The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Rear rattles
      12-15-2005, 11:50 AM   #1
CPTHALL
50
Drives: None
Rear rattles
Picked up car on Monday. Heard a rattle in the rear. Thought it was the rear plate but I screwed that down. Nothing in trunk. Sounds like rear deck or something in that area is clangging. I have rear shades. Anyone else with this?
2013 535XI M-sport
2012 Cherokee Overland
2010 BMW S1000rr
      12-15-2005, 11:55 AM   #2
obLu
obLu's Avatar
50
Drives: 330i 6MT ZSP
Does it sound sort of metalic? Do you only hear it when you hit a bump instead of a continous rattle? I noticed a lot of posts about it previously but they made it sound like it was a continous rattle. Mine is only a metal on metal sound when I hit a sharp bump. Thought it was my son's car seat, but I'm starting to wonder now.
      12-15-2005, 12:39 PM   #3
CPTHALL
50
Drives: None
Thats exactly what it sounds like. Sounds like a lincense plate and the metal plate cover banging together but I screwed both down. It somewhere in the back near the rear shelf or in the trunk. Nothing in the trunk. Only when I hit a bump.
2013 535XI M-sport
2010 BMW S1000rr
      12-15-2005, 12:49 PM   #4
SCA
SCA's Avatar
565
Drives: Multiple BMWs
Do you have rear fold-down seats? If so, open them and then close them firmly (hard).
      12-15-2005, 02:17 PM   #5
bavarian19
General
bavarian19's Avatar
517
Drives: Car
Ive now heard something on my rear shelf. Almost as if the seal is off with my back window and the body of the car. Dont know if this is a familiar sound to some of you or not...
      12-15-2005, 02:18 PM   #6
lucas.kent
lucas.kent's Avatar
143
Drives: M3
2016 BMW M3  [0.00]
Yeah, I actually have that same noise. It sounds like the rear deck is creaking up against the window or something...
      12-15-2005, 02:22 PM   #7
bavarian19
General
bavarian19's Avatar
517
Drives: Car
You notice it recently when the weather has gotten a bit colder?
      12-15-2005, 02:25 PM   #8
e90driver
Drives: 06 325i, 08 328xi
I hear it on the rear parcel shelf. There is a peice of plastic that meets the glass, if i push down on it, it makes the same noise. I was going to remove it and fit it with some sticky felt but haven't had the chance yet- Plus it looks like a complicated removal via the trunk, if any of you guys get it fixed let me know.
see ya
06 325i. IT'S HERE!- 08 E92 328xi, Premium, Auto, Cold- Montego Blue
      12-15-2005, 02:25 PM   #9
Squawks
One of my two dachshunds:
Squawks's Avatar
53
Drives: B6 A4 3.0 Quattro
Check the cupholders in the back. The could be loose. Stuff the rear cup holders with paper or something and see if that eliminates the rattles. If so, you know you have a rattling rear cup holder.
      12-15-2005, 02:27 PM   #10
bavarian19
General
bavarian19's Avatar
517
Drives: Car
Its in the rear shelf... not the armrest...
      12-15-2005, 02:41 PM   #11
Graphite330isp
Drives: 2006 BMW 330i
I have the same problem, noise coming from the rear shelf/window area. Kind of sounds like the window is crackling a little. Noticing more in cold weather. Just got the car last Monday
      12-15-2005, 03:09 PM   #12
obLu
obLu's Avatar
50
One thread mentioned something about isolating the problem to the rear parcel shelf. But I'll give the rear seat thing a whirl.
My son's car seat makes so much noise when he's not in it that I barely notice the other rattle.
      12-15-2005, 03:15 PM   #13
billgti
26
Drives: 06 BMW 330i
this is exactly what i found too. i'm pretty sure the noises u guys are hearing are from the rear parcel shelf / vent thingy. it's almost as if it's not sealed properly so whenever the car vibrates or flexes, it makes a creaking/popping sound.
http://www.e90post.com/forums/showthread.php?t=8618
      12-15-2005, 04:08 PM   #14
bavarian19
General
bavarian19's Avatar
517
Drives: Car
Its kinda funny actually... The rattle I had in my passengers side front door went away, and this one appeared :mad:
Just another thing on the list for when I bring it in...
Heres my list so far:
1 - Fix the bluetooth module (only connects 2/3 of the time)
2 - Rattle in right side fron door
3 - Rattle in rear shelf/window
4 - Program Key memory
5 - Un-program auto door locks (until its available with auto-unlock)
      12-15-2005, 09:19 PM   #15
CPTHALL
50
Drives: None
Any luck with the rattles?
2013 535XI M-sport
2010 BMW S1000rr
      12-15-2005, 10:52 PM   #16
tctic
38
Drives: BMW E90
I am quite sure it's the thermal expansion near the air ducts. I turn my climate control off completely, rattles gone. Turn it back on, come back again. At least this is the case for my car..
      12-16-2005, 08:14 AM   #17
CPTHALL
50
Drives: None
Are you sure? Sounds like a metal on metal sound when I go over bumps. Checked the rear cup holders and that was not the problem. It did seem to lessen when I turned on the rear defrosters.
2013 535XI M-sport
2010 BMW S1000rr
      12-16-2005, 12:41 PM   #18
ssam
ssam's Avatar
Drives: carefully
CPTHALL i have exactly the same metallic sound you are describing......also thought it was the plate.....but it s not
I wonder if it s not coming from the battery area ...
      12-16-2005, 12:59 PM   #19
lucas.kent
lucas.kent's Avatar
143
Drives: M3
2016 BMW M3  [0.00]
Yeah, it has definitely become more noticeable since the weather has gotten colder.
      12-16-2005, 01:04 PM   #20
CPTHALL
50
Drives: None
I took the cover off and tha battery seems tight. It seems to be coming from the rear shelf area. Any suggestions!
2013 535XI M-sport
2010 BMW S1000rr
      12-16-2005, 02:29 PM   #21
rag21
lets drink
Drives: 06 E90 325i
sounds like you guys have some junk in your trunk!!
There's no place like 127.0.0.1
      12-16-2005, 03:06 PM   #22
tctic
38
Drives: BMW E90
For my case, it sounds like plastic cracking.
