10-31-2014, 05:16 PM | #67 | |
European Editor
10628
Rep 22,992
Here is a friend of mine @JK135i with a N54, 135i... his exhaust at this time had a aftermarket muffler with a straight pipe/mid. Maybe he will chime in on this thread... Anyways his car was loud! So loud you could hear him a few km's away!
12-11-2014, 08:23 PM | #68 | |
European Editor
10628
Rep 22,992
There is a reason why BMW does certain things.
12-12-2014, 11:57 AM | #69 |
27
Rep 231
Drives: 1M VO - #161 US
Wanting to quiet the resonances at 2300 and 2800 rpm, I replaced the y-pipe in my 1M with the resonator from Dack's 135.
It turned down the resonances a bit, but they are still there. More acceptable for my money, but still mildly annoying. |
12-12-2014, 04:01 PM | #70 | |
European Editor
10628
Rep 22,992
Here...
12-12-2014, 06:14 PM | #71 | |
27
Rep 231
I had already done the dynamat thing in the trunk (with a lot more than you used, and a carpet scrap to fill the area flush) with only slight improvement. |
12-12-2014, 08:22 PM | #72 |
292
Rep 2,898
Only way to get rid of it -- as opposed to simply dampening the noise a bit -- would be with a tuned helmholtz resonator.
Some very high end exhausts (perhaps Akrapovic) have them as integral part of their systems. Neil |
12-14-2014, 12:02 PM | #74 |
27
Rep 231
This is essentially the N55 mid-pipe with two add'l cats. Should be quieter than a 135, theoretically.
05-10-2015, 05:02 PM | #76 |
27
Rep 231
Resonator update
Update on the 135 y-resonator:
I'm pretty sure it's not just my ears, but over the 3000 miles it has been installed, my 1M (with Dack's 135 y-resonator) has become considerably less noisy, and the resonances at 2300 and 2800 rpm are now greatly reduced. When the 135 y-pipe was first installed, I was a bit disappointed that it didn't reduce exhaust noise more, but at this point it is acceptable. To me it sounds like a BMW 6 is supposed to sound - normally muted in driving around town, but developing a nice smooth snarl when wide open. I don't have a good explanation for this, but I'm pretty sure the change is real. Maybe oil/carbon buildup on the pipes or on the stuffing makes it more effective at soaking up sound? Theories welcome... |
05-11-2015, 01:36 AM | #77 | |
European Editor
10628
Rep 22,992
The change in sound, is real. It's the same thing forum members report after installing a PE. After a few thousand miles the tone of the exhaust changes. For me, I noticed this after 6K miles of driving. I believe its the carboning up of the exhaust that's responsible. Dack
05-11-2015, 06:06 PM | #78 |
2619
Rep 2,819
Drives: e82 1M, f87 M2cs
I put the Mad Dad mids on last August and have driven about 6000 miles since then. The exhaust has finally "matured" after its first track day last month, noticeably more snarl now even with modest acceleration, half throttle. It is exactly what I had hoped for, finally!
05-13-2015, 03:57 PM | #79 |
Moderator
29971
Rep 13,162
Akra + N55 mids: during 'spirited' Autobahn runs, after some time I start to hear a kind of 'double bass' whenever I floor the pedal. Hard to describe this phenomenon, but it sounds as if an extra rumble is added. Dies down when engine gets less stressed. Very likely heat-related.
///M is art ↔ Artemis
05-18-2015, 06:34 PM | #80 |
27
Rep 231
Artemis Have you checked the clearance around the exhaust when it's hot? Perhaps it is touching the body somewhere when it heats up?
05-24-2015, 04:54 PM | #81 | |
Rep 15
05-24-2015, 05:20 PM | #82 | |
Moderator
29971
Rep 13,162
I may run a quick check next time at some exit of the Autobahn (though a bit complicated to spot anything, even when crawling a bit under it, as the car sits already low). Don't underestimate the degree of heat flowing through the system when the car is seriously pushed.
11-18-2015, 08:32 PM | #83 | ||
Moderator
29971
Rep 13,162
BMW 1M midpipe: http://www.realoem.com/bmw/enUS/show...diagId=18_0770
And also the difference regarding the BMW 1M axle back exhaust: http://www.realoem.com/bmw/enUS/show...diagId=18_0932
12-04-2015, 12:43 AM | #84 |
247
Rep 1,585
Drives: 2011 VO 1M
Garage List 2010 Porsche 911 GT3 [10.00]
2021 BMW X5 SD40i [0.00] 2023 Toyota TRD Pro [0.00] 2011 BMW 1M [9.83] 2014 Ford Raptor [0.00] 2005 Ariel Atom 2 [0.00] 2008 135i SOLD [10.00] |
Have a question regarding the secondary cats as I cannot find my answer anywhere, figured this is would be an appropriate place to get the info. ~How restrictive are the secondary cats? I read in some e90posts that the primary are 400 cell and the secondary are 200 cell. I understand the 1M OEM DPs are less restrictive. Not sure about the mid pipe section. It matters as I am tossing around the idea of ordering some HJS 100-200 cell race cats. If the OEM cats are 200s then I will use the OEM mids (fully catlless now) Thnx
///1M #643 of #740
12-04-2015, 03:41 AM | #85 | |
European Editor
10628
Rep 22,992
I think it was Harold at HP Auto HP Autosport that said it. I know the primary cats are also different - like you mentioned above, they flow more than the 135i N54 ones. 1M mid pipe w/cats... p/n 18307845669 http://www.realoem.com/bmw/enUS/part...669&series=E82 135i N54 mid pipe w/cats... p/n 18307559994 http://www.realoem.com/bmw/enUS/part...%0918307559994
12-04-2015, 09:43 AM | #86 | |
220
Rep 695
12-04-2015, 01:35 PM | #87 |
247
Rep 1,585
Drives: 2011 VO 1M
Will do, and thnx for the response Dackel
///1M #643 of #740
