03-31-2016, 02:58 PM | #1 |
233
Rep 417
Standard metric for aiming headlights?
Does anyone on here know of a standard metric to use to gauge how high to aim the headlights properly (i.e., not as they come from the factory)? I want to be able to see further, but I don't want to be blinding people. I know headlight aiming is generally an inexact process, but I'm and exacting person. So if someone knows of a good measurement to use for the settings, like the cutoff should be so many inches up a wall from so many feet way, it would be appreciated.
According to the new IIHS headlight test, to the front left of the car low beams should shine about 200 ft forward and directly in front of the car the low beams about 320 ft. The IIHS tested 2er with HID headlights measured just under 100 ft on the left (less than half!!! ) and about 250 ft in front (still 70 ft short). For all the halogen people ...
Current: 2016 BMW M235i | 2013 BMW X1 xDrive28i (wife's)
Gone but not forgotten: 1992 Buick LeSaber Limited | 1999 Acura CL 3.0 | 2003 Volvo S60 2.4T | 2006 BMW x3 3.0i | 2009 Honda Fit Sport Last edited by CanadianGatorBacon; 03-31-2016 at 03:06 PM.. |
03-31-2016, 03:14 PM | #2 |
3279
Rep 3,256
I'm curious as well. Disappointing to see the 2 and 3 did so poorly. But then again, I felt that others cars I've had have much better headlights.
Subbed to see if anyone knows how to improve the performance by re-aiming the lights. |
03-31-2016, 03:50 PM | #3 |
310
Rep 886
This is the old school way. At an annual inspection, the tech was supposed to move a bunch of reference lines around on the target wall in the garage. In 40 years, I think I saw that happen once.
The 24" and 50" numbers are examples only here, to be replaced with the actuals from a 2-series. The mention of "trim rings" lets you know how old this procedure is.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi |
03-31-2016, 04:11 PM | #4 | |
233
Rep 417
I guess I could dust off the old trigonometry skills and work out a number, but I'd prefer guidance from someone with some experienc.
Gone but not forgotten: 1992 Buick LeSaber Limited | 1999 Acura CL 3.0 | 2003 Volvo S60 2.4T | 2006 BMW x3 3.0i | 2009 Honda Fit Sport |
03-31-2016, 07:35 PM | #5 | |
310
Rep 886
Measure the distance between the two headlights. That's the number to use instead of 50. Seriously, I did this on my 335. Took all of 5 minutes plus a tape measure.
03-31-2016, 07:55 PM | #6 |
BMWCCA 149159
38
Rep 847
Couple of things here. First of all every BMW I have ever owned had improperly adjusted lights. Yes they are perfect on the BMW machine but always way way too low. The chart that is used above is pretty standard. I have used Daniel Stern's method for years.
http://www.danielsternlighting.com/tech/aim/aim.html This should help some. How can BMW HID lights get a good rating when the company has then adjusted too low? I loved my BMW lights in Europe because I could raise or lower the lights using the adjustable electric switch that comes with all European cars... |
04-01-2016, 02:17 AM | #7 |
233
Rep 417
Oh, oops. Not sure what I was thinking when I read the instructions.
04-02-2016, 09:43 PM | #8 |
1437
Rep 2,526
Drives: 2011 328i Wagon
Given the HID cars are supposed to have speed-based aiming (I forget what BMW calls it), but it is not allowed in the US, I suspect this is why the headlights are aimed too low from the factory. They probably install them all the same regardless of whether that is inhibited or not. I plan to code it back in once I get one of those "round tuits" and setup the coding software.
But 30 seconds with a Torx wrench and the headlights are much improved.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
04-03-2016, 10:15 AM | #9 | |
Kingslayer
411
Rep 1,479
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i Current Cars: 2019' X3, 2021' M3 Comp |
04-04-2016, 11:13 AM | #10 |
233
Rep 417
I have to find a flat parking lot or something. My building's garage is full of drains, and there isn't a level piece of ground on any of the three floors. Maybe an emptyish mall garage will do.
04-16-2024, 02:52 PM | #11 |
Rep 13
These lights do suck. Dealer of course says they are perfect - passenger side basically shines into people's yards as I drive and doesn't hit the road, feels like I'm driving blind. Glad this info is still floating around....tonight's project
04-16-2024, 06:05 PM | #12 |
998
Rep 2,212
Find a big box store, like a supermarket, auto parts store, etc.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
