I Am Not Sure This "d" Will Make it
12-28-2011, 07:19 PM | #1 |
149
Rep 2,383
It is in serious need of a "DEFusion".
Note the logo on the Diesel Exhaust Fluid Bottle. The VW parts guy said they get lots of BMW and Mercedes owners coming in for the DEF. LOL
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
12-28-2011, 11:49 PM | #3 |
149
Rep 2,383
I dont know, you could put water in a bottle and pass it off as DEF and most people wouldnt know the difference. I trust VW to put the right stuff in bottles if it is going to be put in cars they warrantee....
Anyway, I posted that to show people my new "funnel". I picked it up today at Wallmart. In toto (well not including the light stand and duct tape), it costs about $10, but it allows pouring from the 2.5 gal container with both hands.
12-29-2011, 03:41 PM | #7 |
149
Rep 2,383
I must admit, even with this setup, I spilled a bit. I pour the 2.5 gallon bottle with one hand on the handle and the other supporting the bottle on the bottom. I learned that the bottom hand needs a latex glove. The DEF sloshes around pretty good in the bottle.
08-22-2012, 06:45 PM | #8 |
28
Rep 743
funnel
08-22-2012, 07:50 PM | #9 |
208
Rep 3,175
08-22-2012, 08:22 PM | #10 |
149
Rep 2,383
I have used a small funnel, but it takes a long time and I had to first move the fluid to a smaller container because the big one is too heavy to pour with one hand. Then the small funnel fills up and you have to wait for it to drain -- tedious.
As previously mentioned, there is a smaller container which is designed to screw onto the inlet in place of the cap. I havent ever had one of these, but I have read that others have adapted these to be able to refill them (apparently they are designed to be one-shot things), so if you buy one once, you can use it and refill it and use it again. Also, maybe you could cut the bottom off and use it as a funnel but you would probably need to attach it to a stand like I did in the above photo with the transmission oil funnel.
08-23-2012, 07:19 AM | #11 | |
143
Rep 634
08-23-2012, 07:47 AM | #12 | |
28
Rep 743
08-23-2012, 11:50 AM | #14 |
143
Rep 634
When it stops flowing in. By using the bottle screwed into the fill port, because it is not very high, you will always be below the vent of the tank. If you fill using a hose from higher up (as in the picture at the beginning of this thread) you could overfill the tank and have DEF come out the vent which will only crystalize and possibly plug it.
08-26-2012, 08:17 PM | #15 |
Rep 44
Pick-up a $8 gallon bottle from VW dealership and drill a 1" hole in the side at the bottom (not ON the bottom though). Go to autozone etc or your local truck stop and get a few gallons of the stuff cheap, pour it into the jug with the hole and put a rubber cork in it so you dont splash it out while you're pouring.
Fill one gallon at a time. When the fill tank equalizes with the bottle, you're done! |
08-28-2012, 04:10 PM | #17 |
149
Rep 2,383
Well, I would rather spill a bit of DEF than have high octane race gas spewing all over the place.
10-01-2012, 06:20 PM | #18 |
28
Rep 743
I did my first refill with 2.5 gallon DEF BLUE from Oreillys. It comes with a short plastic slinky hose. Managed to get 2 gallons in there. Spilled alot. I need to buy that hose setup. we need more pics of peoples setup/devices
10-02-2012, 06:07 AM | #19 |
229
Rep 3,489
Drives: Montego Blue 335d
cool stuff @ roegr arent you coming down to the island soon you pmd me on this tell the dates so we can meet
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
