08-12-2019, 12:06 PM | #1 |
171
Rep 324
Staggered or square winter setup
The temperature dipped a little yesterday and I have already started thinking about winter tires lol.
I am thinking of putting Michelin Pilot Alpin PA4s on my original 437m wheels. We don't get tons of snow here and I can get away with not driving much even if we do (I can work from home). Will my staggered setup be good enough for winter? I've heard that a square setup is better. But if I could get away with using the same wheels then that would be awesome. Any thoughts or suggestions would be appreciated! |
01-06-2022, 02:43 PM | #4 | |
203
Rep 166
01-06-2022, 07:40 PM | #5 | |
284
Rep 566
Lowered on MP coilovers. (I loosen rebound 1 or 2 clicks on all 4 corners for the winter, depending on conditions, the more slippery the more loose you want, for most conditions just 1 click softer (re the default factory summer settings, leave the compression as is, default 595/600 mm lowering, front toe-in at 0.02', rear toe-in at 0.09, rear camber at -1.50). My conditions in winter are mostly frozen/icy roads, lots of cold/wet or icy roads, some slush and snow, sometimes packed snow, and occasionally (but not very often) a lot of fresh snow. Suits me just fine. Provides me reasonable or lots of traction in my conditions and perfect balance of the car handling-wise. Better than 99.9% of the vehicles around me. I don't do any off-roading. In my conditions and with my winter settings I am confortable going through all kinds of backroad twisties, alternating automatic/manual gearbox settings, and doing 140-180 km/hr on more or less straight roads. On some straights I can take it over 200 km/hr. I take off quicker than most 4WDs, and I certainly catch up with them if they somehow manage to take a lead. I stop better than most of them because of the wider tires. Also, I can manoeuvre around them on slippery roads, something they have trouble with. I typically drive in sport plus, occasionally, if super slippery, in just sport, always in MDM, so I change my rears once a winter season. I might re-consider re the staggered setup if I was driving in mostly lots/deep of fresh snow, but I typically don't. (as the only time I might have trouble with this setup is not just some or a little but LOTS/deep of fresh snow). Last edited by x233; 01-06-2022 at 07:50 PM.. |
01-07-2022, 03:27 PM | #6 |
184
Rep 107
If you are only going to need them for moderate snow and cold temps, staggered Alpins work great. I too work from home and I run staggered Alpins on my stock rims here in Salt Lake. I would not attempt to go up to the ski resorts if it was snowing. I would say that they are serviceable in moderate snow and ice; starting on a step hill in snow isn't great. I do have a little rubbing when the wheels are turned and I am reversing so be aware of that.
chris7197334.00 |
01-17-2022, 11:43 AM | #7 |
103
Rep 116
Square setup
My cool weather setup is square so I can rotate the tires front to back. Probably switch them next season. Not looking for looks or performance this time of year.
01-17-2022, 12:54 PM | #8 |
79
Rep 47
01-17-2022, 03:15 PM | #9 |
3907
Rep 4,048
Drives: 2020 M2C, 2019 330xi, 2017 Q7
I'm so confused with this. Your 245s rub up front? I have 255s up front and they rub (one size up should not imo) even two different brands of tire. So BMW has designed this wheel well for ONLY a MPSS 245?!?!?!
01-17-2022, 03:34 PM | #10 | |
10665
Rep 6,939
Drives: 2018 M2 AW DCT
BMWCCA member Puget Sound Chapter
01-17-2022, 05:16 PM | #11 |
3907
Rep 4,048
I've been seeing this everywhere, its related to the winter tires. For some reason, the outer edges of the winters are chunkier than summer tires, and there are many members who report rubbing with 245s 255s for winter tires on the M2C. When I put my winters next to my MPSS, you can tell right away there is gonna be a problem. Whats amazing to me is that BMW left so little room in there for anything besides a summer tire
01-17-2022, 05:26 PM | #12 | |
10665
Rep 6,939
Al Bundy's Dodge1640.00 |
01-17-2022, 05:28 PM | #13 | |
7334
Rep 7,299
However, I will say that I have zero rubbing that I can tell with 245 PA4 mounted on 437M wheels, 2021 M2C. I'm not sure why it doesn't happen to everyone, but I've parked about 30 times now since I mounted them and haven't had any rubbing at low speed. Maybe there are some large tolerances on the wheel well liner stack. |
01-19-2022, 04:03 PM | #14 | |
83
Rep 53
Drives: 2021 M2C
chris7197334.00 |
