XI on Road course
01-19-2017, 09:11 AM | #46 | |
2470
Rep 9,004
Hear me out for a moment: How can you make such definitive statements of what is 'better' without having a way to substantiate that - it's bullshit. You have literally no evidence outside of brand name, no first hand experience on this platform to make such a definitive statement, and you're upset with me for calling you on it? So tell me again why the OP (or anyone for that matter) should spend $2500 for a kit that objectively might be better by the minuscule amounts, which honestly doesn't matter since OP isn't in competitive racing. |
01-19-2017, 10:21 AM | #48 | |
226
Rep 2,387
Maybe you have a reading comprehension issue. I am making definitive, objective statements about parts that have certain capabilities and features I consider essential to a track car. That cheap coil overs don't have. The (informed) opinion is whether those are important features to have or not, and I freely admit that is an opinion. I do own an XI and have modified it extensively. I don't want to put coil overs on that car. I am happy with a koni/eibach/ZSP set up. And, in case you still can't read, I am NOT recommending OP or anybody else buy coil overs for this platform. I am actually saying don't do it. I am recommending if they still do want to they buy good ones that have capabilities cheaper ones don't, like being rebuildable and (at least) rebound adjustable. And I have recommended lower end coil overs for street use for people who have difficulty getting ride height correct on this specific XI platform because it seems to be so hard for some to get right. If you have some objective measure or direct personal experience that supports your claim that non-adjustable non-rebuildable cheap no-name $800 coil overs are as good as 3k TCK/KW/Ohlins etc. FOR TRACK PURPOSES by all means put it up here. Not getting why you are so cranky esp since I am not even doing or saying what you claim you are so upset about. My 335XI is not a track car, and never will be. It's a pig (4000 lbs) and has an AT. I live at 8k ft ASL my house has seen 10 ft of snow this season already WTF do I need coil overs for? You don't even need coil overs to run drivers schools and I said so. My point is simply if you want them be aware they are tools for people who know how to use them. So make sure you need them and then make sure you understand why. As such buy some good ones. Now being a former serious track junkie, having set up lots of cars, even worked in the industry for years maybe some people might want to hear what I've got to say. Some might not but not getting all the hate. I do own an XI, I am familiar with its suspension quirks and there are a lot of them. It is a big heavy AWD car and if I were to even think about tracking it at much higher suspension loads I'd want a fairly high quality suspension on it. Because my life would depend on it. Literally. Just my preference. Now why don't you tell us which cheap coil over kit you have on your XI and regale us with how well it does after thousands of track miles, and compare it to the expensive coil over kit you also ran for thousands of miles. Oh yeah, and the dyno plots. All 48 of them for the expensive double adjustables, too. Before and after 5000 track miles. Lap times too, cheap vs expensive would help, and notes on all settings. JFC Last edited by ajsalida; 01-19-2017 at 10:38 AM.. |
01-19-2017, 10:29 AM | #49 |
226
Rep 2,387
Where did you get those numbers?
4k = 224 lb/in and 13 k = 728. That latter is pretty stiff for a street car. Are you running coil overs? If not you're going to have to pick something fixed from aftermarket. This is a great thread for spring rates, all really depends on what you want to do and how stiff you can stand. Good discussion of motion ratios and wheel frequencies later on in it. http://www.e90post.com/forums/showthread.php?t=85206 Some numbers from that thread Stock 335i e92: • Front: 145 lb/in • Rear: 460 lb/in Stock M3 e92: • Front: 160 lb/in • Rear: 550 lb/in 335i KW v3: • Front: 260 lb/in (progressive average) • Rear: 570 lb/in 335i KW Clubsport: • Front: 400 lb/in • Rear: 570 lb/in M3 KW v3: • Front: 285 lb/in • Rear: 630 lb/in M3 KW Clubsport: • Front: 508 lb/in • Rear: 800 lb/in |
01-19-2017, 10:37 AM | #50 | ||||||
2470
Rep 9,004
01-19-2017, 10:56 AM | #51 | |
226
Rep 2,387
If you're looking for back to back track tests and dyno plots of cheap vs expensive coil overs, man I don't know where you'd find it outside of proprietary manuf data, which would cost a fortune to produce. Good luck though, not sure why you expect it or are so pissed off it isn't in this thread. Maybe go to a SCCA race prep forum. Manuf and teams tend to guard this data like state secrets though, so good luck with that too. And they won't be testing 1k coil overs. Or even 3k. You might ask one of your fave cheap CO manuf to provide it as a public service. There's a reason why pros pay $10k (and far more) for good shocks. Anyway based on that experience, and bad personal experience with cheap shocks on race/track/street cars, I try to stay away from them and advise others to do so as well. It's an informed opinion, take it or leave it. Last edited by ajsalida; 01-19-2017 at 11:09 AM.. |
01-19-2017, 12:11 PM | #52 | |
2470
Rep 9,004
That being said, I do think there is a difference between a high end coil over and an entry level model - I don't think this is necessary for the majority of people. (Hell, I don't even like 'adjustable') And for the record, many manufactures will provide you with a shock dyno for their off the shelf/revalved products. I remember when one shop was dynoing off the shelf Koni Yellows, and the valving was all over the place, and the variance from shock to shock was huge - compared to something like X brand (BC, Feal, etc) which show their shocks within range and valved appropriately for the spring rate. It isn't as easy as saying X is better than Y. You running away when I challenge you on that proves it - You have a lot to learn (and I do too) |
01-19-2017, 12:12 PM | #53 |
226
Rep 2,387
Putting all this unpleasantness aside, I figured some might not know what a shock dyno is and what it tells you. Here's an example pic of one, they all look more or less the same all though they can be cheap or super expensive with additional features
Basically you have a frame you mount the shock in (without a spring). Frame has a load cell that measure applied force, +/-. There is an electronically (hopefully digitally) controlled hydraulic (or electric) ram connected to the bottom of the shock, with position sensor either internal to the ram or external that measures how far the ram moves, and to help do closed loop feedback control of ram motion to force it to follow programmed wave forms under various loads the shock produces. You send a sinusoidal waveform to the ram, then measure force and position times histories. You differentiate position to get velocity. Since the top of the shock is fixed, position sensor output is shock rod positon relative to the shock and so derived velocity is actual piston velocity in the shock. Then you plot Force vs velocity for the points you have. You get 2 quadrants of data, one for rebound and one for compression dierction. Here's a random sample F-V plot I ripped of some website, various lines in a quadrant are different damping settings: Here's the thing. This isn't like a chassis dyno where you get WHP and can say, oh yeah this or that mod gave me more or less HP so I will be more or less fast. Suspension tuning is a black art and highly subjective. Two different very fast drivers could have identical lap times in the same exact car with wildly different damping settings. I mean it is informative if you know what you're doing and know what you want to do and how shock damping might fit into it, but it is not absolute and there are literally no "objective" data to say this or that damping curve will always make you faster (like a WHP dyno might). And finding somebody who can read one and translate it to repeatedly faster times for a given driver handling preference, that dude makes serious coin on F1, NASCAR, Indycar teams. They always have one shock guy. Usually such a team has a vast number of shocks with carious characteristics, a shock dyno in one of the team semi trailers, and that dude's job is to have dyno charts on all of them, he rebuilds them to spec sometimes, and he provides that data input the other dudes who do suspension tuning for specific tracks, weather, etc. Very big deal but shocks are only one small piece of a giant puzzle at this level. What you really want is repeatable consistent data out of the shocks and evidence of any problems/deterioration, which is what the dyno provides, and then you begin to take notes and impressions of settings for all the tracks and various other tweaks you do for suspension (springs bars etc.). Dump it all into one big database. Like I said most teams this is super secret proprietary and obviously very time consuming and expensive to gather and keep up. A good shock dyno itself is not cheap either. The one I used was a 250k piece of hardware with all the data acq and other stuff. Not chump change, you can get them far cheaper but accuracy suffers. Anyway if you can read F-V curves having them is helpful kind of generally but not so much specifically what to do next. And you're not going to see something like quality differences between low end and high end just off the curves. You might see some goofy stuff at low piston speeds like sticky seals or whatever, you might see big changes with temp as shocks get hot or oil foams in non-monotubes without floating pistons. But by and large you just see F-V. What you do with that is up to you, how much experience you have translating them to your car and whatever track situation you're facing. |
FamilyManTrackSedan111.00 |
01-19-2017, 12:20 PM | #54 | |
2470
Rep 9,004
01-19-2017, 12:23 PM | #55 | |
226
Rep 2,387
You can run bargain basement coil overs on your track car if you want, I just don't recommend it. Lot of other issues besides damping curves, quality of basic tube, valves hardware etc. There may be some new entrants to this field at very competitive prices, I suspect you may be involved in marketing them. That would be great. Why not give us your spiel devoid of all the insults. |
01-19-2017, 12:52 PM | #57 | |
2470
Rep 9,004
http://farnorthracing.com/autocross_secrets18.html |
01-19-2017, 04:03 PM | #58 | |
109
Rep 235
On the other hand, I think you may be going a little over board even though I get what you are saying. |
01-19-2017, 04:17 PM | #59 | |
2470
Rep 9,004
Take a look here: http://www.motoiq.com/Projects/Subaru/AutocrossBRZ.aspx Tested with cheap coils, KW V3s and KW Clubsports. |
01-19-2017, 05:28 PM | #60 | |
110
Rep 1,340
01-23-2017, 10:57 AM | #62 |
109
Rep 235
01-24-2017, 08:27 AM | #63 |
96
Rep 406
Drives: S54/N52
Damn, I am loving it let's keep this going!
01-25-2017, 04:36 PM | #64 | |
Touring cars rock
351
Rep 907
It's not enough for track use but almost ideal on the street. I can get you my corner weights so you can do the math for the other chassis. I'm winning to bet that the e92 front weights are not far off mine, so it's only the rear springs that would matter. Having had the Pros I would say that a better spring is the Eibach ERS linear springs, but they are a bit more $$$
Sportwagon Daily: I've done some stuff.
Julian2485110.00 |
01-25-2017, 05:00 PM | #65 |
Touring cars rock
351
Rep 907
I also wanted to address the hollow vs solid bar point.
Bar rate is what matters here. The thickness of the wall, the length of the lever arm at the various adjustment points, all factor. Measuring thickness is really not telling you much. These are similar bars to the ones we ran on the Porsche Cup car: Swaybars Racing bars usually are available in two or three (or more) wall thicknesses, to allow better rate tuning with the blades. Any fixed bar is a compromise setup which starts with:
etc. I ran different bars at Laguna than I did at Infineon. I can tell you after cycling through about 5 variations of bars that there is a wide difference between bars out there, even with identical dimensional specs. Think metallurgy. The OE bars are not great, for a whole host of reasons. These cars are heavy as shit and plow into corners. My solution has been to deal with the spring rates, get batter dampers and put some rear bar on. It's loose now, but fast. Now I was putting a cup car around the old Daytona road course in about 1:54, before 991's were out, and while not pole fast, it's fast. So I know a bit about getting the car to go. I like it. Your mileage may vary. Here's what a really fast lap looks like, mind you this is a cool 3 seconds faster than my fastest time ever, and this guy has some pedigree.. (and a better setup) but it's still a fun watch:
Julian2485110.00 tetsuo1111227.00 |
01-25-2017, 06:06 PM | #66 | ||
110
Rep 1,340
