02-21-2015, 07:08 PM | #1 |
1438
Rep 783
Front Suspension Details
The OE front strut top mount looks like this in section:
The steer bearing is interesting in that it fully packed with balls. More typically in ball bearings the balls are separated by a cage, and it is the ball separation that permits the bearing to be assembled. Without the cage the balls could migrate to one side and the bearing could fall apart. Along the same line, a fully packed bearing is "impossible" to assemble. A close examination of this bearing shows where the outer race is split to permit it to be expanded to complete the assembly. Forum member Orb has pointed out that vertical deflection in the top mount is substantial under static loads, and is often not taken into account when considering the stack height in comparison to camber plates. I have been guilty of this omission myself, so I wanted to have a look at exactly how much deflection can be expected. This is actually an easy thing to check when they are installed in a vehicle, but my OE top mounts have been removed and replaced by camber plates, so I rigged up a test fixture, which also allowed me to get an idea of the stiffness characteristics of the mount. Here is the test setup: And the results: I calculate the static load carried by the top mount to be about 850 lbs when unsprung weight is accounted for, hence the static deflection estimate of 0.2 inches or 5 mm. Lateral loads on the suspension are reacted by the wishbone, which has a ball joint at the outboard end and a rubber bushing at the inboard end. In contrast, the M3 wishbone has ball joints at both ends. Any deflection in this bushing as a result of cornering loads will result in a tendency of the corresponding front wheel to steer away from the turn (due to the forward-mounted steering rack), which results in a compliance understeer effect. Accordingly the M3 wishbone is a worthwhile modification for a car that sees the track, although the OE rubber bushing appears to be very stiff (I haven't measured it). The bushing is shown below in horizontal and vertical sections, against an M3 bearing: "Steady state" aft wheel loads arise from rolling resistance, braking and cornering (the aft component of the tire force due to both steering angle and tire slip angle). In addition transient impact loads from surface irregularities (expansion joints and such) giving rise to NVH issues. To address both considerations the tensions arm reacts these loads in tension as the name would imply. A back of the napkin calculation suggests that apart from severe impact events, the tension loads in this member will be less than about 2000 lbs. The OE tension arm has a ball joint at the outboard end and a large fluid-filled rubber bushing at the inboard end. In the following image, tension loads will shift the inner part of the bushing to the left. The bushing contains two separate fluid-filled cavities. The hydraulic fluid permits forces to be transmitted through the body of the bushing without contributing to the bushing stiffness. The fluid also supports the relatively thin wall sections, which would otherwise quickly kink, overheat and fail. In the above image, the tension loads are horizontal and the bushing is very soft in this direction. The bushing is very stiff in the un-loaded vertical direction, simply to maintain control over the hydraulic cavities. The bushing is soft enough that it is easily deflected by hand over a short range, but then bumpers stiffen up the bushing. The bumper is removed from the right hand side of the above image. The bumpers result in extremely non-linear stiffness characteristics. The initial softness results in a reduction in NVH, and the final stiffening results in appropriate control over wheel position during cornering and braking. In order to characterize the stiffness properties I have measured deflections and loads on an OE tension strut when loaded in the tension direction. I have repeated the same test with an M3 tension arm, which uses a much simpler concentric-shell rubber bushing. The results are plotted below: Clearly the M3 tension arm is more concerned with wheel control than NVH. |
02-24-2015, 09:26 AM | #4 |
1688
Rep 3,140
Drives: 2014 M5 6MT
Adding M3 tension arms to my list! thanks.
2014 M5 6MT
02-24-2015, 04:51 PM | #5 |
107
Rep 1,428
So if I understand correctly the front control arm rear position on the non-m cars have a rubber bush and the m-cars have a ball joint on both ends. Which would be better for tight handling and road feel poly bushes or ball joints, the cost is the same for powerflex poly bushings and the trw complete arms so it's not about price, but I will get a bit more neg camber with the arms.
02-24-2015, 05:26 PM | #6 | |
21
Rep 232
02-24-2015, 05:38 PM | #7 |
1688
Rep 3,140
Drives: 2014 M5 6MT
Yes the M3/1M front arms increase negative camber (wheel and tire leans toward the strut) but the increased negative camber helps more than it hinders. The bushings are better quality and deflect less under load. They fix more issues than they create. Not that they create any at all.
2014 M5 6MT
02-24-2015, 05:49 PM | #8 | |
107
Rep 1,428
02-24-2015, 05:53 PM | #9 | |
107
Rep 1,428
02-24-2015, 06:09 PM | #10 |
1688
Rep 3,140
Drives: 2014 M5 6MT
The M3 arms are a known, an well tested upgrade. Im sure poly bushings would be an improvement as well. Maybe the OP can test the deflection of the poly bushings, and post the results.
2014 M5 6MT
02-24-2015, 06:09 PM | #11 | |
21
Rep 232
03-04-2015, 10:06 PM | #12 |
1438
Rep 783
As with the rear suspension arms, the windup of the front suspension arm bushings contribute to the total wheel rate (effective spring rate at the wheel location). I have not tested the OE wishbone and OE tension arm to see how much they contribute to the wheel rate, but I have tested the M tension arm. The M wishbone contributes nothing to the wheel rate because both ends have ball joints.
The method of testing is pretty simple. Hold the bushing in a vice and load with barbell weights: Measure deflection with a caliper: Plot the results: Because I am measuring deflection at the ball joint and not the wheel centre, the results need to be adjusted by the motion ratio of the wheel relative to the ball joint (= approx 16/19). Loads decrease by 16/19 and deflections increase by 19/16. The net effect is a wheel rate due to bushing windup of 5 lb/in using the M tension arm. OE arms together are likely to contribute about twice this wheel rate. CORRECTION: the motion ratio argument is wrong. When the ball joint moves 1" vertically, so does the wheel, so the wheel rate due to bushing windup is actually 7 lb/in, not 5 lb/in. Last edited by fe1rx; 03-06-2015 at 10:25 AM.. Reason: logic error |
cerealwars82.50 |
03-29-2015, 04:24 PM | #14 |
300
Rep 4,040
Drives: 130i coupé ;)
Definitely Sticky material!!
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
04-01-2015, 09:46 AM | #15 |
828
Rep 2,232
Looking at all the pictures and reading about the construction of the front suspension pieces, I am still wondering what could be making the clicking noise in my front suspension. I've taken it to the dealer but they say it's normal. Maybe it is, maybe I'm crazy.
The jist of my issue is that when making a hard right or left turn (used to only be right, hence why I think it may be a worn suspension component), I hear a clicking noise coming from the outside wheel (presumably, could be either). It only becomes noticeable when beyond a certain degree of steering input is generated, as well as only at increases speed (increased load on suspension). Do you guys have any thoughts on what this might be? I was thinking some sort of bearing in the suspension components, maybe wheel bearing. Maybe a ball joint that' worn, I don't know and the dealer says it is normal. |
04-04-2015, 02:06 PM | #17 |
828
Rep 2,232
Could be. The last time my rotors were replaced under BMW maintenance the sound seemed to go away. Any ideas on how to diagnose other than putting new rotors on? Just to be sure that's what it is.
01-21-2016, 08:56 AM | #18 |
1545
Rep 3,071
Thant you fe1rx for you efforts. It is definitely appreciated!
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
07-07-2016, 12:08 PM | #19 |
BMW Fan
290
Rep 838
Quick question: Can we not just press the factory M3 tension strut bushing into the e82 arm and thereby keep the factory geometry for the 135 while gaining the properties of the M3 suspension?
Besides, it's a pretty cheap part when compared to the options. 31102283579 Rubber mounting f pull rod $45.13 |
07-07-2016, 12:26 PM | #20 | |
461
Rep 4,531
You'll just have a stiffer bushing than prior, which probably isn't a bad thing. |
07-07-2016, 04:01 PM | #21 | |
234
Rep 2,643
07-13-2017, 08:19 AM | #22 |
505
Rep 649
Hey Fe1rx, great post, as an Engineer myself I love seeing data about things like this. The one question I have is how much track width does this add?
The reason I ask is I'd like to do this, but I also plan on doing coils/camber plates and want to squeeze as much tire (245 vs 235?) as possible, so my thinking is that camber angles being the same, this mod would actually decrease tire clearance to the fender, as the whole strut assembly would be farther outboard. My other option would be to replace the bushings in the arms and only adjust camber with the plates. From your Ohlins thread, when using a 235/40 on the ET45 wheels, it looks there is more room between the strut and tire, and less between the tire and fender. So my thinking is a 245 would fit better with the OEM arms? Secondary question is: Is static camber the only benefit to this mod, or does it help in dynamic conditions as well? |
