02-12-2008, 07:08 AM | #23 |
Reincarnated
245
Rep 4,227
Total poser!!!
02-13-2008, 06:31 PM | #24 |
350
Rep 2,937
Drives: 2013 Estoril 328i M Sport
I can chime in on this as I have HK in my 05 M3 and I've spent some quality time with 752 in my father's 08 M5. In the M3, taking the volume to a certain level gives severe distortion and gives off an annoying rattle throughout the car. 752 doesn't distort in any sense even with max volume. It's equally clear and balaned whether on max volume or mid volume. The two subs under each front seat are very impressive as well in terms of offering a deep, firm bass that doesn't shake the frame of the entire car.
02-21-2008, 06:38 AM | #26 |
136
Rep 1,274
02-21-2008, 11:35 AM | #27 |
Rep 82
02-24-2008, 02:37 PM | #28 | |
1133
Rep 8,020
02-24-2008, 02:40 PM | #29 |
2306
Rep 13,010
02-24-2008, 03:32 PM | #30 |
34
Rep 330
02-24-2008, 04:09 PM | #31 |
1133
Rep 8,020
Don't like 2ohm setups, usually make the sound a little bright for my liking.
So re-cap: HiFi is the 676 option which if I remember right doesn't have a centre speaker. So basically the only different between it and the Logic7 setup is 3 extra speakers, a bit more power and the Logic7 system itself. Has anyone compared the 676 system to the Logic7 to see if the extra dosh is worth it? |
02-24-2008, 07:20 PM | #32 |
2306
Rep 13,010
02-24-2008, 08:16 PM | #33 |
102
Rep 1,035
02-25-2008, 02:05 AM | #34 | |
34
Rep 330
Footie, I've been in various cars with the base system and was in a 6 series that has the hi-fi system as standard and noticed the difference, I've ordered the logic 7 system so will let you know when it appears |
02-25-2008, 07:55 AM | #36 |
2306
Rep 13,010
One possibility: if you replace 4 ohms speakers with 2 ohms and leave everything else in the system the same you effectively are doubling the current load in the system. Thus it is possible that that "brightness" is simply amp(s) gain adjustment or amps that are not stable at 2 ohms.
02-25-2008, 10:46 AM | #37 | |
1133
Rep 8,020
I always believed that Rockford kit was designed to run in 2ohm form, one amp running a multitude of speakers. Don't know if it's just their brand but at low/normal volume levels things was quite decent but as the volume increased so did the brightness, maybe there was too many mids and highs in the setups over subwoofers but I wasn't too impressed. At least the BMW system has numerous amps for certain speakers so probably everything is just fine. If the Logic7 is remotely as good as my B&O setup in the S5 I will be happy enough. |
02-25-2008, 05:19 PM | #38 | |
2306
Rep 13,010
02-26-2008, 02:14 AM | #39 |
1133
Rep 8,020
Please explain what you mean so I can understand a little better, I was assuming that it was that subwoofers in general require a lot more power from the amp accordingly than either the mids or highs and because of the one amp setup the subwoofers were being lost in the mix. I understand that the midrange is the most important to get right as it's the one the human hear is most sensitive to because we are designed to hear speech. I know this conversation is way of topic but we you rate multi amp much better an option in a car than a single amp setup. I see heat is the biggest issue to a single amp setup as the lower the ohms the more the amp has to work and the harder it works the hotter it gets, do you agree. |
02-26-2008, 04:43 AM | #40 |
102
Rep 1,035
This is getting way off topic, I've spent decades in autosound and competition. As impedance drops, the only thing you can say is in general that THD goes up. And it's not even to a point where it can be heard. We're talking fractions of a percentage. Sound quality has almost nothing to do with impedance. The linearity of the system will be the same regardless.
footie, whatever difference your hearing is due to everything except impedance. Just didn't want to leave the readers misinformed that 2 ohms sound any worse than 4 or 8 ohm systems. I can spend paragraphs explaining why but this is an M3 forum and my baby's got a V8 that is gonna rev up to 8400 RPM and make some music that can't be compared to. I'm too old to participate in these debates nowadays... |
06-10-2008, 08:27 PM | #41 | |
221
Rep 2,339
07-01-2008, 01:23 AM | #42 | |
48
Rep 1,436
Drives: E70 X5 M
'13 E70 S63B44A
'17 95B GTS |
07-01-2008, 03:57 AM | #43 |
2306
Rep 13,010
Subs are the same size regardless, the specs are different: HiFi's are 2 ohms, Individual's most probably are 4 ohms, power handling should be more than double in the Individual's.
07-01-2008, 05:10 AM | #44 | |
1133
Rep 8,020
This might expalin why the individual can cope with twice the wattage. |
