BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Oil thermostat housing temporary fix... need advice!
      05-04-2017, 02:16 AM   #1
ycy.yeung.cy
Drives: e90 335i
I over torqued my oil valve cap... retapped it and stripped it twice... now the housing is cracked... I'm thinking to make a block and bolt on the oil filter hoising... temporary deleting thermostat until I got another one.. will it work or not? I don't know but I'm going to find out.. wish me luck guys...
      05-04-2017, 08:13 AM   #2
AM330i
AM330i's Avatar
90
Drives: 08 535xi 11 328xi
2023 BMW M440  [0.00]
Not trying to sound like a jerk, but if you over tightened that bolt that many times to the point of cracking the housing, you definitely should be using a torque wrench until you understand how much a bolt should be tightened. That being said, I don't think blocking that off is a good idea unless you know how the oil flows. You don't want to block the flow of oil.
      05-04-2017, 08:39 AM   #3
ycy.yeung.cy
Drives: e90 335i
Well.. I tried to find torque spec on the valve cap but couldn't find it... so I torque it to 14 ft but still.... anyway imo block off the thermostat will be going back to earlier n54 model without oil cooling... please correct me if it's totally a bad idea...
      05-04-2017, 09:18 AM   #4
doru
doru's Avatar
126
Drives: e92, f25, e46, e83
Park the car until you get the part. If I were you, I would get one from the wreckers. New it costs +/- 300 $. Also as mentioned above, invest in some good torque wrenches. You need them if you DIY. If you don't have $$ for tools, you have no business fixing cars, let alone owning a BMW (Indy/dealer cost much greater than DIY).
Stable:
e92is
f25 N52
e83 N52
e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30)
      05-04-2017, 09:33 AM   #5
ycy.yeung.cy
Drives: e90 335i
I have torque wrenches in my tool box... I just can't find the torque spec... I have the money the buy the part now but I don't want to wait for shipping... and I'm thinking to spend my money to order a rb delete plate, aftermarket (custom) oil cooler and an external thermostat... if I'm going to spend money why not spend it for better part?
      05-04-2017, 09:35 AM   #6
ycy.yeung.cy
Drives: e90 335i
But still... need to wait for shipping...
      05-04-2017, 09:36 AM   #7
AM330i
AM330i's Avatar
90
14ftlbs seems like a reasonable torque for that bolt. if you are running stock, running without an oil cooler might be ok, if you are tuned, I wouldn't.
Jb4/MHd BEF, XHD Stage 3
DCI, FTP Charge Pipe
      05-04-2017, 09:47 AM   #8
Donutz
140
Drives: 335i
If I were in your position I would park the car until I had the correct part installed.
I don't advise using a torque wrench when the required torque for the fastener isn't known. I subscribe to the German methodology of 'guttenenteight', and this method (knock on wood) has never failed me.
      05-04-2017, 09:50 AM   #9
doru
doru's Avatar
126
Maybe your torque wrench is out of spec. As I said, if you would've used a wreckers yard to pick that part, you would've been in business by now at a low cost. I don't want to sound like a jerk.
Stable:
e92is
f25 N52
e83 N52
      05-04-2017, 09:52 AM   #10
ycy.yeung.cy
Drives: e90 335i
Currently FBO but running stock map... but I just found something interesting... will upload picture later
      05-04-2017, 10:51 AM   #11
avocet
252
Drives: 2007 328i 2011 X5d
Not saying you should do this, but I always travel on my motorcycle trips with some JB weld. I have used it to stop oil leaking from a cracked crankcase from a spill, and not only did it make it back to Canada from Cali, it survived another 15000km until the bike got stolen.
I also used it to fix a cracked camshaft bearing journal on an old gs550 beater bike. That sucker lasted over 40000km.
I would try to glean the crap outta that with a good chemical degreaser/solvent then get as much JB weld into that crack and clamp it as well as possible. Once set, retap the threads and be off to the races. This would be just a temporary fix!!!
      05-04-2017, 11:23 AM   #12
ycy.yeung.cy
Drives: e90 335i
Thanks for good info... noted... but I already retapped it twice... the thread is already big enough.. and I bring this thing to ask for professional technicians... we all said to get a new one... but I'll try jb weld it...
