02-23-2024, 06:14 PM | #1 |
1618
Rep 2,274
Today I received the 2nd part for the next phase of performance modifications for my car... it came in the form of the Newer Cast version of the Pure 800 Turbo.
My current setup is: Stage 2+ BM3 93 oct map XHP Stage 3 VRSF 4.5" Catted Downpipe TU HPFP TU Spark Plugs MST Intake Masata Chargepipe Remus Catback Exhaust As some of you know the Pure 800 has been a popular turbo in many B58 cars, but this newer Cast one is even better with more gains. It has a cast compressor housing along with a cast exhaust manifold, essentially built from the ground up. This turbo also spools up quicker than the older Pure 800. Another positive, there's no core charge with this so you get to keep your stock turbo too. I bought the turbo directly from Pure Turbos EU. Very happy with the whole buying experience and service from them. I ordered it Wednesday evening and it arrived Friday morning. Few more bits to get before everything gets done. I already have a 5" Osprey Performance Catted Downpipe waiting to go on. I'm also going to upgrade my coolant lines and coolant tanks to the newer versions that BMW released for the G30. Looking forward to getting all these bits on and seeing where the build goes.
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
02-24-2024, 12:44 PM | #2 |
188
Rep 2,225
Please document as much as you can I’m very interested. Pics of the new vs old coolant stuff would be great, I’m not sure what is on my 2019 540. I plan on doing something similar with this car a little down the line but I already have a catless downpipe and stage 2 MHD tune. Will this be your daily driver?
Good luck with the modding. |
Junebug851617.50 |
02-25-2024, 11:10 AM | #3 |
Joint Chiefs of Staff
24201
Rep 190,807
Awesome, congrats!
Junebug851617.50 |
02-25-2024, 11:43 AM | #4 | |
1618
Rep 2,274
Thank you
IG: project540ix
darkrom188.00 |
03-12-2024, 08:59 AM | #5 |
1618
Rep 2,274
Few more parts have arrived that will be going on same time as the turbo install.
Parts to be Installed:
Decided to swap the coolant tanks and pipes for the newer versions to try and combat one of the G30's common issues.
IG: project540ix
03-13-2024, 01:00 PM | #6 | |
drive to survive
87
Rep 443
03-13-2024, 02:50 PM | #7 | |
1618
Rep 2,274
As for the TU plugs, they were recommended to me for tuned B58 engines. The BMW B58TU spark plugs are the same as NGK 94201(SILZKGR8B8S) spark plugs. I did read that they help with knock resistance and misfire reduction...it's something I've tried and not seen any negatives, so went with a new fresh set. My last set of plugs were fitted at 45,000 miles. The car is at around 56,000 miles now.
IG: project540ix
03-31-2024, 08:42 AM | #9 |
57
Rep 87
I wonder....
I wonder if I should change the following as well...
BMW V2 Coolant Tank BMW V2 Charge Cooler Tank BMW Coolant and Charger Cooler Tank Caps BMW Coolant Tank to Radiator Pipe BMW Intake Manifold to Charge Cooler Tank Pipe I am currently awaiting.. IPOS Motorsport IM450 B46/B48 Turbo Upgrade IPOS B48/B46 Upgraded Intake Manifold IPOS Motorsport B46 True 4-Inch Catless Downpipe B58TU/Supra High Pressure Fuel Pump The car just went above 40k and it's barely driven for a 2018. Since everything will be out, I guess I might as well. Do you have those part numbers? |
Junebug851617.50 |
03-31-2024, 10:21 AM | #10 | |
1618
Rep 2,274
Some nice upgrade for your car there! I've heard of IPOS - they have some decent stuff on their website. Part numbers below for all the coolant bits: 17125A02485 - Pipe, Expansion Tank-Radiator 17117639020 - Coolant Expansion Tank Cap 17139846642 - Coolant Expansion Tank 17135A1BD89 - Charge Cooler Tank Cap 17139485733 - Charge Cooler Tank 17128602646 - Pipe, Intake-Charge Cooler Tank
IG: project540ix
darkrom188.00 |
03-31-2024, 10:49 AM | #11 | |
57
Rep 87
The B48 modding scene has finally taken off its amazing seeing the numbers people are putting down. Anyway, looking forward to seeing where I go. The car already brings a smile to my face every time I drive it. Thanks for the part numbers! |
Junebug851617.50 |
04-01-2024, 05:15 PM | #12 |
159
Rep 324
I'm keen to do this update as well on the cooling side to prevent what sounds like a weak point in the older tanks. Odd thing I noticed with the Expansion tank is that RealOEM seems to list item 17139884859 as the current version. They state it Supersedes: 17139487210(02/01/2018 — 05/29/2019), 17138742975(07/24/2017 — 03/08/2018), 17138610656(07/01/2015 — 01/18/2018) The part 17139846642 you used wasn't even listed on there. <confused>
G30 540i M Sport | MPPSK | VSRF Catted d/p | Burger Intake | BM3 Stage 2 | XHP Stage 3 | FTP G-58 / G3X
04-01-2024, 05:30 PM | #13 | |
1618
Rep 2,274
17139884859 shows an 'up to' date of 08/2020 I don't think 17139846642 is on RealOEM as it's a part that comes on the LCI cars (which are not on RealOEM as you know) but the part is still backward compatible with pre-LCI cars.
IG: project540ix
DBO159.00 |
04-01-2024, 06:47 PM | #14 | |
159
Rep 324
Good to know the part numbers. I'm going to try and order through my local and do the upgrade as part of next service. Keep us posted in terms of the mighty Pure800 upgrade. The car must be brutal with that on board.
Junebug851617.50 |
04-02-2024, 04:52 AM | #16 |
1618
Rep 2,274
haha. She's grown immune to them and given up
IG: project540ix
04-04-2024, 12:28 PM | #17 |
188
Rep 2,225
I'm super curious with the power on the 5" catted. I know a supra thread out there somewhere has a guy with an upgraded turbo wondering why he didn't make nearly enough power as he expected, and when he went from catted to catless it was a massive difference, not the usual small numbers people quote for a stock turbo car. I've been very skeptical of all the claims that catted vs catless is a small difference on B58, I'm not sure how that could be the case for just this platform specifically.
I guess we can always compare your car to a catless one with similar mods, but the tune and tuner and so many other factors will come into play. I'm hoping it makes great power because my catless smells so bad right now I'm beginning to think I actually have a leak somewhere in the system. |
