03-02-2023, 06:13 PM | #23 |
526
Rep 1,145
Drives: 2022 x5 40!
Easiest oil change i ever did . I always dread taking my car to the dealer for service so I’ll probably be doing my own oil changes every 5000 miles pretty basic drain replaced filter add oil make. Sure your using 0w20
10-02-2023, 02:40 AM | #24 |
The Dark Knight
422
Rep 1,262
Quick question: for the 2019 xdrive 40i do I need 6.5 litres of oil or 7.2? I read somewhere that if it is a xdrive (all wheel drive) then you need 7.2 litres. Is that accurate?
10-02-2023, 07:39 AM | #25 |
49
Rep 47
When I changed my oil and filter on my 2023 xDrive 4.0, it took 6.5 quarts (=6.2 liters) to show full on the oil-check display. Perhaps it's 7.2 liters for a dry engine from the factory?
10-05-2023, 10:59 PM | #26 |
The Dark Knight
422
Rep 1,262
Also, what is the best way to bring the oil to a warm temperature like others have mentioned which makes it easier for the oil to flow? Previously on all the cars that I have done it, it has always been on a cold engine, so just trying to figure out if I should drive for a mile and then do it or I should just let the engine run for about 10 minutes or 15 minutes and then do it or what is the best way to bring it up to the best temperature before changing the oil?
10-09-2023, 06:25 PM | #27 | |
83
Rep 108
10-23-2023, 07:41 AM | #28 |
49
Rep 47
I just changed my X5's oil for the second time. This time I added 6 quarts after draining it and changing the filter, and the on-board display still showed it was at the full level when I checked. My conclusion is that there's a pretty wide range where the car will still show the oil as full - probably so people don't come back to the dealer after an oil change looking for a top-off when it's not reading 100% full. Ah, how I miss a real dip-stick!
01-22-2024, 09:56 PM | #29 | |
Rep 1
Thank you! |
01-23-2024, 07:47 AM | #30 |
49
Rep 47
See post 12! It's a link to an oil change how-to for the X7, but it's basically the same for our G05 X5 - same engine, same oil filter location, etc.
https://g05.bimmerpost.com/forums/sh...0&postcount=12 |
02-23-2024, 08:16 AM | #31 |
71
Rep 95
Is there an online source for OE/OEM oil filters you folks use on the G05's? I've done a lot of my own service work on my Porsche's and typically use Pelican Parts or FCP Euro but I don't see the newer 2024 parts on there. Is there a dealership (online) store that doesn't charge full dealership prices?
Even GetBMWParts.com doesn't have much of anything listed for a 2024.... I have a G05 in production now but will be doing an early oil service around 3k miles (and want to use OE parts).
2024 X5 X40i Tanzanite Blue / Tartufo Merino
Past Bimmers: 1600/2; E36 M3/4/5; 740; 328 Conv (wife's); 128 Conv (wife's) Past Beemers: K1200RS; R100 GSPD; K1200 LT; R1100 RT; R1150 GS Assorted Porsche's over the last 20+ years Last edited by formerE36M3/4/5; 02-28-2024 at 02:19 PM.. |
02-28-2024, 01:29 PM | #32 | |
49
Rep 47
formerE36M3/4/570.50 |
