F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > UK - Off Topic > Any toilet flushing experts here?
ARMA SPEED
      03-13-2024, 12:40 PM   #1
Rbrown
Scotland
2766
Drives: X3 M40i
Sorry. Not a post for reading when you are eating.
Having a funny issue with our toilets. Flush works. Human waste goes away. But toilet paper floats back. Happening in 3 toilets (upstairs and downstairs).
I have tried different toilet rolls and still happens.
Wondering if it’s some some of blow or further down the line. But confused why it’s only toilet paper coming back (not that I’m complaining).
Have plumbing cover with British Gas, so can get them up.
Just wondering if any of you guys have any ideas.
Thanks in advance
      03-13-2024, 12:53 PM   #2
Pond
1836
Drives: E89 Z4, F31 and Z3 project
As it's affecting multiples WCs I would look at your SVs (soil pipe vents). If you have open vents, ie at the top of the stack, check they (it) aren't blocked by birds nesting materials etc. If you have AAVs (air admittance valves, or Durgo valves) internally check they are not stuck.
WCs create quite a vacuum when 6 odd litres of water are thrown down them at once. This is what helps to get rid of the 'stuff'. The vents are there to allow air in to compensate for the 'suck'. If a vent is even slightly blocked, your scenario is common.
Our downstairs WC does the same, to a small degree, because the clever plumbers didn't put any vent in at all when the house was built!
Rbrown2765.50
      03-13-2024, 12:54 PM   #3
Eddamoo
391
Drives: BMW 430dX
If the toilets aren't draining as fast as usual, the soil stack could potentially be blocked.
Has it gotten worse over time? Maybe they are just poorly designed toilets or flush mechanisms?
Rbrown2765.50
      03-13-2024, 01:35 PM   #4
Rbrown
Scotland
2766
Drives: X3 M40i
Thanks. It has just got worse.
Think I will get DynoRod out. I have cover so no harm in letting them see it.
Many thanks for coming back.
      03-13-2024, 02:57 PM   #5
EvilDrPorkChop
EvilDrPorkChop's Avatar
951
Drives: Porsche Cayman
Are they all the same style/brand of toilet?
Rbrown2765.50
      03-13-2024, 03:02 PM   #6
Rbrown
Scotland
2766
Drives: X3 M40i
2 are the same. The other one is different.
      03-13-2024, 03:04 PM   #7
EvilDrPorkChop
951
Would suggest maybe an issue with the waste pipework then. Do they all drain into the same stack, or are they different sides of the house?
I would possibly lift a manhole cover up outside and see if it's easily done. Then flush one of the toilets and see if it comes through OK.
      03-13-2024, 03:15 PM   #8
Rbrown
Scotland
2766
Drives: X3 M40i
Think they are on different stacks. May be a problem further “downstream”!
I have arranged for DynoRod to come out on Monday. I will also have a look tomorrow in daylight.
Appreciate the help.
Many thanks.
      03-14-2024, 03:44 AM   #9
GOF_430d
289
Drives: 430d convertible
Having had a similar problem last year, I discovered that my neighbours were too having an issue and after lifting the cover to the interceptor which is on my drive, noticed that the pipe was backing up. Complained to Thames Water and the following day they cleared the blockage and now everything flushes away.
Rbrown2765.50
      03-25-2024, 12:40 PM   #10
EvilDrPorkChop
951
What was the issue in the end then Rbrown?
Rbrown2765.50
      03-25-2024, 02:50 PM   #11
Rbrown
Scotland
2766
Drives: X3 M40i
Had dyno rod round today.
Took ages to get them out as dyno plumbing had to come out first.
They think it was a partial blockage. Did a clean out of the pipes. All the pipes etc looked ok. Hoping it sorted now!! 🤞
f30post
