08-18-2020, 06:13 AM | #23 |
Rep 37
Hello, I have a 118i f40, I have the HBA option in the steering wheel stem and it takes me to the bmw store to acquire the function, I know this is not my forum, but the control units will be the same and the encoding option will be anyway, I am interested in knowing how you have coded it, I have bimmercode
08-18-2020, 06:27 AM | #24 |
102
Rep 250
I think only one person has coded this on a G20 via someone who knows what they are doing. It'll be advanced coding not a prebuilt menu in Bimmercode.
Why don't you just buy the software from connected drive? Probably the easier and warranty safe option. Your car comes with all the hardware by the sounds of it.
Current: 2020 M340i
Past: M140i, Z4 35is |
08-18-2020, 06:33 AM | #25 | |
Rep 37
08-19-2020, 04:29 AM | #26 | |
24
Rep 15
08-19-2020, 05:51 PM | #27 |
775
Rep 1,113
Coding isn't too much of an issue for me. I just purchased a used SZL on fleabay for $150. It's an older production revision but is essentially the same.
PN: 61317944086
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive Last edited by greekcs; 08-19-2020 at 06:01 PM.. |
08-20-2020, 02:05 AM | #28 | |
Rep 37
Do you know how coding for will active HBA ? That program need and how ? |
08-20-2020, 04:42 AM | #29 | |
20
Rep 35
179€ over here |
08-20-2020, 05:46 AM | #30 | |
24
Rep 15
greekcs775.00 |
08-20-2020, 05:49 AM | #31 |
24
Rep 15
08-20-2020, 06:29 AM | #32 | ||
102
Rep 250
Also if BMW ever update your car, goodbye coding. You'll have to start again. For £160 I wouldn't risk potentially messing up my car with complicated coding that is very different to previous gen software.
Current: 2020 M340i
08-20-2020, 08:39 AM | #33 | |
Rep 37
08-20-2020, 12:29 PM | #34 | ||
102
Rep 250
Although it should be standard, don't get me wrong.
Current: 2020 M340i
08-24-2020, 03:25 PM | #35 |
775
Rep 1,113
I'm still trying to code the feature on my M340. The SZL works and shows the option to purchase message on the cluster but that's all. (5AC) VO coding wasn't successful as previously stated. I scoured through all the BDC/KAFAS CAFD files and found some parameters pertaining to FLA/HBA but with no luck. My vehicle doesn't have the Driver Assistance Package; only Active Guard.
Shawn Sheridan suggested I may need: AppID 433 (1B1) -> MID FLA- High Beam Assistant .
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive Last edited by greekcs; 08-24-2020 at 03:36 PM.. |
08-26-2020, 04:49 PM | #36 |
775
Rep 1,113
After trying for days to code HBA, I reached out to r33_RGSport for help. Unfortunately we weren't able to activate HBA and only produced driver assistance errors. I have a feeling Driver Assistance Package equipped vehicles may have the HBA feature unlocked on KAFAS. This would mean standard Active Guard equipped vehicles are SOL. The only other solution I can think of is retrofitting an FLA equipped mirror but at this point it's not worth going any further with this project.
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive Last edited by greekcs; 08-26-2020 at 05:08 PM.. |
09-23-2020, 04:34 PM | #37 | |
Rep 8
Drives: G20 M340d
10-08-2020, 02:03 PM | #38 | |
Rep 25
BMW is securing there car's more and more... I'm afraid VW has started a new way of branding options with the golf 8. OTA option store. |
10-13-2020, 02:04 AM | #39 |
56
Rep 256
Just to confirm my 330e, build date 9th September, arrived yesterday and has the 2nd button for HBA. Clicking prompts me to buy the £160 option. Not sure how that then gets to the car via logging in to connected drive in the car I assume.
10-15-2020, 01:02 PM | #40 |
Rep 25
Like I said. You can login to Connected drive and buy the option.
04-04-2021, 08:40 AM | #41 |
Rep 6
Any update on the topic? I have 2019 G21 330i with retrofitted laser lights but without HBA. I would love to use whole potential of those great lights but in my car there's no 'auto' button under 'BC' at left stalk near steering wheel to activate anti-dazzle function. I can replace the stalk but not sure if that will be enough to make it work. My camera is KAFAS4 - MID FLA. Some people say it's impossible in G20 to retrofit HBA because you need FSC code and BMW is not selling it at the moment - I don't see any part number for High Beam Assistant - 01B10001. I'm doing some research before buying the stalk, any help would be appreciated.
06-03-2021, 04:47 PM | #42 | |
Rep 6
08-05-2021, 01:12 PM | #43 | |
24
Rep 15
10-24-2021, 09:38 AM | #44 |
Rep 6
Do you mean that you added HBA without FSC? Who did that for you? I already replaced the stalk but that's not enough to make it work. After pressing auto button the car asks me to buy this option via ConnectedDrive store but it's not possible because it's greyed out.
