M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      02-18-2024, 09:58 AM   #1
NFB F10 M5
NFB M5
NFB F10 M5's Avatar
30
Drives: BMW M5
BM3 Gauge Cluster Screen !!!
I know this isn’t a drivetrain modification, but I figured a lot of people in here would find this cool, using an updated iNav system integrated with BM3
      03-11-2024, 11:17 PM   #2
BoostedAvus
18
Drives: 2003.5 M3, 2016 M5 comp
anymore info on this?
2003.5 M3
2016 M5 Comp
      03-12-2024, 04:49 AM   #3
NFB F10 M5
NFB M5
NFB F10 M5's Avatar
30
Drives: BMW M5
What info you need?
      03-17-2024, 11:56 AM   #4
BoostedAvus
18
Are you using AirPlay to do it? I wish bm3 would go native CarPlay app that would be amazing.
      03-28-2024, 08:55 AM   #5
NFB F10 M5
NFB M5
NFB F10 M5's Avatar
30
Drives: BMW M5
I have a after markrt head unit that is Android UI while also having bmw on the other side, so on the Android side I can download any apps I want, then getting it to work with the car is a bit tricky, if you have LTE on the after market unit you can just add service to it and connect to boot mod, but if not and you use a hotspot to run apps on it, you’ll need to connect to bootmod through the hotspot, then when connected change the wifi connection from the hotspot to your OBD wifi adapter. Then go back to the BM3 app, then it will connect to the Vin. FORGOT TO MENTION!! The car has to be in accessory mode or just electrics on but not key’d on, but then once it is connected to the vin you can start the car and the gauges will start reading, as well as you can datalog through the system as usual, then upload at home.
m5post
