BMW
X7 and XM
forum
BMW X7 (G07) Forums General BMW X7 Forum X7 Center Jack Points?
      05-02-2022, 07:36 AM   #1
Buzzard59
Buzzard59's Avatar
17
Drives: 2021 X7
BIMMERPOST
     Featured on BIMMERPOST.com
Where are the points to place your jack on your X7? I found one near the tire where you can use a bottle jack if I want to use a regular floor jack, I don't see any good location to place the jack.
      05-02-2022, 07:53 AM   #2
MystroX5
MystroX5's Avatar
6290
Drives: 2020 X7 M50i/ 911
I use these Jack pads in all 4 corners when swapping my wheels around with a 4 ton floor Jack. I do one corner at a time. Takes me maybe 20 minutes….
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      05-02-2022, 09:26 AM   #3
Buzzard59
Buzzard59's Avatar
17
Drives: 2021 X7
Very nice! Where do you place these pads under the vehicle? I was able to use a bottle jack that fit inside the jack point, however, I can't use that point with a floor jack. I wasn't able to find many points because most of the undercarriage is covered. If you can point out the locations where I can place my floor jack and stand I would really appreciate it.
      05-02-2022, 09:44 AM   #4
MystroX5
MystroX5's Avatar
6290
The Jack points are in the manual. They’re are those plastic square grid protrusions at each corner. Their is a slot cut out in the middle of the plastic square for the jack pad to link into.
Here is a thread on wheel swapping I did awhile back.
https://g07.bimmerpost.com/forums/sh....php?t=1773941
      05-02-2022, 10:22 AM   #5
bagekko
bagekko's Avatar
815
Drives: Lots of BMWs
2018 M4 Vert  [0.00]
2006 Z4M Roadster  [0.00]
1995 540i  [0.00]
2008 BMW M5  [0.00]
2019 i3 Rex  [0.00]
2021 X7 40i MSport  [0.00]
I bought a bunch of these ages ago when I don't think anyone else made them.
https://reverselogic.ecwid.com/BMW-MINI-c4591507
ECS now sells them
https://www.ecstuning.com/b-ecs-part...pter/ecs10721/
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX
2021 X7 40i MSport, 2006 Z4M 6spd
      05-02-2022, 02:39 PM   #6
Buzzard59
Buzzard59's Avatar
17
Drives: 2021 X7
Thanks a lot for the information, this was very helpful. I ordered them through Amazon, my X7 didn't come with anything, not even a spare tire. I eventually found a center point in the center where the engine is where I could use the floor jack. Does the X7 come without a jack and spare because of the run-flat tires? Do you have to turn off the air suspension every time you take off a wheel or have the SAV on a jack? Is that just for safety reasons or for something specific?
      05-02-2022, 02:43 PM   #7
PinkNinja400Guy
506
Drives: '22 X7 M50
Spare tire was a $150 option. Your must have not had it. The stock tires are runflats regardless of whether you have the spare. So the spare isn't really of any use unless you're planning on going way out into the middle of nowhere.
Also if the TPMS detects a flat tire, the air suspension will adjust on all four corners to take weight off the flat one and put more weight onto the other tires. That makes life a bit easier for the flat RFT. Pretty cool.
      05-02-2022, 02:54 PM   #8
Buzzard59
Buzzard59's Avatar
17
Drives: 2021 X7
Now that's something cool, I like it when you use the sports mode and the X7 lowers itself. The reason why I needed to jack the truck was that I scratched the wheel and wanted to get it repaired. When I get the wheel back, should I do anything specific to make sure everything goes ok? I know I have to torque them to 101lbs ft/140Nm and tighten them using the diagram. I turned off the air suspension so once the wheel is on I'll turn it back on.
      05-03-2022, 11:55 AM   #9
jmciver
///M SubDriver
jmciver's Avatar
1837
Drives: 2017 M3, 2020 X7 40i
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
2009 BMW 128i  [0.00]
I would not jack up the X7 from under the engine as I don't remember seeing a center jack point under there the last time I looked (and I don't remember seeing a center jack point described in the manual). Not all vehicles have a center jack point under the front subframe (e.g. under the engine). Just use one of the 4 factory jack points along the sides. While the BMW jack pad adapters are nice, they are not necessary if your floor jack has a nice, flat surface that will fit properly on the factory jack pad. I use the jack pad adapters sometimes, but don't if I get a bit lazy….
Also, you don't need to disable the air suspension to change a tire. After you finish changing your tire, the air suspension should reset itself within a few minutes of driving. This was my experience when I recently removed a wheel/tire to plug a slow leak from a screw I picked up.
You can see where I put my jack in the picture below (bottom right corner of pic). The other pic is what the factory space saver spare looks like if you wanted to retrofit a kit…
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's)
      05-03-2022, 03:47 PM   #10
x7bmw23
x7bmw23's Avatar
282
Drives: 2021 BMW X7 40i M Sport
Use jack pads. Same thing happened to me. Amazon one day delivery to the rescue
      05-05-2022, 08:26 PM   #11
Buzzard59
Buzzard59's Avatar
17
Drives: 2021 X7
It was an area in the center of the steel frame right between the front wheels that weren't covered by any plastic.
      05-07-2022, 05:42 PM   #12
Qsilver7
Qsilver7's Avatar
4448
Drives: F06 650ix GC / F15 X5 50i
BMW TIS:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
jmciver1837.00
      05-22-2022, 09:34 PM   #13
Buzzard59
Buzzard59's Avatar
17
Drives: 2021 X7
Thanks for the diagram, that's where I placed the jack, (point 1), it was metal.
      05-24-2022, 01:37 PM   #14
Qsilver7
Qsilver7's Avatar
4448
      12-07-2023, 09:19 AM   #15
classic_erik
classic_erik's Avatar
2809
Drives: 23' X7 40i M Sport
Originally Posted by Qsilver7 View Post
BMW TIS:
Can someone clarify the #3 rear axle jacking point? Has anyone use this rear point in order to get the rear up on jack stands? I assume that warning on the TIS guide just means to avoid the differential cover that is right next to the jacking point? Does anyone have actual photos of exactly where point #3 is?
      12-07-2023, 10:05 AM   #16
Qsilver7
Qsilver7's Avatar
4448
You can lift the entire rear axle by lifting on the rear diff…and as noted…make sure there is no pressure on the diffs COVER. The rear diff is supported very well within the rear subframe assembly(aka rear axle carrier)…so there shouldn’t be any issues using the rear diff. You can also do a google search for pics of BMW owners using a jack/lift and where they placed it on the rear diff. This topic has been discussed for decades.
Here’s an illustration of the rear axle carrier to which the rear diff is attached. You can see how the weight is distributed and not just focused on the rear diff and axle rods alone:
Don’t forget to chock the wheel(s) on the opposite end being lifted…especially when lifting the entire rear axle. The front wheels have no parking brake or tranny park pawl to prevent the vehicle from moving forward when the rear axle is lifted.
      12-07-2023, 10:28 AM   #17
classic_erik
2809
Here’s an illustration of the rear axle carrier to which the rear diff is attached. You can see how the weight is distributed and not just focused on the rear diff and axle:
Incredibly helpful. Thank you!
xbimmers
