if you do not have the BMW scanner or any other scanner that can activate the cooling fan and hear it functioning - would be turning the AC on and check if the fan kicks in. After some time, parked and engine running warm, you should hear the fan increasing the speed. The E92 M3’s fan is very loud when it is activated at maximum speed (hot weather and AC on). 2. 00279F : Map Thermostat Mechanism a. The thermostat opens when the engine is too hot and allows the cooler fluid to refrigerate the engine. The car PCM (powertrain control module) monitors how efficient the coolant system is working. One plausible situation is, for example, when the engine is hot, the computer activates the electric fan and the engine does not cool down, the computer might interpret it as the thermostat is not operating properly. Also, the PCM (powertrain control module) might assume the fan is not operating as it should. b. How to test it? Monitor the engine coolant temperature. It is difficult to do it on M3 because the instrument cluster does not have a gauge for engine coolant temperature, only engine oil temperature. But, If you have any scanner, you might be able to check the coolant temperature. It should be around 200 to 210 Fahrenheit within several minutes. Worth to mention: Thermostat issues were very common on old e46s and BMW used the same terminology to indicate coolant issues. I had cases where replacing the thermostat would cure the problem. I hope I was able to help! Regards, Last edited by HenryTav; 10-07-2014 at 09:01 AM.. |
10-12-2014, 07:57 PM | #107 |
Rep 57
Drives: 2009 Alpine White E92
Wow, this thread will be awesome after it's finished being compiled... Great job..
10-13-2014, 10:35 PM | #108 |
Rep 73
were do i get the first series of numbers prior to the error code? for ex 27bo . .etc
is there any way to look up any kind of fault that could arise or is related to codes p0301 and p0491 |
10-17-2014, 05:57 PM | #109 |
Rep 8
Honestly, I didn't get your question "first numbers prior the error code?". Can you be more specific?
Now, P0301 is a generic code for cylinder number 1 misfire and P0491 is Secondary Air Injection System Insufficient Flow (Bank 1). More information is needed to give you "a direction" to go with this. |
10-17-2014, 05:58 PM | #110 |
Rep 8
