K-CAN error codes Pro HU
04-24-2024, 02:44 AM | #1 |
Rep 12
Hi, I recently retrofitted a 2010 Professional HU with BT to my 2008 e93.
I already managed to change the VIN # with WinKFP on the new unit, in "MASK/CCC" and "MOSTGW" But I have the following problems: 1) When connecting the new radio to the car, after I turn ignition on, I scan the car using ISTA and I always get so many "K-CAN" fault codes. For example, it says "CAS: K-CAN line fault", "FRM: K-CAN line fault", "PDC: K-CAN line fault" What would be the cause of those error codes? I forgot to mention that when I switch back to the original radio, after clearing error memory, the error codes are gone. Lastly, I don't know if this is an issue (I believe it is) but when I connect the new HU to the power, it always makes a high pitched sound like electrical/frequency, that goes away and comes back again, for as long as the HU is powered on. 2) With NCSEXPERT, I can't manage to read the 2RAD module when having the new HU connected to the car, I noticed that there is a "RAD22.something" file when trying to read the module, and in the old HU the name of that file is "RAD2.something" and I can read that one. I'm using a standard K+DCAN cable Any help would be deeply appreciated. Thanks |
