BMW M2 Forum > M2 Photos, Videos and Builds > M2C 6MT Street/Track Frankenstein.
      01-15-2023, 09:25 AM   #1
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
I am going to use this thread to publish all the modifications that I am doing to the car, although I only have to change the seats, I am not going to do anything else.
Exterior:
Full stock
Interior:
Short shifter cae (modified)
Lightweight lihium battery liteblox 2kg
Engine:
Stage2 hybrid turbos
M2 OG full decat exhaust
Catless downpipes
Oil lever sensor with spacer for 7.2l of oil
Keyed crank hub
Suspension:
Kw competition
M4 GTS Knuckles
Sway bars H&R
Rear arms with uniball joints
Manufacturing the front arms for uniball ball joints and lift kit for rear diff
Brakes:
CCB rotors, oem pads
Wheels:
Custom forged wheels
Front 19x9.5 et22
Rear 19x10.5 et42
M2cs racing rims are on the way.
For now this is all.
Sound:
Appreciate 2
      01-15-2023, 09:56 AM   #2
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Gts knuckles with custom inserts to be able to use them with kw suspension.
Modified shifter
Liteblox battery
Appreciate 2
      01-15-2023, 06:21 PM   #3
ebisu8
Dom
ebisu8's Avatar
1080
Drives: E46 M3 Comp
So jealous of your LiteBlox. They still won't ship to the US, unfortunately.
      01-15-2023, 06:36 PM   #4
to_riffic
to_riffic's Avatar
3024
Drives: rwd
novice question here....what's the advantages of the GTS knuckles?
~loud noises~
      01-16-2023, 12:59 AM   #5
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Billet machined, 2 attachment points, I suppose it allows less torsion, it also has different geometry, it does not allow more than -3 degrees of camber (for more camber adjustable arms are needed), and it also allows more ET.
What is the reason? Is it forbidden to send batteries by air?
Appreciate 2
      01-16-2023, 01:43 AM   #6
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Carbon cover like M4 GTS
Rear subframe
Oil lever with spacer
Front arms bushings
Testing gt4 oil stick
Anodized rear brake protectors and arms.
Appreciate 4
      01-16-2023, 10:53 AM   #7
AB M2C
74
Drives: 2019 M2C Hockenheim Silver
Awesome, excited to see how this progresses. Any plans for a cage?
Current -- 2019 M2C MT
Sold -- 2009 E82 135i MT Widebody Track Car
Sold -- 1989 E30 325i MT Showcar
Sold -- 2005 E46 M3 MT
      01-16-2023, 11:31 AM   #8
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
I do not plan, maybe I'll change my mind later
      01-16-2023, 01:25 PM   #9
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
The last weekend I made some tools to remove the bushings from the diff bracket:
Appreciate 3
      01-19-2023, 02:47 PM   #10
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
M2CS Racing rims arrived
With 4mm spacer on rear, i hope 20mm at the front is enough, i will ride them with the 2NH brakes
Tires 295/30
Appreciate 9
(K)1278.00
aatlas192.00
gphung193.50
The_Werm212.00
Shaq935.00
      01-20-2023, 04:55 AM   #11
MWelt
MWelt's Avatar
70
Drives: 2016 Mineral Grey DCT
I see some serious skills & thought here … a talented Body Man!
From one to another ,Cheers for continued persistence on your beautiful project !
Dan
      01-21-2023, 10:11 AM   #12
MadM2C
74
Drives: Bmw m2 comp
These wheels clear 400mm without issue?
      01-21-2023, 03:26 PM   #13
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Dan
Thanks 💪
Yesterday i tried the front rim:
With 20mm spacer
I had to cut the protector, it is bigger than the inside of the rim.
Today I took out the calipers, i'm going to mill the outside face a few millimeters.
Appreciate 4
      01-21-2023, 04:16 PM   #14
MadM2C
74
Drives: Bmw m2 comp
If you can provide any measurements/pics on the milling please. I’d replicate this to run 18s as well
      01-21-2023, 04:49 PM   #15
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Yes, no problem.
      01-22-2023, 12:55 AM   #16
MadM2C
74
Drives: Bmw m2 comp
I'm surprised you were even able to get the wheel mounted onto the car to be honest!
Those wheels must have great inner barrel clearence
      01-22-2023, 02:21 AM   #17
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Before buying the rims I was sure that I would be able to mount them with 400mm brakes, my 19 rims have an internal diameter of 460mm and there is still space between the caliper and the rim (with the naked eye about 15mm), the 18 rims have an internal diameter of 448mm, for this reason reason I knew they could be mounted.
Appreciate 3
Fabb228.50
The_Werm212.00
      01-22-2023, 04:42 PM   #18
MooMooM2
MooMooM2's Avatar
1818
Drives: M2 Comp
that is very cool. After all, there is an 18 that actually fit the 2NH.
Whole car is looking amazing
Appreciate 2
aatlas192.00
      01-22-2023, 05:01 PM   #19
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
I can't stop looking at the wheels every time i pass the car, bmw did an awesome job, for me these are the best wheels.
Today the calipers are finished:
Appreciate 9
      01-22-2023, 07:33 PM   #20
MadM2C
74
Drives: Bmw m2 comp
Very nicely done. Any before/after pics of calipers?
My only concern would be if this compromised and structural integrity of the caliper. Especially under hard loads
Looking forward to see everything mounted!
      01-22-2023, 11:58 PM   #21
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Appreciate 2
      01-23-2023, 06:16 PM   #22
MadM2C
74
Drives: Bmw m2 comp
So you took few Mm From top middle and bottom. Any concerns with caliper strength with missing material?
m2
