Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Sponsor M3/M4 Project Cars Showcase
Closed Thread
      10-25-2014, 12:48 AM   #45
bluekn8286
103
Drives: 2011 E92 BMW M3 Dinan S1
Originally Posted by GSR Autosport
Originally Posted by jackkk View Post
So the springs are not the way to go for the track days?
Having more seat time now in the M4 I think the answer is somewhat yes and no. If you really want to put down some good times you really need to move to a performance oriented damper.
We tried the lowering springs mainly because we were looking to get more front negative camber (we were able to get -1.8), which is not ideal but something... again trying to deal with the understeer issues. With a lower CG the weight transfer of the car was a bit better but because of the reduced operating range of the damper and the fact that the H&R 435 springs we were using were not heavy enough to support the compression weight under load, high speed cornering composure was less than ideal.
Willow Springs was not a good track for the lowering springs because it is a fast, flowing track with bumps in critical braking areas (Turn 1) and corners (Turn 8). There aren't too many technical sections where you need to aggressively transition the car. I would expect the stock spring setup might be better at this track.
Now Buttonwillow is a much more technical track so transitioning the weight of the car is much more critical. It's also very smooth as it was just recently paved. I think the lowering springs could actually help at this type of track.
If you are just doing a track days for fun, every once in awhile I think the lowering springs are fine just note there limitations and be cognizant of the potential behavior changes in the car when you load up the suspension.
-Nick
This is a great way to explain how modifying the stock suspension with "high performance" springs aren't going to always net you the best results on the track. The stock springs on an M car were designed and tested for the chassis they support and changing that will only lead to inconsistent results. I am definitely in support of coil-overs because the high level of adjustability allows you to properly dial in the car for any application you choose.
      10-29-2014, 01:58 AM   #46
GSR Technik
GSR Technik's Avatar
463
Drives: F13 M6 | E92 M3 | '15 Mustang
G Load Data - Buttonwillow vs Willow Springs, OE Springs vs lowering springs
swifty asked about comparison of OE M springs and lowering springs so we thought we would take a look at two somewhat similar corners from our tests at Buttonwillow (with stock springs) and Willow Springs (with lowering springs).
We took a look the right-hand "Riverside" turn from Buttonwillow and the right-hand "Turn 8" from Willow Springs. Both are grip limited corners but Turn 8 is about 30 mph faster and a lot bumpier.
Below is the G-force trace data from the Riverside corner at Buttonwillow:
The lateral G loads look about .2 G's less in Riverside as compared to Turn 8. There is also about .2 longitudinal/acceleration G's which is putting more load on the rear.
Below is the G-force trace data from the Turn 8 corner at Willow Wprings:
The lateral G loads are maximized laterally - almost no longitudinal loads which makes sense as the corner is pretty much taken at maintenance throttle. I guess the biggest difference is we have much more weight on the front left spring in this corner - compared to Riverside.
We experienced pretty harsh suspension behaviors in Turn 8 in the bumps. Looking at the data this could have been coming from the front as each time the car hit a bump the car would bounce to the left a foot or so.
Although it's interesting to take a look at this data I don't think we can really determine a material difference between the two springs unless we test the OE springs at Willow Springs. It's tough to say that the OE springs would handle the loads in Turn 8 any better than the lowering springs.
If you are at SEMA come check out the GSR Autosport BMW M4 Global Time Attack car in the Achilles Tires booth.
-Nick
Closed Thread
f80post
