BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
      09-18-2016, 03:30 PM   #1
Hujan
Hujan's Avatar
569
Drives: M3
Replace panel w/ start/stop and sunshade switches
I recently deleted my car's rear sunshade and never use the auto start/stop feature. As such, I have zero need for that control panel with those two switches and would thus like to delete that panel to clean the interior up a bit.
I cannot for the life of me find the part number for the clean panel in that spot. Can anyone help a brother out? I am referring to the panel seen just above the little cubby above the DCT shifter in the photo below (although, unlike the panel in that pic, my seat heater switches are in the A/C unit; that panel is where the sunshade and auto start/stop switches are):
      09-18-2016, 06:03 PM   #2
Chuck's M3
Chuck's M3's Avatar
162
Drives: with driving gloves...
Looks like it's called radio trim; #10 from link below.
https://www.getbmwparts.com/parts/20...gramCallOut=13
Part Number: 51459118703
center bezel w/navigation
Part Number: 51459137564
center bezel w/o navigation
Hujan569.00
      09-18-2016, 09:38 PM   #3
Hujan
Hujan's Avatar
569
Drives: M3
Thanks. My fear is that that is just the trim piece that surrounds the strip of buttons as shown here:
If so, that would leave me back at square one. I guess I'm hoping there is a piece that deletes that entire strip of buttons (basically the above piece but without the lower of the two cutouts). Failing that, I would settle for a strip of buttons without any buttons designated.
      09-19-2016, 11:39 AM   #4
whats77inaname
825
Drives: when at all possible
The panel containing the buttons contains blank button faces. It's modular so if you had the kit, you simply pull off the seat heater faces and put on the corresponding blanks in their place.
https://www.ecstuning.com/BMW-E92-M3..._All/ES168433/
I have the kit but I'm planning on using it for another project to stealth up some of my add-ons
But, the piece you're wanting, I actually ordered a few months ago as mine was peeling. I'll get you the part number when I get home.
Edit: here you go, part number 51459118703.
https://www.ecstuning.com/Search/Sit...8703/ES119249/
Hujan569.00
      09-19-2016, 01:31 PM   #5
Hujan
Hujan's Avatar
569
Drives: M3
Thank you, sir! You are a gentleman and a scholar!
      09-19-2016, 01:34 PM   #6
whats77inaname
825
Takes one to know one
Hujan569.00
      09-19-2016, 11:20 PM   #7
Chuck's M3
Chuck's M3's Avatar
162
lol
Hujan569.00
      09-20-2016, 07:28 PM   #8
Hujan
Hujan's Avatar
569
Drives: M3
lol
My bad, Chuck! It was the picture that confirmed for me that the part number that "whats77inaname" (and you) found was the right one. The link to Tischer had me a little unsure.
But thanks to you as well! You were the first!
      11-10-2019, 01:20 AM   #9
wyatth
3549
Drives: E90 ZCP
Bumping this up, did you ever swap the trim piece? I only have auto start/stop there and would like to remove the row of blanks for a plain trim piece, but not sure if it’s that simple or if the auto start/stop will spaz out when disconnected.
Like this, not mine:
      11-11-2019, 03:55 AM   #10
chocstraw
chocstraw's Avatar
496
Drives: E92 M3 ZCP
There's space in there, you can just leave the button row hanging. I don't think it likes being disconnected but I don't remember. It might default to start/stop on when disconnected.
      11-11-2019, 11:38 AM   #11
wyatth
3549
Drives: E90 ZCP
^ Ah, interesting idea. Though knowing it's not "tidy" behind the panel may trigger my OCD. Easy swap, I imagine?
Default auto start/stop to ON would be hellacious!
      11-11-2019, 12:08 PM   #12
chocstraw
chocstraw's Avatar
496
Drives: E92 M3 ZCP
Very easy, I lifted the transmission leather panel then just pried it off. Might not even be that complicated but it runs the lowest risk of scratching any soft-touch plastic.
Could use some gaffer’s tape to stick it down without leaving any adhesive residue.
      11-09-2023, 02:57 AM   #13
hson10
hson10's Avatar
140
Drives: '21 A90 Supra 3.0, '11 E92 M3C
2017 BMW M2  [0.00]
quick bump on this - was this ever resolved? I also only have 1 button (2011.5 with auto start stop) and would like to replace with a clean no button panel piece as my trim is starting to peel slightly as well.
Wondering if there's enough room behind the panel to keep the button hanging or what the workaround fix is here- TIA!
2021 A90 Supra 3.0 Nitro Yellow, 2011 E92 M3 Comp Jerez Black
Instagram @hans.device
      11-09-2023, 12:20 PM   #14
jiggz
2141
Drives: E90 M3|F15 X5 50i
You just need the trim piece pictured above (assuming the picture matches that part #) that doesn't have the cutout for the buttons.
I replaced mine a few years ago as it was all nicked up from the original owner. I seem to recall there being plenty of room behind there if you want to hide that start/stop button.
      11-09-2023, 02:04 PM   #15
hson10
hson10's Avatar
140
2017 BMW M2  [0.00]
perfect thanks so much for the reply! did you leave the buttons unplugged (prob easier / ideal for me) or did you have to take off the strip of buttons from the original trim and hide it back there? Wondering what the process is like.
Thank you!
m3post
