03-01-2024, 01:35 PM | #23 | |
2326
Rep 5,777
I was suggesting a higher neg front camber to get more grip out of it. As long as the inner to outer temps are uniform then the actual magnitude of camber doesn’t matter. I’d say the difference in compound has a larger effect on balance than a shorter sidewall. If you made the change at only one end, it would alter the front-to-rear ride heights but you swapped both together. Your use of the 275/30 on the GTS supports it’s not a shorter, slightly stiffer sidewall (sidewall stiffness is dominated by internal pressure, not structure excluding RFTs) that’s altering turn-in balance. You’re probably overdriving the different brand 285/30 a bit expecting it to provide the same grip level as the 285/35. |
03-01-2024, 02:14 PM | #24 | ||
1404
Rep 1,367
And the rear tires were in this condition when I changed to ad09, in that condition I had more grip than now with ad09... and also before I had -1.8 rear camber now -1.5. |
03-01-2024, 04:02 PM | #25 |
7605
Rep 3,605
1. AD09s have a stiffer construction overall = more stiffness 2. Moving from a 35 to 30 profile tire = more stiffness 3. Moving to a stickier compound = rear is gripping more which has the knock on effect of feeling more understeer Since you're running pretty low compression as it is, probably the best pragmatic approach is to try to adjust front rebound up slightly (sounds like you've done this) and/or drop the front sway-bar to the softer position if that is an option. Don't take my advice as the gospel though, those are just the things i'd look at messing with first.
Current: F80
Prior: F82, F32 |
03-01-2024, 04:26 PM | #26 | |
1404
Rep 1,367
I agree with points 1 and 2, ad09 added a lot of stiffness about the third I never experienced anything strange, I had a lot of grip in turns and corner exits |
03-03-2024, 10:28 AM | #27 |
1113
Rep 1,313
I forget if I posted this previously somewhere, but when I entered the world of adjustable suspension, to help wrap my head around what different things do, I made this flowchart algorithm on addressing understeer & oversteer, broken down by which phase of the corner things are happening. This was made directly by copying the approach outlined by suspensionsecrets.co.uk. I've read other resources that cite somewhat different approaches, but I like how this one tries to break things down.
https://drive.google.com/file/d/1iCt...ew?usp=sharing If people would like I'm happy to modify if there's a consensus about a different way to approach some of these scenarios |
03-03-2024, 12:40 PM | #28 | |
2326
Rep 5,777
Ksoft_tire = (Kspr_w*Ktire_so)/(Kspr_w+Ktire_so) = (605*1800)/(605+1800) = 453 lbf/in Kstiff_tire = (Kspr_w*Ktire_st)/(Kspr_w+Ktire_st) = (605*2200)/(605+2200) = 475 lbf/in So for a 22% change in tire stiffness, the wheel rate changed by 4.8%. Some spring manufacturer spring rate tolerance is higher than 5%. It requires a MASSIVE change in tire stiffness to have a significant change on wheel rate. I doubt the two tires in question have an order of magnitude difference in stiffness. Does tire stiffness matter? Absolutely. But for the spring rates we’re using, a realistic change in tire stiffness has a small effect on wheel rate and/or handling balance. Tire ultimate grip, squirm and slip angle have a much larger effect on handling balance. |
03-03-2024, 12:53 PM | #29 | |
2326
Rep 5,777
03-03-2024, 02:44 PM | #30 | |
1404
Rep 1,367
Today i try +9clicks rebound on front and 4 rear, low speed and high speed compression at minimum and have been able to go quite fast and I found myself quite comfortable, I also tried increasing rear compression, I don't like it, it becomes quite harsh. Front tires ended up drowned I don't want to imagine how much additional grip I would have with this amount of rebound clicks and sport rs tires, if the grip increases proportionally it has to be awesome. Last edited by Track/S; 03-03-2024 at 02:53 PM.. |
03-04-2024, 07:36 AM | #31 | |
2326
Rep 5,777
I had heard the ad09 was supposed to be a decent track tire but you’ve shown the opposite to be true. I’m surprised by how much on-track understeer you experienced with the ad09. The ad09 must like a different hot temperature/pressure range as well as a different cold starting pressure from the sport rs. It probably has lower overall grip than the sport rs. However, I’d look at it as a blessings in disguise! Using it showed you the true balance of your M2C was biased towards understeer which was being masked by grippier tires. However, as you’ve made suspension changes on the street, the post-track rebound adjustments using the ad09 have shown improvement in both balance and cornering speed as well as increased comfort/confidence. Confidence is a big part of getting a setup right. You won’t be fast if you aren’t confident in the car. At 100 mph, saying to yourself what the hell is this thing going to do as you approach the corner means you won’t attack the corner! I’m thinking you probably overdrove the ad09 on track by expecting/hoping it would provide the same level of grip as the sport rs but you’d get more and more push. This just drove up the temperatures/pressures of the ad09 even more quickly which only exaggerated the understeer. The rebound changes you’ve been making with the ad09s on the street should carry over unchanged to the sport rs on track. It may require a change or two to account for grip differences at elevated temperatures and the differences between the ad09 and sport rs. The good thing is you’re dialing out the understeer and feeling more comfortable in the car. Looking forward to hear how things go on your next track day. |
03-04-2024, 10:28 AM | #32 | |
2326
Rep 5,777
jfritz271113.00 |
03-04-2024, 03:46 PM | #33 | ||
1404
Rep 1,367
I would like to try ad09 with hottest asphalt, maybe it works better at higher temperatures, sport rs works great in cold, hot and wet conditions, everything I am testing is on street, on track does not matter to me since this year I will not attend no event. I also just remembered with sport rs I had a total 4mm rear toe in and I could go fast in slow corners, now with ad09 and 2mm toe in I have understeer... |
03-04-2024, 04:35 PM | #34 | |
2326
Rep 5,777
The sport rs sounds like it’s a great performance tire that’ll also get good mileage out of a set. How cold was it? I was at a track event in 2004 where the ambient temperature was 14 F and my PSC’s would come off track barely warm to the touch. It was a great day for working on car control. Road temperature definitely impacts the available grip you can get out of a tire. It’s fair to give them another try on a warmer day. 4 mm total rear toe is more understeer-ry than 2 mm total rear toe so it definitely points to the tires and/or temperatures. I’m glad you’ve found a street setup that’s both comfortable and confidence inspiring. |
03-04-2024, 05:09 PM | #35 | |
1404
Rep 1,367
I have tested sport rs from 0°C to +30°C, 275/30/19 treadwear is 240, 285/35/18 is 180. I have ordered a set of 285/35/18 want to try them with the current suspension settings |
03-04-2024, 05:53 PM | #36 |
2326
Rep 5,777
Interested to read about how the rs 285/35 with the revised damper settings perform compared to the ad09 on the same settings.
03-04-2024, 07:43 PM | #37 | |
1113
Rep 1,313
03-04-2024, 08:22 PM | #38 |
2326
Rep 5,777
Yes I was and I deleted my original comments. That’s what happens when you’re doing it on your phone where you can see only one section at a time.
03-04-2024, 08:37 PM | #39 |
1113
Rep 1,313
Hah, no worries.... the one thing for me that doesn't make sense in particular is the rec for corner entry oversteer under hard braking, where it says to soften rear rebound. Seems to me (and my own experience backs this up) that INCREASING rear rebound would be the solution, slowing the forward weight transfer to keep weight on the rear to improve rear grip.
03-05-2024, 09:43 AM | #40 | |
2326
Rep 5,777
03-06-2024, 05:47 PM | #41 | |
2326
Rep 5,777
jfritz271113.00 |
03-06-2024, 06:50 PM | #42 | |
1113
Rep 1,313
Given your suspension knowledge, when you have a minute, I'd be interested from a theory standpoint in hearing your Cliffs notes version of how you think about addressing mid-corner issues. In theory, this is the phase where the car has taken a set and the weight has stopped moving around -- so if that is true, damper adjustments should largely be moot/unhelpful, no? The flowcharts kind of reflect this, in that the majority of interventions listed for mid-corner under/oversteer are non-damper-related. But there are a few damper interventions listed for some scenarios.... |
03-06-2024, 11:03 PM | #43 | |
2326
Rep 5,777
To answer the first question, yes. For a smooth midcorner without curbs, the damper R and C forces are zero because there’s no relative motion/velocity. Answer to the second question also is yes. Dampers cannot be used to alter the balance of steady-state cornering. If the weight transfer from braking and cornering are done and the corner is smooth then the dampers are no longer part of the equation. Steady-state cornering balance is altered by making spring rate changes, ride height changes, rake changes, changing front track width, changing rear track width, adjusting front and rear tire pressures, changing tire compounds, changing tire widths, width, altering suspension alignment front and rear, etc. but this all changes as soon as you encounter one bump midcorner! Not too many perfectly flat, not-a-single-bump corners left on race tracks anymore. |
jfritz271113.00 |
