Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > You can now purchase TPMS sensors directly from me (even if you don't buy wheels)
Closed Thread
      03-29-2007, 12:07 PM   #1
Gary@TireRack
Moderator
Gary@TireRack's Avatar
369
Drives: Formerly 1995 M3
You can now purchase TPMS valves and sensors for TPMS equipped 2007 BMW 3 series cars directly from me. We've had a policy change so I can now sell the sensors separately from the wheels.
Current price is $46 per corner for both the sensor and needed valve stem. Shipping on a set is usually $8-$10. These are not available on the site so call me directly at extention 386 to order.
All BMW valve sensors are currently being produced by BERU and are sold by us in two parts: the sensor component and the metal valve. The size of the sensor shouldn’t be a problem for many wheels, but if the valve hole is in the middle of the wheel’s barrel, then obviously the sensor will not fit properly. The wheel industries are aware of the valve sensors and are rushing to get most of their wheels TPMS-compatible.
If you aren't buying wheels from us *please* be sure to verify with a dealer of the wheel or the manufacturer of the wheel that you are buying that the wheel is TPMS compatible. I've already had a few forum members have to go to the trouble of shipping back sets on wheels that were not compatible with sensors.
If you have a 2006 model you have an indirect system. BMW’s indirect system will not affect the choice of switching aftermarket wheels or tires. The system runs off of the ABS/wheel-speed sensors which “count” the number of revolutions of each tire. If the right-front tire is low (25psi) it will spin faster than the left-front tire (35psi), so the ABS system will recognize this change and alert the driver with a flashing light near the gauge cluster and possibly a loud chime. Some 2007 models also have indirect systems.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
Turati0.00
      07-28-2008, 02:05 PM   #2
Gary@TireRack
Moderator
369
Price updated to $50 per corner as of 7/21/08.
      07-08-2009, 03:23 PM   #3
Gary@TireRack
Moderator
369
Updated, now $49 per corner as of 7/08/2009.
      06-24-2010, 09:59 AM   #4
Gary@TireRack
Moderator
369
Update/More info:
The pricing on 2010 and 2011 sensors is higher, currently at $80 per sensor, or $88 including the valve stem. The older 07-09 sensors will *not* work on 2010 and 2011 cars.
Unfortunately the web site isn't set up to accept orders for TPMS sensors at this time. I'd be happy to help over the phone or via email.
One way to get around the web problem would be to add a complete set of wheels to the cart, then the site will allow you to add the sensors. Next, delete the wheels from the shopping cart, so that all that will be left is the sensors.
Just refer to "Gary/e90post" as your previous contact towards the end of the order.
      12-13-2013, 09:28 AM   #5
Gary@TireRack
Moderator
369
Update :
Current pricing has been bouncing around the neighborhood of $55-$60 per sensor.
Be sure to specify the year of the BMW you are ordering sensors for as there are three different types based on the year.
If you're having trouble finding/ordering the TPMS sensors on our site, try this : Add a complete set of wheels to the cart, then the site will allow you to add the sensors. Next, delete the wheels from the shopping cart, so that all that will be left is the sensors. Just refer to 'Gary/E90Post' as your previous contact.
Closed Thread
