M2 Technical Topics > Suspension | Brakes | Chassis > M2 incoming but coilovers arrived
      05-10-2016, 06:55 PM   #45
M3 Number 86
3221
Drives: black m3
Also anyone know the spring rates? Are these double adjustable?
      05-10-2016, 09:02 PM   #46
Jay-K
Jay-K's Avatar
Indonesia
384
Drives: Slow
Originally Posted by metrickid View Post
Here is mine at the BMW recommended height provided in the install instructions.
Attachment 1406634
sh*t that looks good!
"Well, there's a straight-six engine at the front, a manual gearbox in the middle and drive goes to the back. That's Page 1, Chapter 1 from the petrosexual handbook" - JC
      05-10-2016, 10:08 PM   #47
simmomi
Drives: 2000 BMW 528i
Attachment 1406634
Holy crap, that's HAWT!!! Looks FANTASTIC!!
      05-11-2016, 04:18 AM   #48
M+M
M+M's Avatar
New Zealand
227
Drives: M2 DCT MPerformance coilovers
Hmm, should be the same if we both used the same recommendation. I measured it to be 595 mm up front and 600 mm in the rear when I collected the car but it might have settled a bit. I will measure it again and see. The measurement should be made with 2x 75kg in the car according to BMW so that might be a reason for it to be different depending on if the installer did that or not.
Yes sorry if I was unclear but I have retained the 5mm front down difference vs the original flat (equal front and rear) but have set up a little higher than you. So far I have not had any problems over any kerbs or speed bumps or car parking ramps. so I am very happy with the set up. I will check heights at first service after break in and maybe decide if I want to lower any more.
These pics posted over in general discussion forum
Appreciate 4
      05-11-2016, 04:24 AM   #49
M+M
M+M's Avatar
New Zealand
227
Originally Posted by fourscore View Post
Looks fantastic..
My question for me is; is having the better, lower look in contrast to (or a trade off with) the firm/hard ride around town or is it simply an acceptable compromise in your opinion?
Many thanks
thing is the kit is height adjustable so you can set up where you want and also bump and rebound adjustable so around town if you find it too hard you can back off a little to find the right compromise.
      05-11-2016, 04:26 AM   #50
M+M
M+M's Avatar
New Zealand
227
don't know spring rate but shocks have separate dials for bump and rebound so yes 2 way adjustable
      05-11-2016, 04:32 AM   #51
M+M
M+M's Avatar
New Zealand
227
Originally Posted by mhanism View Post
Any need for spacers?
So far no hint of any rub. Spacers may result in rub on the body because on my car the clearance is nice and tight within the guards
      05-11-2016, 05:57 AM   #52
kmx
New Zealand
25
Drives: BMW E90 335i MSport
Attachment 1406634
Wow that looks incredible. This is how they all should come off the factory floor looking like that.
Amazing looking car. Congrats.
      05-11-2016, 07:07 AM   #53
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
M+M - looks superb. Has front camber increased much ? I ask as MPSS have a softer outer shoulder so can wear prematurely.
Given the noise and lack of reliability in aftermarket camber plates - it would be interesting to see an M2 with MP suspension mated up to M4 GTS offset top mounts........
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      05-11-2016, 07:23 AM   #54
alex-e92
alex-e92's Avatar
23
Drives: 2011 335is
Attachment 1406634
this looks so damn good. aggressive af.
      05-11-2016, 08:10 AM   #55
M+M
M+M's Avatar
New Zealand
227
Since this is for me a DD car the post install wheel alignment was set at factory road spec by the dealer. I haven't looked at the readout sheet yet to check as it was left with the original suspension in box. I was too impatient at delivery (last Saturday) to go try some back roads and didn't want the heavy suspension sitting in the boot and I haven't gone back yet. Probably won't get the chance to do that either till next week as I have an out of town Targa rally this weekend. Just by eye if anything I think the risk is the negative camber on the rear might cause the inside to wear faster than outside. You can see outside row of tread blocks don't pick up any dust when just parking in parking building and the rest of the tire does - not sure if this happens also on standard suspension. So possibly with less roll movement and too much slow speed driving might get more inside wear.
      05-11-2016, 08:17 AM   #56
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
M+M - I reduced rear camber on my jb4'd M135i from -1.7 to -1.3 to aid traction from my 245/35/18 tyres.
My comments are about more negative camber on the front axles
      05-11-2016, 09:06 AM   #57
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Looks great! I will have a look at the height again when my wheels arrive and I see the fitment. The front is quite low as it is now for me.
      05-11-2016, 10:55 AM   #58
N & M
371
Drives: F90 M5
Laguna Seca
I got the impression that the M2 press cars at Seca were on standard suspension and M track brake pads. Is this correct? Or did they have the coil over suspension installed?
      05-11-2016, 02:13 PM   #59
F30form
18
Drives: '13 Mini Cooper S Hardtop
Standard Suspension and M Performance Pads, correct.
      05-11-2016, 02:40 PM   #60
M+M
M+M's Avatar
New Zealand
227
Ok thx. I will check and ask tech at 2000km breakin service
      05-12-2016, 06:44 AM   #61
jusblazeee_f22
jusblazeee_f22's Avatar
334
Drives: '13 E92 M3
Attachment 1406634
Its perfect
      05-13-2016, 04:58 AM   #62
N & M
371
Drives: F90 M5
Thanks!
Thanks for the reply.
      05-16-2016, 08:11 PM   #63
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1621
Drives: ///Ⓜ️
Looks very good
IM POOR..
      05-16-2016, 09:31 PM   #64
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
Is adjusting the height something we can easily do in our garage?
Current
AW BMW M2
Past
VO BMW 1M
      05-17-2016, 06:19 AM   #65
M+M
M+M's Avatar
New Zealand
227
It is supposed to be with the tool supplied with the kit. access under the car is the thing so best with wheels off and car jacked up off the ground. The instructions are given to measure the ride height but in reality the best thing is to corner weigh the car and make it equal weight side to side front and side to side rear. Instructions suggest that you should simulate passenger weight in the car by having 75kg in the driver and passenger seats. However my thinking is a bit different.
So far I have not corner weighed the car but will likely do so after the 2000km service to let the suspension settle down. And I will do it with just me in the driver seat - no passenger weight. My logic is at normal road speeds corner weights are not critical. If going fast - say on track it is most likely that there will be only 1 in the car.
      05-17-2016, 09:14 AM   #66
OrangeCrush
1236
Thank you.
Current
AW BMW M2
Past
VO BMW 1M
m2
