10-22-2014, 09:33 PM | #23 | |
207
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
F80 M3 / Mineral Grey-Silverstone / CCB
10-22-2014, 09:59 PM | #24 | |
Sunburnt Member
158
Rep 525
You're right... I did miss your point and read the following sentence in isolation and completely out of context
2019 Deep Blue Tesla Model 3 Performance | 2015 Mineral White F82 M4 | 2010 Burnt Orange Lotus Exige S2
Past: 2009 Ibis White S5 (APR Supercharged V8) Past: 2004 Imola Red M3 Convertible |
10-22-2014, 09:59 PM | #25 |
504
Rep 3,446
Time attack, is that like a Tardis? Awesome!
See my photography at http://ronscubadiver.wordpress.com
10-22-2014, 10:06 PM | #26 |
207
Rep 1,864
Drives: F80 M3
10-22-2014, 10:44 PM | #27 |
775
Rep 1,113
Cant wait to see it at SEMA.
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
10-22-2014, 10:46 PM | #28 |
Enjoying driving
388
Rep 1,169
997.2 and 991s ABS is programmed to compensate for no more than 0.3" rolling diameter difference between front and rear, rear being higher. Any more than that the ABS and PSM get 'confused' and make the wrong evaluation of a given situation. I wish Ice Pedal was the only issue, but it is not. This is valid with both Bosch and Siemens units btw.
10-22-2014, 11:16 PM | #29 |
///M3mber
185
Rep 430
Drives: 2008 E92 M3
Nice lap on Buttonwillow!
10-22-2014, 11:18 PM | #30 |
463
Rep 383
Drives: F13 M6 | E92 M3 | '15 Mustang
10-23-2014, 06:20 AM | #32 |
593
Rep 5,396
its almost always due to two things
1) inappropriate spring length for the damper length. the damper only has a certain amount of travel built in, and is specifically designed for a certain spring height. when you lower a car, the damper is already pre-compressed at static height, eliminating however much travel you drop the car by. you drop it an inch, at static height you already pre-compressed the damper by and inch and removed an inch of potential travel down before hitting the bump stops. so, you have made it more likely you will hit the bump stops, have made the dampers work in an inefficient range, and eliminated the majority of the travel. this is a HUGE issue and is why proper coilovers have shortened dampers to account for running a shorter spring. 2) wrong spring rates for the OEM dampers. the OEM dampers are designed for the exact spring rates in the OEM car. this is why a ZCP suspension will come with different springs (shorter) AND different dampers. because the length of the damper will be shorter and the compression rates will change due to a changing spring rate with the ZCP springs. Overall, these springs cause a huge amount of issues which are exaggerated when driving on non ideal roads which have the dampers working hard. any "benefits" of these spring kits are vastly overshadowed by the negative effects. Not to mention the fact that most of these springs run progressive rates that are completely undisclosed, so no one has idea how any of these spring rates match to the stock dampers. I don't blame the OP for testing them, I think its a good thing. Its a difficult thing for a performance shop to discuss a product they sell in a negative sense. I give them credit for being relatively honest about the springs and how they drive.
10-23-2014, 09:46 AM | #33 |
314
Rep 2,448
Thanks for the feedback. Been learning a lot from reading this thread. Some info was shared in previous threads similar to this but I think this is one of the rare ones where track data was shared by someone very knowledgeable in the technical aspect as well as the driving. Wish OP would try out the M specific springs for these cars to see how they stack up.
Kenny, just wanted you to clarify one thing. Are you stating that the ZCP dampers will be shorter as well? If so, was that true for the e92 zcp?
Current Bimmer: '16 F80 M3, '20 F87 M2c Gone but never forgotten: '13 FO e92 M3, Swifts, volks/advan, Akra Evo, Kics R40 Past: Alpine white e46 323i, Jet Black e39 530, Saph Black e60 530, Space Grey N54 e92 335, Mineral White N55 e92 335 |
10-23-2014, 10:22 AM | #34 | |
75
Rep 549
I'm thinking in getting the HAS KW kit. An if the camber plates will be available for the stock adaptive dempers it will be cool to make changes before the tack day and then go back for the street set up. Plus I drive the car at winter and I need the winter high set up. This is the reason I don't want to go with the coil overs, that I do around 3 track days a year because of the weather and free time. So you posted before about the flash on this car. Will it be or not? I'd like to have a good linear flash for the car. I don't really like the piggy backs that give power only at mid range and make car uncontrolable at the track when you open the corner. Plus I don't want to loose the power till the top end (7600rpm) like in stock. Tnx.
F80 M3 SO/SO |BM3 St.1 91 oct.|Cattless DPs|Tractive P'n'P|Brembo 6pot|Rays G25 with CUP2 tires|GTS coding|
1M VO FBO (KW DDC) PTF st.2+ sold e90 335i FBO jb4 sold |
10-23-2014, 10:23 AM | #35 |
463
Rep 383
First, we are really using these springs for an unintended use. These are street lowering springs for a 435 that comes with 225/45-18 street tires with a pretty high tread wear rating. The spring rate was probably determined based on vehicle dynamics expected in a street environment. For their intended use (on the street and lowering your car) they absolutely fit the bill.
Now, when we take them to the track, put big sticky tires on and generate well over 1g in cornering forces things begin to break down but we shouldn’t be surprised. It’s important to remember that springs generate force over distance and dampers generate force with speed. Springs need to support the forces (i.e. weight), ideally within the operating range of the damper. Dampers need to control the frequency of the springs. In this case we are generating too much “weight” for the spring – fundamentally this is the biggest issue using these springs on track with an aggressive tire setup. The spring rate is not enough and compresses on to the bump stops. We are reducing the operating range of the damper with a shorter spring but I don’t know enough about the construction of the damper internals to know if we increased the spring rate the dampers could handle the springs within that reduced operating range. I expect not but I don’t have any objective data to comment with any measure of confidence. |
10-23-2014, 10:36 AM | #36 | |
463
Rep 383
10-23-2014, 10:53 AM | #37 | |
463
Rep 383
We ran the stock springs at the first test day at Buttonwillow with R888 tires (100 tread wear), supposedly stickier than the tires we ran at the Willow Springs test - Hankook RS-3 (140 tread wear). The challenge from the first test is we had so much understeer in the car we probably weren't generating as much cornering forces as we were during the second test. During the first test at Buttonwillow there is a long right-hand corner (Riverside) that is comparable to Turn 8 (where we think we were bottoming out the dampers) at Willow Springs, although it is a little slower (90 mph compared to 125 mph) and a little less bumpy. I didn't feel that the dampers were bottoming out in the Riverside Corner with the stock springs. When a get back to the shop I will look at the data from the two corners and see if there was a big g load difference. Will post what I find this weekend. |
10-23-2014, 11:17 AM | #39 |
463
Rep 383
10-23-2014, 12:30 PM | #40 | |
Supreme Allied Commander
3888
Rep 54,565
Drives: F80 M3
***Just read 435i springs were used....that is part of the problem*** Last edited by HP Autosport; 10-23-2014 at 12:33 PM.. Reason: 435 springs... |
10-23-2014, 12:34 PM | #41 |
463
Rep 383
I don't want to answer for KennyPowers but it's our opinion that they are fit for purpose - on a 435 for spirited street driving. No for track duty on an M3/M4.
10-23-2014, 01:35 PM | #42 |
2051
Rep 25,989
Beast, good stuff!! Looking forward to seeing more updates
VMR|Wheels | 714.442.7916 |
10-23-2014, 08:32 PM | #43 |
3495
Rep 3,076
Drives: G06/G20/F30/F15/F10/E90
Get rid of the wing ... Does not fit IMO
10-24-2014, 02:33 PM | #44 |
463
Rep 383
