01-30-2023, 08:29 PM | #1 |
Rep 7
Negative Scrub Radius after changing tires and rims..
Hi,
On my M235i xDrive GC the original tires are 225 x 40 x 18" on 8" ET 54 rims. I would like to change them to slightly taller tires for driving comfort. So for tires 225 x 45 x 18" on new BMW rims 8" ET 57> The simulation shows that I will get a Negative Scrub Radius -7. compared to original tires and rims. A question for those who know the secrets of BMW suspension settings . Is this difference [ -7 ] within the tolerance limits of the suspension ( Scrub Radius ) settings . What is the factory value of Scrub Radius ????? If not, does this difference affect ride quality. I can't find technical exact suspension data for the M235i xDrive GC anywhere. I will be grateful for your help .... |
01-30-2023, 09:50 PM | #2 |
Bored at work....
891
Rep 5,393
What simulator are you using for your calculations?
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
01-31-2023, 12:00 AM | #4 |
Rep 7
https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm
I didn't notice your text until later..sorry Chris |
01-31-2023, 09:55 PM | #5 |
Bored at work....
891
Rep 5,393
That unfortunately, is beyond my suspension knowledge. Though
Why not use the ET54 rims? But I’d be more concerned about increasing the rolling diameter by at least 4%…I didn’t know if this is within allowable tolerances for the xdrive / ABS computers.
02-01-2023, 03:35 AM | #6 |
1133
Rep 553
Well, the 19" wheel of the 235 has 235/35 tires on it, there is a margin for bigger ones, but 225/45 18 is even bigger than that. Do you have the adaptive suspension? If so, the bigger tire might touch the strut.
To improve the driving comfort, id first suggest to check the tire pressure and lower it. Whats the pressure on your car? I'd start with around 35psi, but wouldnt go below 32.
2022 G82 M4 Competition xDrive in indiv. Sunset Orange
Incoming: 2023 F40 M135i xDrive in indiv. Tansanite Blue |
