06-02-2021, 07:37 PM | #89 | |
1520
Rep 1,494
0W40 has probably (MSDS stats 25-50%) PAO base stock. 5W40 is strictly hydrocracked Group III (mineral oil synthesized using hydrocracking method). 0W40 is probably around 50% PAO as pour point is -60. PAO has excellent cold temperature kinematic viscosity. More PAO=lower pour point. If you are out of warranty, go 0W40. |
smknjoe234.00 atruong24732.00 |
06-03-2021, 03:06 PM | #90 |
32
Rep 73
Appreciate the info ya'll. I used Castrol 0w-40 for my first oil change moving away from 0w-30. I just found out my auto shop carries Motul xmax 0w-40, so will be using that moving forward.
06-03-2021, 03:15 PM | #91 |
7355
Rep 7,527
Try to see if anyone locally has xcess gen 2 5w40, it's alot better than xmax.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
atruong24732.00 |
06-03-2021, 03:51 PM | #92 |
32
Rep 73
06-03-2021, 04:21 PM | #93 | |
7355
Rep 7,527
I was never a fan of xmax I thought it was just meh, but this new xcess gen 2 is really catching my attention. If I didn't buy so much PPE I woulda switched over this year.
atruong24732.00 |
06-03-2021, 04:46 PM | #94 | |
32
Rep 73
I just like the idea of finding an oil that is readily available and priced well at a store like wal-mart. However, I guess with a car like this, shouldn't really be treating it as so. Although, are there any drastic differences of using Motul versus Castrol if the car is completely stock? |
06-03-2021, 05:06 PM | #95 | |
7355
Rep 7,527
Nope there shouldn't be any major differences between the two oils, they're both so dang good and pass extremely stringent tests that the differences between them are really just nit picky details for oil enthusiasts. You're fine with both.
atruong24732.00 |
06-03-2021, 07:43 PM | #96 | |
32
Rep 73
I appreciate the information. |
06-03-2021, 07:45 PM | #97 | |
1520
Rep 1,494
Gen2 has very robust HYHS of 3.8. But, while it looks really good on paper I would give Castrol 0W30/40 slight advantage as base stock has a lot of PAO unlike Motul Gen2. As F87 said, don't get into boutique oil trap. Your local Wal Mart has superb oils for M2. You can also get Quaker State Euro 5W40 (rebadged Pennzoil Platinum Euro) in Wal Mart for $18 for 5qt. Don't forget, Wal Mart doesn't make money on all products. They also use a lot of products to get people in and then spend money on other stuff. |
atruong24732.00 F87source7355.00 |
06-03-2021, 07:46 PM | #98 | ||
1520
Rep 1,494
atruong24732.00 |
06-03-2021, 09:39 PM | #99 | |
7355
Rep 7,527
Don't listen to those guys on facebook bragging about how they use their $120/oil change botique oils with dyes in them to make florescent glows that helps detect oil leaks.... That is a bunch of BS gimmicks to drive up prices. You also don't need to use a bunch of oil additives either, just frequent oil changes are good.
atruong24732.00 |
06-04-2021, 03:51 PM | #100 |
2865
Rep 3,844
I just checked the specs of Quaker State Euro. I looked up the specs from the Quaker State website and a link from Shell (Pennzoil) popped up.
https://shell-livedocs.com/data/publ...d17f3428b0.pdf However I was able to find the a better deal on the Pennzoil version. |
06-04-2021, 03:57 PM | #101 | |
7355
Rep 7,527
For me I have access to both so I just get what's on sale, and it tends to be pennzoil (which seems to have higher inventory too).
06-04-2021, 07:43 PM | #102 | |
1520
Rep 1,494
Their BMW TPT 5W30 oil was truly remarkable. To bad BMW gave deal to Castrol. |
F87source7355.00 |
06-04-2021, 09:44 PM | #103 | |
6643
Rep 4,145
Drives: '18 M2 6MT
But for my M2 daily driver that I only drive 5K a year, I can't imagine I will need to do this yearly with these new oils, right? Once every 1.5 years? 10K miles? |
06-04-2021, 10:31 PM | #104 | |
7355
Rep 7,527
edycol can comment with more detail on OCI, but I think once every 3 years is too long for an oil change. I don't know if the black stone test does a good enough job determining oxidative degradation of oil, and water ingress causing issues but again edy can comment.
VisualEcho6642.50 |
06-04-2021, 11:50 PM | #105 | ||
1520
Rep 1,494
Also, under no circumstances add any additives. Everything you need oil has. When one adds additives, chemical balance of oil is messed up. |
F87source7355.00 VisualEcho6642.50 |
06-05-2021, 11:57 AM | #106 | |
6643
Rep 4,145
Drives: '18 M2 6MT
I'm in Missouri where our temps get as high as 105° F (40° C) in the Summer, and as low as 5° (-15° C) (with much lower wind chills) in the Winter. Do you still recommend 5W40 for me? I drive the Exige less than 500 miles a year. It sleeps in my climate-controlled basement. It has a Toyota 2ZZ 1.8L, 8500 rpm redline. Mild to spirited driving. Should I still change the oil once a year? I currently use Castrol Edge Syntec (fully synthetic) 5W30. In your opinion, is that the best oil for my application? |
06-05-2021, 01:37 PM | #107 | |
7355
Rep 7,527
So you have a few choices of oil: Castrol 0w30/0w40 (no LL01 but edy discussed it would still be permissible to use), Pennzoil platinum euro 5w40/quaker state euro 5w40 (same oil and really cheap and really good at $19/5L in Walmart USA), or motul xcess gen 2 5w40. 2) for the lotus if you can use a 40 weight use the same oils as the m2, the m2 recommended oils are dang good. If you can only use a 30 weight use Castrol edge 0w30 which is really really good with a heavy Pao base stock, and if you only want to stock one type of oil use it on the m2 as well. Castrol edge 5w40 and 5w30 are inferior to their 0w counterparts because of the base stock.
VisualEcho6642.50 |
06-05-2021, 03:23 PM | #108 | ||
1520
Rep 1,494
-15? I started vehicles using 10W40 at -42c. Any 5W oil will do good in lower 48. In MO, absolutely not to worry. But, people using Castrol 0W30/40 are using it for other reasons, mainly very good shear stability, low KV100 compared to HTHS and very strong additive package. |
VisualEcho6642.50 F87source7355.00 |
06-05-2021, 03:36 PM | #109 | ||
6643
Rep 4,145
Drives: '18 M2 6MT
So I'm going to try the Pennzoil platinum euro 5w40/quaker state euro 5w40 in both cars, 2 birds with one stone, unless you say otherwise. Not sure about that 40W, should be fine, right? I'm not racing the car, it's just a fairweather friend. And THANK YOU both for all the help. |
F87source7355.00 |
06-05-2021, 03:56 PM | #110 | |
7355
Rep 7,527
The only concern for a 40 weight is dependent on the bearing clearance, like for example if it was supposed to take a 20 weight or 30 weight maximum but now you are stepping up to a 40 weight there might* (and I emphasize might) be a problem. I have no idea what lotus specs but it should be ok. As long as you don't put 10w60 in there like some people do for the s55.... then you should be fine. (Like this guy: ) *Pennzoil/quaker state 5W40 is a relatively low viscosity 40 weight (kv100) so it should be fine.
VisualEcho6642.50 |
