      04-22-2012, 09:50 PM   #89
IancoleTX
Dillo boxers
IancoleTX's Avatar
272
Drives: 2019 M5C
Originally Posted by MaC-N54-E82 View Post
Thanks AndyM..... Less than 30 minutes start to finish.
Ditto, props to OP
2019 M5C Matte MBB / Tartufo
      08-24-2012, 10:58 PM   #90
adevangel84
adevangel84's Avatar
19
Drives: 2006 E46 M3 (RIP)
Hey guys, I am not having any power on my radar detector. I tapped my wire on the green/white wire on the connector with the arrow on it on this DIY. I looked at the wire and it looks like it is tapped correctly but no power still. Please let me know if I have the right wire. Thanks.
      03-23-2013, 02:19 PM   #91
chiefsalami
11
Drives: 2022 X3 3.0i M-sport
Looks like I'm having the same issue. No voltage on that green/white wire, whether ignition is on or off. I have a 2012 135i. Does anyone know what that connector is for? Is there a fuse for it that I might have blown while tapping this power wire?
EDIT: Turns out the wire tap provided by the hardwire kit did not work for the job. It's designed for a larger gauge wire, and therefore was not even breaking through the wire insulation. I used a different wire tap and got voltage. But be aware that the connectors all need to be PLUGGED in before battery voltage is supplied at the green/white wire. Works now!
Thanks for the write-up guys. Especially the removal of that map light assembly. It's a bitch!
      04-28-2013, 09:25 PM   #92
Nose Nuggets
Drives: 2016 M235i
I performed this install in my 2013 135 and it works provided i don't use the sunroof. But if i open or tilt the sunroof it loses power. Provided the root is closed, everything works great. Also, while the roof is tilting or opening the radar detector turns on and off very rapidly, like the power current is pulsing. once the roof has stopped opening and is open, the radar detector stays off. as soon as the roof is closed, it works normally again.
any ideas? i performed a similar install in my '10 328 and did not have this issue with the sunroof.
      05-13-2013, 12:30 PM   #93
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
I have a question. I don't have a sunroof, so where can I ground? I don't have any bolts by the map lights
      03-22-2014, 06:34 AM   #94
Mortify
Drives: 2008 135i m sport
This install took me about an hoir ! Mostly because I was scared to damage the headliner, but everything went in dandy, thank you for the diy!
      08-04-2015, 04:22 PM   #95
Venoml2k
Drives: 135i
Additional Information regarding the clips:
This thread on e90post may help in showing the tabs better than I explained.
Thank you for this link. My factory mic had been unplugged when I bought the car and this assisted me in finding the issue.
Bumping it to make it easy for others to find when installing or replacing mic.
Issue was I could hear callers, but they could not hear me.
      08-17-2015, 03:20 PM   #96
XAMI
XAMI's Avatar
12
Drives: 135i
Thanks for the great write-up, hardwired mine today without any problems.
      08-05-2017, 12:52 PM   #97
traintrax
Drives: 2012 135i Marrakesh Brown
I know this is a necro post but did anyone who did this DIY have any issues with the SOS system? Ever since I did mine and used the green/white wire as described I get an SOS system failure warning when I start my car. If I disconnect the radar detector, I don't. Thanks
      08-06-2017, 04:58 PM   #98
tock172
Beachtown Bill Collector
tock172's Avatar
582
Drives: 2012 135i
2012 BMW 135i  [0.00]
1999 Lexus LS400  [0.00]
1985 BMW 325e  [0.00]
I had an issue with power interruption to m V1 when operating the sunroof. I ended up running a fuse block tap and wiring my radar detector that way.
2012 BMW 135i Space Grey Metallic M-Sport DCT Dinan S2
1addicts
