335i DSC/DTC OVER SENSITIVE ?????
01-20-2010, 02:43 PM | #23 |
246
Rep 7,690
Drives: 335i SE Coupe Space Grey
wow! interesting thread!....
I have changed my brake discs and pads, all round and when first installed, the computer showed 24000 miles left on them....front and rear...... NOW its showing 19000 Front and 15000 Rear!!! why is the rear pads wearing off quicker? is it because of the DSC? ...in thats the case, then I'll start to switch it off all the time now! |
01-20-2010, 02:45 PM | #24 |
275
Rep 9,218
01-20-2010, 02:58 PM | #25 |
246
Rep 7,690
01-20-2010, 04:00 PM | #26 |
132
Rep 1,898
it is simple. Our cars do not have a limited slip diff. This means the inner backwheel starts spinning quite fast. With DSC on, the brake of the inner wheel will be applied to limited the wheel spin. Power cut is only when you push it quite a bit harder.
01-20-2010, 04:32 PM | #27 | |
6659
Rep 15,858
Like ABS, DSC is a safety system. HighlandPete |
01-21-2010, 01:14 AM | #28 | |
118
Rep 3,866
The car has been driven by the dealer "Master Technician" on numerous occasions and always says "seems alright to me" I have also had both the Dealer Principal & BMW UK Area Technical Manager in the car with me on journeys, but you cannot really demonstrate "lack of throttle response". I have asked for them to drive the car with the "GT1" machine connected to monitor the car, the only comment I get is that it would take two technicians to do this. This would require a technician who can instantly recognise what the machine is telling him (reading between the lines, I am not sure they have someone of this calibre, they only seem to be able to react when being told what is wrong by a fault code, cannot work it out for themselves). |
01-21-2010, 01:22 AM | #29 | |
118
Rep 3,866
This is exactly my point at the average speed recorded, DSC shouldn't even be getting a look in, That is why I am sure there is a fault with the DCS/DTC system, it works far too early. Because of the lack of enjoyment driving this car, I tend not to go far in it now. In the early days it went on 200 mile trips, all types of surface, still had the problem. The performance/throttle response between DSC on and everything switched off is night and day. Last edited by MERLIN335i; 01-21-2010 at 01:31 AM.. Reason: typo |
01-21-2010, 01:25 AM | #30 |
118
Rep 3,866
01-21-2010, 01:56 AM | #31 | |
275
Rep 9,218
That doesn't mean that the DSC has not been active though. It will cut in at relatively low speeds if you are cornering fast enough to brake traction (which on wet greasy icy surfaces could be very low indeed). If anything the DSC light comes on far less on my 335i than it did on my 330i. The system seems to allow far more wheelspin, which is a good thing. The flashing light also comes on less, although I can feel the system working. Switching DSC off does sharpen throttle response on all cars. I would say by around 25%. Is it a greater difference on your car? I also paid attention to the first 25% of throttle travel on my car driving home last night. On my car there is a fair amount of travel at the beginning of the throttle movement, so the first 20% does very little anyway. Beyond that point there is a variance in response as the car begins to accelerate, which seems to depend on the turbos. It's not lag, but it's the only point where you can tell that there is 'something else' contributing to the power. To me it feels like a much reduced version of the 'torque convertor locking up' sensation you get with an auto. I'd say that the difference in response is only 25% or so and only for a VERY short period of time (an instant really). What was different about the other 335i you drove? |
01-21-2010, 08:40 AM | #32 | |
118
Rep 3,866
This problem has existed from day one, the same whether on dry or wet roads. The difference in power/response between DSC on or off, is night & day. Pedal travel seems linear, first 20% just the same as the rest. The other 335i supplied by BMW UK was running the anti waste gate rattle/bad lag V29.2.0 software, also had been stood for eight months, so a waste of time really. I have very latest spec turbos and actuators, with V34.0 software. The more I used it with DSC turned off the better it got (up to a point), obviously the adaption values have now been set, using "turned off" data. I think the excessive pad wear and brake dust on rear wheels (rather than the front) point to a fault with the DSC system (rear wheel speed sensor faulty ??) it is far far too sensitive. Maybe the answer is a LSD, and continue to run with system off. I feel I should say (we know this site is monitored) that I have no doubt of my Dealer Principle's desire to solve the problem, but I strongly question the Service Department's ability to solve it !!!!! |
01-21-2010, 08:50 AM | #33 |
118
Rep 3,866
I find it strange that Tony has not commented on this problem, he is usually fast out of the blocks to help with other 335i problems. I don't see how, but maybe I have upset him ??
01-21-2010, 08:57 AM | #34 | |
268
Rep 9,915
Drives: VW T5
Have you considered using another dealer?
01-21-2010, 09:03 AM | #35 |
118
Rep 3,866
If I take it to another dealer (Battersea or whoever) and as usual it shows no fault codes, the dealer will not be paid by BMW, therefore the dealer will not absorb the cost
as I did not buy the car from them, as he has made no money from me, and I will be charged for the time @ £120+ per hour. I do not see why I should pay, the car is under warranty that has only done 5000 miles and the fault has existed from very early on. |
01-21-2010, 09:19 AM | #36 |
Rep 24
01-21-2010, 09:26 AM | #37 | |
118
Rep 3,866
Have you tried it with DSC/DTC completely off ??? What did you think, is it slightly better or much better as mine is ??? |
01-21-2010, 11:46 AM | #38 | |
275
Rep 9,218
With DSC off is the throttle response 25% / 50% / 75% / 100%? If it's more than 25% then I would say that DSC is DEFINITELY your problem. The next question is if your DSC is actually broken or if you just don't like it. The only way to understand that is to drive it back to back with another car. I've asked a couple of times about the 335i you drove. Just saying it was a waste of time is again not very descriptive. Did you perceive any similarity with your car in terms if throttle response / DSC intervention? Was it totally different? Was the difference between DSC on and off as pronounced? |
01-21-2010, 01:45 PM | #39 | |
246
Rep 7,690
Throttle response for me is the same.....but then again, its town driving with traffic.... I will switch off the DSC/ DTC completely and start testing throttle response from now on! and you can get me a beer at the next UK meet!!!.... But, so far every time I've switched off the DTC the car "feels" faster when accelerating from standstill (maybe its just in my mind...i may be wrong...) but i'll pay more attention now and will let you know.... theres so many factors to consider though when testing these kind of stuff....(gear selected DS , D or M , road surface, hill gradient etc....I found that a slight uphill, really triggers my orange light!!!! ) |
01-21-2010, 01:51 PM | #40 |
246
Rep 7,690
01-21-2010, 02:10 PM | #41 |
91
Rep 2,079
ive not notced the throttle response tbh. will look out for this next time tho
however do realise how much work the DSC does its job tho as on the idrive the front pads apparently have 45,000 miles left in them when the rear have 14,000 |
01-21-2010, 04:06 PM | #42 | |
Moderator
324
Rep 5,493
2 Entertaining 'dancing friends' 3 More busy Perceived DSC issues are very common during winter months, because the differences between DSC activation and non-activation are so much more pronounced. As has already been said, the DSC system is almost constantly working to control the back wheels and to prevent loss of traction, in either the linear axis (as in direction of travel) or in the transverse axis (side to side motion). The DSC's first option is to selectively brake one or more wheels in order to minimise wheelspin. If this is not sufficient, the DSC system will then progressively shut down the throttle to reduce power until suitable grip levels have been regained. In the current weather conditions, the DSC system will always work more than during warm summer months, and because of this greater intervention the difference between throttle response with DSC on and off is much greater, and hence more noticeable to the driver. There is another element that shouldn't be overlooked - throttle adaptations of the car. The car learns how the driver uses the throttle, and if it senses that the driver demands a more aggressive throttle application under normal driving conditions, the ECU will adapt accordingly and deliver more go with less pedal travel. This therefore means that power delivery is more sudden, and this can have an effect on DSC activation, especially when the weather is how it is now. It could be that your car is electronically aggressive with throttle application, and the DSC is having to intervene in a more active fashion, hence why you feel that there is a poor response. Ask your dealer if they would reset the ECU adaptations - it's an easy process and might alleviate some of the issues you are experiencing.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
01-22-2010, 01:22 AM | #43 | |
118
Rep 3,866
Throttle response is around 50% better with DSC off. With the back to back car, because it had bad lag problems (software) it was hard to know whether it was that causing the bad throttle response or the bad response was down to DSC intervention. Turning the DSC on/off made very little difference, but lag may have influenced this. To do a true back to back, the cars need to be identical, the car provided was the only manual in BMW UK stock at the time, but with the different turbos and software, it was never going to be a true comparison. The continual varying throttle response really messes with my head, I need to know what I will get when I press it. |
01-22-2010, 01:30 AM | #44 | |
118
Rep 3,866
Sorry didn't realise your's was and auto, so no doubt it will be different. Buying Beer, driving home, TUT TUT !!! |
