BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Fog light to DRL conversion - Error
proTUNING Freaks
      08-11-2013, 11:19 PM   #1
kon
Singapore
21
Drives: F30 310i > G20 310i
Somebody I knew went to replace their fog light with a set of DRL, and the fog light is throwing out error on dashboard. The fog is gone, but a set of DRL is now mounted, and a separate switch is used to activate/deactivate the DRL
Anybody with experience on how to code out the error?
I'm thinking of removing the fog light option from FA, [61] 520_FOG_LIGHTS
But since I'll be sometime before I get hold of the car to code it, I thought of hearing out other options/recommendations.
      08-12-2013, 12:06 AM   #2
kon
Singapore
21
Found this
http://www.f30post.com/forums/showpo...84&postcount=6
Originally Posted by 1lyfe View Post
If you know someone who can code locally these are the codes you need to turn off your fog error check
FEM_BODY -> 3061 -> NSW_L_KALT -> NICHT_AKTIV
FEM_BODY -> 3061 -> NSW_R_KALT -> NICHT_AKTIV
FEM_BODY -> 3061 -> NSW_L_WARM -> NICHT_AKTIV
FEM_BODY -> 3061 -> NSW_R_WARM -> NICHT_AKTIV
      08-14-2013, 05:51 PM   #3
Chris@codemybimmer
BimmerPost Supporting Vendor
Chris@codemybimmer's Avatar
171
Drives: AW F30 328i Xdrive
you can also just jam in resistors into the sockets
as long as you dont accidentally push the fog button it should be fine
      08-14-2013, 08:11 PM   #4
kon
Singapore
21
Sound dangerous... I'm sure someone someday will definitely press the foggy button
