09-24-2012, 09:36 PM | #23 | |
Moderator
675
Rep 4,737
Let me know if you need help... I am local now |
03-06-2013, 06:12 PM | #25 |
30
Rep 1,789
How does the dealer verify the fluid level?
03-06-2013, 06:24 PM | #26 |
78
Rep 684
Same as step 7. They are able to more accurately read the transmission temp. via their computer.
03-06-2013, 07:07 PM | #27 |
30
Rep 1,789
Would the transmission temp differ much if the fluid were low?
I was hoping I wouldn't need a pyrometer if the car was completely cold. Pricey fluid though. With the car getting older, maybe we can have some local tech days in the future. The 20L bottle should be able to cover at least 3 cars....making it pretty economical. |
03-06-2013, 07:10 PM | #28 |
30
Rep 1,789
It's interesting that a quick google search shows of a few selections of fluid for the evo x sst transmission. I'm guessing if BMW didn't make it a lifetime fluid, we'd have some good threads/selection on the subject as well.
06-07-2013, 04:11 PM | #30 |
70
Rep 954
One minor thing I'd suggest is opening the fill plug first. You might end up with a slight mess, but that ensures you'll be able to refill your fluid.
It would suck to drain it and then find for some reason your fill plug is stuck. |
Chewo3.00 spammysammich1604.50 |
06-10-2013, 03:08 PM | #31 |
3956
Rep 3,994
Has anyone used Fuchs Titan DCTF??
It looks like it's recommended for BMWs, although they list it as Drivelogic 7 Speed, as well as the Mitsu TC-SST which seems to take the same fluid. It's almost too cheap, which is why I ask. 5L for $80, that's $16/L, less than half what I can get the Pentosin for. http://www.generaloils.net/PI_TITAN-DCTF_e.pdf |
06-11-2013, 06:21 PM | #32 |
O! So Sour!!
552
Rep 15,615
Drives: Fast 240z / Slow M3
is there any bleeding of any lines involved?
06-13-2013, 09:12 AM | #33 |
3956
Rep 3,994
06-13-2013, 01:24 PM | #34 | |
///M
161
Rep 1,867
step 1: Drain fluid (good idea to loosen the fill plug first) step 2: fill fluid until it starts to come out, tighten and start the car rev and hold at 2k for a bit step 3: fill fluid again until it comes out and your done!
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI |
06-14-2013, 02:35 PM | #35 | |
3956
Rep 3,994
Any thoughts on this stuff? |
06-15-2013, 02:13 AM | #36 |
78
Rep 684
Nope. It's just like changing engine oil.
09-05-2013, 12:27 PM | #37 |
3956
Rep 3,994
Changed mine this past weekend. Didn't have any issues just wanted to change it, everything feels the same no negative effects (seems like i didn't screw it up).
Old vs. New
09-05-2013, 12:50 PM | #38 |
26
Rep 767
+1
At what point did you do this? Mileage and age of the fluid? Maybe I missed it.
2019 McLaren 720s / 2018 Lamborghini Huracan Performante / 2019 Porsche Macan Turbo / 2016 BMW M3/// IG @jon.hagerty
09-05-2013, 02:08 PM | #39 | |
3956
Rep 3,994
ECS recommends every 40k for some reason. They have a kit here: http://www.ecstuning.com/BMW-E92-M3-...ion/ES2677651/
09-05-2013, 03:00 PM | #40 |
64190
Rep 24,857
Have mine done preventive at 50,000 km(31,068 miles) by my BMW dealer !
But only with the best DCT fluid and recommended by BMW . The OP part nr of the DCT fluid is ok for the US,in Europe we have other part nr but the fluid is the same ,brand name is Pentosin FFL-4 ,this DCT fluid is also used by Porsche and is actualy the best fluid for our DCT But one thing i know is.....Pentosin is $$$ When i get another 30 K miles i do the same thing...DCT fluid change ! Links to Pentosin........... http://www.oilprofi.by/netcat_files/...L-4_V6_GB_.pdf http://www.crpindustries.com/pentosi...osin_FFL-4.pdf http://www.fcpeuro.com/products/bmw-gear-oil-ffl4
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
09-05-2013, 03:17 PM | #41 |
///M
161
Rep 1,867
how many bottles did you need to do the fluid change? I',m planning on doing it soon.
09-05-2013, 06:04 PM | #42 |
1580
Rep 8,077
Drives: 11 E90 M3 Individual
I wonder if you can disconnect the feed and return lines from the cooler in the bumper. Just put the feed line into a drain pan and put the return line in a big container of DCT fluid. The DCT pump should dump the old fluid out as it goes to the cooler and then pump in new fluid from the return line. Then you'd probably need to add some more afterwards to account for the volume in the cooler.
That would be really easy.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
Harryc99.00 |
09-06-2013, 08:19 AM | #43 |
3956
Rep 3,994
I used just over 5 liters, I bought 6L and it was enough.
09-06-2013, 12:06 PM | #44 |
///M
161
Rep 1,867
Pentosin FFL-4 are the same as if we buy it from the dealer right?
