DFFF -- Dont Fear the Fuel Filter
09-12-2013, 10:09 PM | #45 |
Rep 56
That didnt work on my 2011. Maybe others would have different luck. That process was brought up much further back in this post.
'11 335d Sport
CCNP, MCITP-EA |
10-12-2013, 01:38 PM | #46 |
28
Rep 234
Just did mine today. After replacing the pump, I put the key in and pressed the "START" button without starting the car. Left it for a few minutes. When I went to start the car, it cranked for a few seconds and stopped on its own. I waited a few seconds and did it again. Cranked a few times and started right up. BTW, mine is a 2010 if that makes a difference.
10-12-2013, 02:02 PM | #47 |
Jumping Jack Flash
324
Rep 1,692
Drives: 2021 X3 M40i
FYI, at 25,451 miles, the computer sensed something that, among other things, caused the dealer to replace my fuel filter. The car was showing an SES light, and I neglected to check the codes before taking it in, so I can't report on that. I had assumed it was just time for the oil change, et al. They changed the "intake silencer" (air filter) too.
Interestingly enough, and I should have questioned them on their logic, they wrote "customer requests fuel filter replacement" on the service record, which was clearly not the case. But I did not have to pay for it.
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. |
10-12-2013, 06:10 PM | #48 | |
73
Rep 697
10-12-2013, 06:25 PM | #49 | |
Jumping Jack Flash
324
Rep 1,692
For the air filter they wrote "Vehicle due for Intake Silencer. Air Filter Dirty. Replaced Intake Silencer." But the oil change didn't show as due, no no oil change nor DEF top up.
10-12-2013, 07:08 PM | #50 |
96
Rep 1,592
Drives: 2011 335d, M-Sport
FWIW, Fuel filter is every two oil changes on the diesels. Every three on the petrol.
...doing mine tonight along with transmission fluid change if I can work up the energy. |
10-12-2013, 09:10 PM | #51 |
96
Rep 1,592
Ok, so I got bored and decided to go for it. FF change took only a handful of minutes once the car was jacked up and the undercarriage protection removed. I then spent quite a few minutes messing around with holding the on button for ten seconds, leaving the car in on, etc, etc. did this probably abut 4-5 times to the tune of 10-15 minutes. During the boredom, I googled fuel primer pumps which are only about 7 dollars and easily would've helped my paranoia which largely was due to the amount of fuel which came out of the old filter are removal (not the few drips which came out of the lines while changing). I'll probably order the BT for next time but the crank is going to happen right now, and survey says...
Started after what felt like 6 hrs of cranking but was actually about 3-5s (2011 MY) ...time to get started on the ATF. Have a good Saturday night, ladies & germs! |
10-13-2013, 09:08 AM | #52 | |
73
Rep 697
Interested to see how your transmission fluid change goes; I was surprised to see it is not part of my extended maintenance package. Therefore, I will do it on my own, since I just hit 60k. Just drain and refill or will you also flush? |
10-13-2013, 04:39 PM | #53 | |
96
Rep 1,592
The one thing that had me irate (there's always got to be one) was that two bolts broke. i've never unintentionally broken a bolt before (on anything vehicularly) and i certainly didnt think i would start with a bolt for which the torque wrench was set for 10nm. Now I've got to CAREFULLY handle that little issue, but otherwise went off without a hitch. Some of them seemed over tightened on their way out, so I'm wondering if they could've been over torqued or otherwise stressed at some point in the car's past. Don't let it scare you off from the job; I think it was purely a fluke. I checked the calibration on my torque wrench against another one and it seemed ok, thus I'm willing to chalk it up to Murphy's law. |
10-13-2013, 07:29 PM | #54 | |
Jumping Jack Flash
324
Rep 1,692
10-14-2013, 07:30 AM | #55 | |
3608
Rep 10,373
Visit thectsc.com for the ZF kit and instructions. |
10-14-2013, 07:35 AM | #56 | |
96
Rep 1,592
Respectively,
10-14-2013, 08:53 AM | #57 |
281
Rep 4,121
That kit is a bit incomplete. This is the correct one from zf
http://webcat.zf.com/nc2_teile_info....INSPNR_ART=252 |
10-14-2013, 09:49 AM | #58 | |
213
Rep 2,210
10-14-2013, 10:06 AM | #59 | |
3608
Rep 10,373
However there are 2 kits for the 26x. One with and one without pan screws. I asked the owner of the website about the 6 vs. 7 liters and he said that the Jaguar is filled with 7. Last edited by F32Fleet; 10-14-2013 at 10:19 AM.. |
10-14-2013, 10:56 AM | #60 | ||
281
Rep 4,121
We have the -28, not the 26 for starters... Thats correct on the kit limitations - 6 may be the correct amount. In any case I did find this: http://www.zf.com/media/media/docume...hselkit_EN.pdf Note that it recommends fluid changes every 80-120k KM or 8 years at the longest. (80,000km = 49,700 Miles) Last edited by taibanl; 10-14-2013 at 11:47 AM.. |
10-14-2013, 11:07 AM | #61 | |||
Jumping Jack Flash
324
Rep 1,692
10-14-2013, 11:15 AM | #62 | |
3608
Rep 10,373
Oil changes not flushes under their severe service schedule. |
10-14-2013, 11:54 AM | #64 |
213
Rep 2,210
I dont recall if my kit from came with pan bolts (if it didnt, the bolts that came out were all ok) but it did come with enough fluid to fill to the spec'd amount
10-14-2013, 11:58 AM | #65 | |
73
Rep 697
(Probably just trying to pass the cost on to the customers ) |
10-14-2013, 12:31 PM | #66 |
149
Rep 2,383
Well that is a relief to me, I have been putting off the tranny fluid change for about a year even though I have all the ingredients. I was a bit leery of the project because I seem to have read somewhere that the transmission fluid had to be a certain temperature before you can change it. I don't have a reader which can report the tranny temp. I believe if the tranny fluid is the wrong temperature some wont come out and I could be overfilling it.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
