2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications love this thing 😍 first up on mod list: wider wheels and tires!
      10-19-2023, 05:47 PM   #1
kehone2995
Drives: BMW E46
https://kodi.software/
https://dltutuapp.com/tutuapp-download/
      10-22-2023, 03:11 PM   #2
John in VA
985
Drives: 2015 228i M Sport
Search through posts on the Suspension section or ask over there - I'm sure it's been discussed. Good luck! https://www.2addicts.com/forums/forumdisplay.php?f=522
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      10-22-2023, 09:56 PM   #3
WolfGTI
WolfGTI's Avatar
716
Drives: '17 F22,15 E84 M Sport,02 R53
2017 BMW M240i  [0.00]
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
Welcome - car looks like mine did the day I picked it up in 2017. Where are you in NJ?
Integrated Engineering engine mounts, Dinan CAI, AA catted DP, Remus resonated cat back.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD.
Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r).
      11-01-2023, 11:38 PM   #4
SpencerC_6MT
SpencerC_6MT's Avatar
197
Drives: '17 M240i 6MT
2017 BMW M240I  [0.00]
Even if you're not interesting in Apex wheels, they have a fantastic fitment guide for the F2x to help you decide on a setup. For a brief overview on your options though:
If you want to keep a square setup, the absolute maximum you can manage is 255-section. That requires very aggressive camber and perfect size/offset wheels, so I wouldn't suggest that route. 245/35/18 square is pretty manageable, but will also require camber plates. I'm running 245/40/18 since I prefer extra sidewall, but fitment is tight. 235/40/18 seems to be the happy medium for our platform, and 18x8.5+40 is the fitment to go with it.
For staggered, you'll probably want to stick to 235's on the front, and 255's or 265's on the rear. It seems to me like most staggered folks run an 18x9.5r and 18x8.5f, but I never did a deep dive on it. 245f/265r is probably the maximum grip setup you can run on the street, but will also require camber plates up front.
I wouldn't suggest changing from 18" personally, but there are options. 17" wheels with a lot of clearance will clear stock brakes, but you're cutting it real close, especially on the rear. 19" is totally possible, though you'd lose some ride quality to the sidewalls.
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
2addicts
