BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
BPM
      06-06-2010, 02:27 PM   #67
bavarian06
bavarian06's Avatar
74
Drives: e46 m3
"equipped with Macht Schnell Competition Spacer kit: (18mm front, 15mm rear)"
is this safe? i would imagine 18mm longer studs to raise some safety issue in addition to strain on the hub since the center mass of the rim is being pushed outward. but what do i know. some insights would be appreciated since i want a flush setup but afraid of potential prolonged issues.
      06-06-2010, 02:54 PM   #68
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
8208
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
18mm is fine, X5s have been running much larger spacers for years.
We typically do not recommend running larger than a 20mm spacer (regardless of application) without moving to an adapter setup - or preferably, moving to a wheel with a different offset.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      06-20-2010, 08:56 PM   #69
MaverickNemesis
49
Drives: Your Girl Crazy
what size spacers are best with eibach springs and stock 19" wheels
      06-20-2010, 11:54 PM   #70
JH M3
JH M3's Avatar
117
Drives: 2017 F80 M3 ZCP Azurite Black
Just had Eibachs installed with 15mm front and 12mm rear spacers.
      06-21-2010, 08:15 AM   #71
MaverickNemesis
49
you think 18mm and 15mm would rub with the eibach springs?
      06-21-2010, 11:27 AM   #72
david @ eas
david @ eas's Avatar
257
Drives: BMW
Might be close to the edge, and over hard bumps, yeah it might rub. The safe bet is 15mm/12mm like shown above.
      06-21-2010, 05:49 PM   #73
MaverickNemesis
49
how about 15/15?
      06-21-2010, 08:45 PM   #74
M3nator
M3NatOR
M3nator's Avatar
Drives: 2010 E92 M3 AP Coupe
PM me for Spacer size: Front: 15mm and Rear: 12mm!
      06-22-2010, 11:44 AM   #75
EAS
EAS's Avatar
548
Drives: VF620 M3
how about 15/15?
Same idea, the rear might rub since it is more aggressive than 15/12.
Will do
      06-26-2010, 11:41 PM   #76
SlamMan
SlamMan's Avatar
148
Drives: ED 5/19/2010, Interlagos E90
Done any spacers with competition package wheels yet?
      06-28-2010, 02:00 PM   #77
EAS
EAS's Avatar
548
Drives: VF620 M3
Yes we sure have!
      06-29-2010, 04:32 PM   #78
Em Trey Drvr
Drives: 2011 E92 M3
What spacer sizes did you use for that comp package m3?
2011 M3 Coupe; Brilliant White/Amarone; Competition, Tech, Premium Packages; Everything Else...
      07-02-2010, 12:49 PM   #79
EAS
EAS's Avatar
548
Drives: VF620 M3
That would be a 12mm front and 5mm rear spacer
      07-02-2010, 01:46 PM   #80
BMWDEMON
Super modder
BMWDEMON's Avatar
104
Drives: E90 M3 & E46 M3
How much for an E90 M3 - 18mmF and 12mmR - MS type
Thanks!
M
SOLD - 2005 E46 M3 ZCP - I/B on black
CURRENT - 2011 E90 M3 - meticulously modified
2015 X1 Xdrive 28i
      07-02-2010, 05:18 PM   #81
EAS
EAS's Avatar
548
Drives: VF620 M3
Thanks!
M
PMed you to keep this thread on topic
      07-06-2010, 05:01 AM   #82
11' AW M3
80
Drives: 11' ZCP E92 M3
could you go even more aggressive? Did the 12mm front and 5mm rear result in the wheels being flush with the fender?
I am really interested in doing this as well...
2011 AW/FR Extended E92 M3... fully loaded
      07-12-2010, 09:15 PM   #83
11' AW M3
80
      07-13-2010, 11:35 AM   #84
shawshank772
shawshank772's Avatar
120
Drives: 08 135i and 16 M3
Here is one dilema you may run into with larger than 5mm rear spacers. Since the rims are 1/2 wider it allows you to put wider tires on in the future. Once the tires wear out I no doubt plan on going wider. With that said. If you go 10mm rear and they are flush with the fender with stock tires, they will obviously rub if you go with wider tires. I am just using random spacer sizes but I think you get the point. That is why I am going to hold off on getting spacers.
      07-13-2010, 12:17 PM   #85
tom @ eas
tom @ eas's Avatar
8208
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Keep in mind buddster swapped his tires to a 255 front and 295 rear Yokohama AD08 setup, which changes spacer requirements. Those keeping the stock tires will need a bit more aggressive setup.
      07-23-2010, 06:55 PM   #86
11' AW M3
80
Tom,
For someone who is going to keep the oem tires with the zcp wheels, I am guessing you would recommend 15fr and 10rr?
      07-26-2010, 12:22 PM   #87
EAS
EAS's Avatar
548
Drives: VF620 M3
Tom,
We would actually recommend 12mm front and 5mm rear.
      07-26-2010, 04:46 PM   #88
11' AW M3
80
david, that is the setup you used on the zcp m3 you guys did with the wider tires. Tom (a few posts above) mentioned that oem tires would need a more aggressive spacer setup.
I would like to make them as flush as possible. When I eventually change my tires for a wider stance, I will change my spacer setup if needed...
m3post
