BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
BPM
      04-21-2022, 01:06 PM   #771
nah dude
Pingu
nah dude's Avatar
237
Drives: White V8 Sedan Car
Originally Posted by kevin @ eas View Post
Since you went wider on the rear I would go with a 10mm out back.
Thank you sir! Do you think 12.5 would be pushing it too much?
      04-21-2022, 02:46 PM   #772
kevin @ eas
BimmerPost Supporting Vendor
kevin @ eas's Avatar
2919
Drives: 2015 BMW M4
P4S runs wider, 12.5 might rub since you went wider on the tire size out back.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      08-30-2022, 07:32 PM   #773
Vigoruler
Vigoruler's Avatar
10
Drives: E92 M3 Comp/F10 M5 Comp
2012 M3 Comp. Previous owner installed AC Schnitzer springs and H&R spacers 10mm and 12mm w/ZCP 19’s. Need tires, however, Michelin Pilot 4s are on back order everywhere in 245/35/19. Came across this thread searching the forum and after reading aplenty can’t for sure determine if I can run +1 all around: 255/35/19 and 275/35/19. Would hate to buy tires and have rubbing.
      09-02-2022, 12:08 AM   #774
TRM04
Drives: BMW M3 E90
E90
255/35
275/35
ZCP WHEELS
12mm
10mm rear
Just did KW CLUBSPORT. Rear rubs. Recommend 5mm?
      09-02-2022, 02:29 PM   #775
kevin @ eas
2919
Drives: 2015 BMW M4
4s is on the wider side. Depending on your rear camber setup a 10mm might clear if on the aggressive side. The 5mm is the safer bet.
Originally Posted by TRM04 View Post
E90
255/35
275/35
ZCP WHEELS
12mm
10mm rear
The 12/10 is what we generally run. Its pretty close in terms of rub/no rub and works with some brands of tires and not others. The 4S's run wide. I would step down to the 5mm rear.
      11-25-2022, 08:17 PM   #776
Vigoruler
Vigoruler's Avatar
10
Just purchased Ohlins suspension from 3DM. Setup currently consists of:
2012 Comp
AC Schnitzer Springs
ZCP 19" Wheels
Front 255/35 Michelin Pilot Sport 4S 12mm Spacer
Rear 275/35 Michelin Pilot Sport 4S 10mm Spacer
EDC light came on not long after the tire install and passenger front looks like rub.
I'd like to have proper spacers in hand when I take the car for the Suspension install.
Should I ditch the spacers entirely? Which spacer size for the front and which spacer size for rear would be best for the Ohlins setup on these ZCP wheels and Michelin tires?
      11-27-2022, 08:07 AM   #777
vitalsigns
192
Drives: BMW
I have this exact same set up: Ohlins, ZCPs, +1 tire sizes and 10/12 spacers.
The 10f/12r spacer combination works perfectly, but of course in your case will partially depend on how low you set your Ohlins.
      11-28-2022, 05:26 PM   #778
kevin @ eas
2919
Drives: 2015 BMW M4
2012 Comp
ZCP 19" Wheels
The P4S tires run wide vs others. 12/10 has worked for some people and not for others we have done. The safer bet if you want to avoid running all together is 10/5mm but does really depend on the ride height like vitalsigns mentioned.
      11-30-2022, 10:26 AM   #779
vitalsigns
192
Drives: BMW
My mistake here. I run 12f/10r. Got them mixed up in my head, but not on the car!
      02-10-2023, 04:43 PM   #780
VR1
638
Drives: E92 M3 Comp
kevin @ eas looking to pickup a set of wheel spacers, I have a ZCP car on stock suspension with the 19" 255/35 285/30 GTS tire setup. Would 10/12 be the recommended set up?
      02-13-2023, 02:13 PM   #781
kevin @ eas
2919
Drives: 2015 BMW M4
Depends on the tire brand you have but I would say p4s I would go 10mm front and 5mm rear.
      05-26-2023, 06:52 PM   #782
heyitsrev
Drives: BMW E90 M3 Competition
2011 E90 M3 Competition
ZCP Suspension
ZCP 19" Wheels
I can't decide if I should go 12f/10r or 15f/12r.
I would prefer zero rubbing.
      05-26-2023, 09:21 PM   #783
rjsiciliano
159
Drives: 2013 MW e92 M3 ZCP
ZCP Suspension
ZCP 19" Wheels
15/12 will most likely rub especially with ps4s’s as they run wide. 12/10 should work on stock suspension but if you ever go lower it will probably rub.
I am on swift springs 255/275 sport cup 2’s which run even wider than the ps4s. I am running a 10/5 spacer setup and it does not run very happy with the fitment.
      05-30-2023, 01:17 PM   #784
kevin @ eas
2919
Drives: 2015 BMW M4
ZCP Suspension
ZCP 19" Wheels
Thats what I have been seeing too. 12/10 would work on most 255/275 setup but the 4s is wide. Stock height can get away with 12/10 but lowered needs to use 10/5.
      10-19-2023, 06:32 PM   #785
Reddevils7
Reddevils7's Avatar
980
Drives: F87 M2CS
2010 E92 M3  [7.83]
2020 F87 M2CS  [7.13]
My E92 should be arriving soon.
I have a pair of VMR V710FF with Michelin Alpine PA4/5 at 255/35 and 275/35 sitting in the garage that I plan on installing for the winter.
Wheel specs
19/9.5/22
19/10.5/35
Compared to 359M, I was planning on no spacers in the front as the outer edge will be extended by 15 mm. The rear outer edge is retracted by 4 mm so I was planning on 15 mm spacers in the back. Should this be good? I'm on stock non zcp springs with EDC
m3post
