08-24-2016, 05:51 AM | #67 |
S0THPAW
8725
Rep 7,847
As MR. twinfed and repucci stated: +1
Much better no drone-ish stuff, au naturelle still heavy metal(I have the MPE)but windows closed valves open inside more silent , HK=clear now. But wind/ other noises more. Windows open MPE valves open: Infernal! And natural. I am happy! Cheers Robin |
08-24-2016, 01:48 PM | #69 | |
861
Rep 923
I ordered the harness 2 weeks a go and someone is bringing it from the USA to avoid the extra shipping and tax charges of Europe.
08-24-2016, 03:04 PM | #70 |
1753
Rep 2,942
It is not a BMW part. It is an aftermarket harness made by TechnicPnP, who is a custom audio installer in South Florida.
Here is the website link ("Top HiFi" means HK). Best results for ordering often come from an email inquiry to the address in the upper right corner of the site.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
08-24-2016, 03:06 PM | #71 | |
2089
Rep 3,007
08-24-2016, 03:10 PM | #72 |
1753
Rep 2,942
Distancing ... sorry. I, for one, won't empower a copycat. TechnicPnP's been too good to the BMW community for too long.
Besides: AFAIK, BMW harnesses are not easy to procure. That's one reason speaker pigtails are not readily available for them.
08-25-2016, 12:20 AM | #73 | |
2089
Rep 3,007
Wouldn't want to be a "copycat" sheesh... |
CosmosMpower2050.50 |
08-25-2016, 09:09 PM | #74 |
699
Rep 1,514
Anyone who has installed the harness noticed an issue with reduced Bass from the stereo? Was looking at the Technic PNP website and noticed this:
'Please note that changes in bass response may be experienced by bypassing the ASD in the HiFi/HK(674) OEM amp systems.' Also any idea if they ship to Australia? |
08-26-2016, 10:30 AM | #75 | |
519
Rep 542
However, I quickly got used to it, and now don't notice the difference in the stereo. No regrets -c
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock 2008 Acura RDX-stock 2005 Honda S2000-mostly stock 1994 Nissan 300ZX Twin Turbo-barely stock |
Prodigy.698.50 |
08-26-2016, 12:06 PM | #76 | ||
1753
Rep 2,942
08-27-2016, 08:33 AM | #77 |
628
Rep 1,424
For those who have bypassed asd, is the drop in bass response enough that a second amp and woofer would be necessary? I'm not looking to shatter my windows or anything...but I do like a bit of punch in my sound stage.
08-28-2016, 05:57 AM | #78 | |
340
Rep 310
Drives: 04A6 2.7T(DD), 16M2 BSM MT EP
Now I will reassess this on my next drive or while sitting in the driveway. I am away for a few days. After I "relisten" will report back! |
08-28-2016, 06:15 AM | #79 |
264
Rep 337
Drives: '17 M2 DCT BSM
So, knowing for a fact that bypassing the asd module causes a drop in bass responsiveness (plus it is a pain in the ass to install), isn't it better to just code it off even though there are still some fake sounds coming through the speakers?
08-29-2016, 07:34 AM | #80 | |
1753
Rep 2,942
To reitierate: the underseat 'subs' are NOT subs; they are mid-bass drivers that are tasked to handle some bass frequencies. What many call 'bass' is actually not true bass (frequencies under roughly 175Hz); it is mid-bass, which extends to about 400Hz. The responsiveness issue relates to the capability of the underseat drivers to reproduce bass, which they aren't primarily designed to do - and are not powered sufficiently to do anyway. If you really, really like true bass (i.e., you listen to hip hop or club music, which are two genres that take advantage of the low end), the HK in the M2 wouldn't have impressed you anyway because the system is not designed or powered to go that low. If you really want a system that can go that low, a dedicated sub with a dedicated amp is the ONLY option for you.
confusion601.00 MustGoFaster1.50 |
09-02-2016, 02:12 PM | #81 |
2274
Rep 3,300
It amazes me that BMW did not make this a user selected function and allow the drover to turn if off.
2018 M5 and 2019 Porsche Boxster GTS Prior. '94 325is, '97 M3 Lux, '16 M2 |
09-09-2016, 02:06 PM | #82 |
1753
Rep 2,942
Some interesting news:
According to this tread, the OP of which contains an internal document that explains how the ASD module operates, ASD may be automatically disabled if any of the speakers are disconnected. Because of the popularity of disconnecting the center channel speaker on 2 Series models with any stereo to improve the soundstage, this means that ASD is permanently shut down when that speaker is disconnected. What disconnecting the speaker doesn't do is take the ASD module out of the signal path, which means that the operational noise that the module emits is not eliminated. The TechnicPnP harness is still the only way to eliminate this.
SoCalRob281.00 |
09-14-2016, 06:04 PM | #83 |
151
Rep 929
I am already dissatisfied with the stock HK system, so living with a reduction in bass, a known side effect of the TechnicPnP harness, means that installing the harness isn't the ideal solution for me. I also plan to disable the center channel speaker, perhaps I should do that FIRST, then evaluate how much hiss is present, before going to the harness, which will reduce bass. I don't spend much time with the stereo on, but I can't live with the ASD.
So it's a choice between some hiss or less bass?
F87 '16 M2 ... Mineral Grey, 6MT, Exec, MPE Gone: E82 '13 135is 475/586 ... Mineral Grey / Oyster, DCT, Premium, Tech, HK, Michelin PSS, BMW Performance Suspension |
09-14-2016, 07:03 PM | #84 | |
BMW Newb
582
Rep 903
They've now found the identified the fix, which you can either re-wire yourself, or send the harness back to Technic to be corrected free of charge. Looks like folks have had their bass back once this is done. Here is the post in question, as well as the original thread: http://www.2addicts.com/forums/showp...8&postcount=69 http://www.2addicts.com/forums/showthread.php?t=1202389 |
09-14-2016, 07:33 PM | #85 | |
283
Rep 399
Drives: 2017 BMW M2 6MT
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold |
CAVU150.50 |
09-14-2016, 08:11 PM | #87 | ||
151
Rep 929
So perhaps I'm still missing something, but TechnicPnP previously said that the ASD unit functioned as a 15W amp (approx 8V), boosting the low 2.8V input signal from the iDrive, and that removing this 15W boost from the signal path was the reason for the missing bass. So are we now saying that the rewired bypass harness somehow retains the boost of the ASD amp without sending the ASD engine sound into the signal path? I'm hopeful, but just want to know what I'm getting into before I order the new harness. Source: http://www.2addicts.com/forums/showp...3&postcount=55
09-14-2016, 08:17 PM | #88 | |
BMW Newb
582
Rep 903
Probably best to ask in that 2'er thread...they've got a lot more experience with the harness I think. |
