07-28-2018, 04:52 AM | #1 |
Rep 39
BM3 stage 2 Target boost hit 28psi
I did some data logging with BM3 stage 2 911 AGG and saw that my Target Boost Psi hit 28. I remember reading somewhere that stage 2 is targeted 23 psi because going over is 24 if not good for an N26. Here is a link for my datalog.
http://www.bootmod3.net/log?id=5b5a958bd10b43626a89d488 |
07-28-2018, 07:55 AM | #2 |
2001
Rep 3,680
Assuming this is just a cruising log, because I couldn't find a WOT anywhere in there. Typically with logging, the shorter the better to make it easier for us to read. A 9 second WOT 2nd gear pull is ideal, unless you want a cruising log, like this, in which case I'd limit it to 15 seconds.
ANYWAY, the reason you're seeing 28psi as your target is because you have pressure set to absolute instead of relative in your datalog settings. Absolute pressure combines both ambient pressure and boost pressure, so 28 psi make perfect sense in the application of this log. To change it, simply go to datalogs, click the gear icon in the top right, and change pressure to relative, it will be one of the first options on the list
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
M2_MEDUSA666.00 |
07-28-2018, 02:12 PM | #3 | |
Rep 39
07-28-2018, 02:16 PM | #4 | |
2001
Rep 3,680
MAF lb/m should be around 25-30 at WOT. Try doing a log how I said in my last post and see what it's at.
07-28-2018, 11:34 PM | #5 | |
Rep 39
http://www.bootmod3.net/log?id=5b5d56f8d10b43626a89db07 Last edited by Tan_N26; 07-29-2018 at 01:35 AM.. |
07-29-2018, 03:54 AM | #6 | |
666
Rep 1,074
Instagram: M2_Medusa
07-29-2018, 04:07 AM | #7 |
2001
Rep 3,680
Just from my experience, that's how I get the cleanest and easiest to read logs. That's just how I like to do it
07-29-2018, 04:10 AM | #8 | |
2001
Rep 3,680
07-29-2018, 04:45 AM | #9 | |
Rep 39
07-30-2018, 09:47 AM | #10 |
1032
Rep 2,382
About that time then.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
07-30-2018, 05:21 PM | #11 |
Rep 39
07-31-2018, 09:07 AM | #12 |
1032
Rep 2,382
If you can get that tool made, you could knock it out yourself, alongside the plugs. Both easy installs IMO.
08-01-2018, 06:18 PM | #13 | |
666
Rep 1,074
08-01-2018, 07:06 PM | #14 |
2001
Rep 3,680
08-02-2018, 08:48 AM | #15 |
1032
Rep 2,382
WOT in second takes no more than 3 seconds maybe even 2
08-02-2018, 09:38 AM | #16 |
2001
Rep 3,680
08-02-2018, 10:24 AM | #17 |
1032
Rep 2,382
08-02-2018, 11:11 AM | #18 |
2001
Rep 3,680
08-03-2018, 08:58 PM | #20 |
Rep 39
08-03-2018, 09:09 PM | #21 |
2001
Rep 3,680
It won't, it's all in the tune. BM3 doesn't do boost by gear either, so you should be seeing the same peak boost in every gear.
08-03-2018, 10:17 PM | #22 | |
80
Rep 307
It’s not normally a lot. But you might see an extra psi of boost. |
