BMW M2 Forum > BMW M2 Discussions > Weird Rattle / Tick when AC is turned On - N55 M2 6MT
      08-21-2023, 07:32 PM   #1
CB2001
CB2001's Avatar
Drives: BMW M2 (2017)
2017 OG/N55 M2 6MT W/ 29K Miles. I get this weird tick when I turn my AC on / idle gets a little more grumbly, but wouldn't call it rough. I noticed by tensioner has a little play in it. I thought it sounded almost like a knock at first but
-it appears to come from the front of the engine where the belts/pulleys are.
-doesn't increase with revs like a knock, the sound subsides under load. Tensioner appears to have less play under load too.
-noise only occurs when AC is on. Hot or cold.
-oil filter / housing is clean (no glitter).
-no current engine codes.
I just did a 2,000 mile road trip with some "spirited" mountain driving, and noticed the noise at a red light with my AC on low and windows down.
Video 1 - in car turning on AC, can hear noise come on just as I push the button.
Video 2 - outside car, warm idle with no AC
https://drive.google.com/file/d/14nh...ew?usp=sharing
https://drive.google.com/file/d/1rir...ew?usp=sharing
Any advice is greatly appreciated. I plan on starting with the Accessory belt, tensioner, and idler pully and see if the problem persists.
      08-23-2023, 08:18 AM   #2
7tune
7tune's Avatar
117
Drives: 2017 OG M2
Honestly, it sounds to me like the AC compressor. It may be rusting on the surface (or within the bearing assembly) and that grinding sound you're hearing is the pulley but only active and doing that when the AC is on. It doesn't sound like that when it is off, right?
Mine is doing the same and you can actually see really fine powder like specs of rust on the chassis where it is corroding and throwing off when the compressor is engaged and disengaged.
How many miles on this compressor?
      04-30-2024, 06:50 AM   #3
haarreh
Drives: 2013 328i xDrive
Did you end up repairing your AC Compressor? I haven’t started too much research yet but I think mine might be going out as the engine starts rumbling when the AC is turned on. Hope it’s just the compressor but I also noticed a leak at the AC Refrigerant Suction Hose 9217375.
      05-09-2024, 06:22 AM   #4
CameronBurton
Drives: mustang 1969
Have you repaired it, how is everything going? I am waiting for your response. And till then I will look for reviews online at https://boomessays.com/ website where I found professional essay writers. But I always read reviews online before getting help from someone. Because it helps me in trusting their service. And yes, if anyone can help me in searching for a site online where i can find reviews of that website, then I will be so happy and I will appreciate you.
Edit: Thanks for replying.
      05-09-2024, 08:31 AM   #5
CB2001
CB2001's Avatar
I replaced the harmonic balancer and drive belts/pulleys. It completely removed the ticking noise. So far so good.
m2
