Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > COBB AP stuck "identifying vehicle"
      12-09-2012, 02:36 AM   #1
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Trying o load a updated BMS backend flash and it just says "identifying vehicle" and at bottom communicating with ECU (evidently it is not lol).
I updated AP firmware and ignition is in the on position...any ideas?
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      12-09-2012, 02:49 AM   #2
nitehawk
nitehawk's Avatar
102
Drives: e92 335i 6MT
Recheck connections and that you're in IG2. Otherwise should work...
      12-09-2012, 02:53 AM   #3
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I forgot the JB4 has to be on map "0" lol!! why did it load so fast, 1st time it took 20 mins easily? If I want install a updated flash map from BMS do I have to uninstall the first one I loaded....99% sure that it s not needed but want to be sure lol!!
      12-09-2012, 09:55 AM   #4
nitehawk
nitehawk's Avatar
102
Yeah, you can just flash over it, which will be much faster than the first time you do the install, as the AP only needs to update the parameters that changed
      12-09-2012, 12:20 PM   #5
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Pretty awesome system, when it was updating car was making all kinds of noise lol!!!
