05-05-2024, 10:19 AM | #1 |
142
Rep 257
Fluid exchange: Diff, TC, oil, + plugs
Planning to tackle front/rear differentials, transfer case, engine oil/filter, and spark plugs on 40i next weekend.
While car only have 24k miles on it, I figured the fluid enhange should be quick, easy, and a good preventative given how many posts I’ve seen about these big items shitting the bed early on the X7 - especially being they only hold 6-800ml of fluid. Any tips or tricks worth mentioning? I’ll circle back with my results. Ordered OEM parts, fluids, and drain plugs from FCP. About $500 in parts but still less than an extended warranty and should hopefully help with long term durability. |
05-05-2024, 12:39 PM | #2 |
Rep 8
[QUOTE=Madsen203;31127674]Planning to tackle front/rear differentials, transfer case, engine oil/filter, and spark plugs on 40i next weekend.
While car only have 24k miles on it, I figured the fluid enhange should be quick, easy, and a good preventative given how many posts I’ve seen about these big items shitting the bed early on the X7 - especially being they only hold 6-800ml of fluid. Any tips or tricks worth mentioning? I’ll circle back with my results. Ordered OEM parts, fluids, and drain plugs from FCP. About $500 in parts but still less than an extended warranty and should hopefully help with long term durability. I'm getting ready to do this on my 40i with 50k on it. I'm hoping it's similar to my past X5, which was pretty straightforward. |
05-05-2024, 12:54 PM | #3 | |
142
Rep 257
[QUOTE=dannyb89;31128003]
Probably excessive to do it this early, but it’ll give me an idea of how the fluids hold up long term. |
05-05-2024, 01:01 PM | #4 |
150
Rep 177
It certainly doesn't hurt to do it early, I'll likely do it at 25k miles as well. I've said it before in another thread but my TRX was known to be severely underfilled from factory, and when I did it at 1k miles that was indeed the case.
Here's a thread with some tutorials that might be helpful. |
admranger2999.50 |
05-05-2024, 01:14 PM | #5 | |
142
Rep 257
05-06-2024, 01:30 PM | #6 | |
158
Rep 97
05-06-2024, 02:37 PM | #7 | |
142
Rep 257
I should tackle this either this weekend or next. Given it’s Mother’s Day weekend, not so sure this weekend will pan out. |
05-07-2024, 08:22 AM | #8 | |
Rep 16
05-07-2024, 08:25 AM | #9 | |
191
Rep 299
05-07-2024, 08:49 AM | #10 | |
142
Rep 257
chicagox7191.00 |
05-07-2024, 07:03 PM | #11 | |
Retired Curmudgeon
3000
Rep 4,075
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
05-11-2024, 07:10 PM | #12 |
142
Rep 257
Update 1:
Did rear differential today. Pulled out 700ml of fluid (which was dark brown/black) and put in 1L. Still not full. This matches others who said the diff and TC’s come under filled. It seems it could still fit another 500ml easily. Going to order another bottle of OE fluid and put it in until it’s filled after it arrives. Maybe tomorrow I’ll tackle the front and TC. |
05-11-2024, 10:02 PM | #13 | |
142
Rep 257
ledphut227.50 |
05-12-2024, 05:03 PM | #14 |
142
Rep 257
Worked on transfer case today. Was able to get about 200ml out. I used the oil change service function in iSTA but it didn’t seem to move the piece that is in the way of the fill port meaning I was only able to get my 1/4” fill hose partway into it leaving a substantial amount of old fluid in there. At the least, I was able to swap 30% of the fluid and ensure it was topped off. Also reset the adaptions.
Any tips for getting my small hose into the TC to suck out the old fluid? Fluid looked pretty bad after only 24k miles. Hoping to attempt this again tomorrow with more luck and swap the fluid again. Accessing this isn’t too bad even with the TC support beam installed still. |
05-14-2024, 07:00 PM | #15 |
142
Rep 257
Finished doing the front today. Pain in the ass but mostly because I did it when the motor was still hot. Fluid was dark as I anticipated. Put fresh plugs on and buttoned it up. Likely won’t touch it again until 50k.
With monkeying around accessing full plug, getting diff oil in eye having to flush it, and cleaning up, took under an hour total. |
05-15-2024, 02:41 PM | #16 |
142
Rep 257
Last item: swapped spark plugs. Took 45 minutes and that’s with following proper torque protocol for plugs and coils. While really early, if this offsets a coil failing in the future, it will have paid for itself. I’ll check gap later to see if any changes. Visual Condition was OK with no concerning signs.
Just picked up a Quinn digital torque wrench. Excellent wrench. Much better than the digital Sata I tried. |
admranger2999.50 |
05-15-2024, 04:21 PM | #17 | |
142
Rep 257
I switched from OE plugs to NGK. Very happy and worth the $100. |
admranger2999.50 |
05-15-2024, 04:43 PM | #18 | |
Retired Curmudgeon
3000
Rep 4,075
Appreciate the write up! Is it pretty much 2 bottles of rear diff fluid, 1 bottle of front diff fluid and 1 bottle of transfer case fluid to complete the changeout?
05-15-2024, 04:48 PM | #19 | |
Retired Curmudgeon
3000
Rep 4,075
Madsen203142.00 |
05-15-2024, 05:00 PM | #21 | |
142
Rep 257
2 bottles for the rear TC fluid came as a 1 liter bottle. I think I’ll attempt pulling fluid again in the future. Maybe each oil change I’ll swap out some of the fluid. Doesn’t take long and will ensure there is some fresh fluid diluting the old. Other write up’s say 700ml |
admranger2999.50 |
05-16-2024, 08:26 AM | #22 |
142
Rep 257
Also changed oil (5k since last factory change). Motul oil + OEM filter.
Now I won’t need to touch anything for 10k as the next oil change is on the dealer. Funny the computer indicated 10k miles until next oil change (just changed from 11k last week) after 5k since last OCI. While there’s has been considerable highway driving, no way would I got 15k intervals on a turbo charged motor with 0-20w oil. |
admranger2999.50 |
