BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
Mporium BMW
      08-24-2022, 10:44 PM   #1
Theodore
Theodore's Avatar
673
Drives: 2011.5 E92 M3
E9X M3 BMW "Factory" Tools
Appreciate 3
      03-24-2024, 06:49 PM   #2
Theodore2
44
Drives: E92 M3
This is a work in progress, please feel free to add to the list or post a photo or video.
Common Maintenance Tools:
83300491129 (BMW Tool # 121171) - S65 Spark Plug Socket
- 83300496565 (BMW Tool # 135160) - Fuel Line Disconnect Tool
83300493647 (BMW Tool # 813010) - Hood Prop Rod Set
- 83300496274 (BMW Tool # 119980) - Coil Pack Removal Tool
- 61432358315 (BMW Tool # N/A) - Smart Battery Charger = CTEK 56-864
83300495794 (BMW Tool # 172050) - Hose Plier Tool
(No image yet)
83302339646 (BMW Tool # _______) - Cable Crimping Tool
Suspension Tools:
- 83300496293 (BMW Tool # 315230) - Front Strut Pull into Steering Knuckle Tool (Includes BMW Tool # 315231 (83300496294) Body, BMW Tool # 315232 (83300496295) M10 with spindle and fixture, BMW Tool # 305233 (83300496296) Nut/bearing)
- 83300491931 (BMW Tool # 312210) - 21mm Top Strut Socket = Hazet 2593-21
- 83300491930 (BMW Tool # 312200) - Strut Sleeve Spreader
83300496388 (BMW Tool # 330100) - Rear Trailing Arm Bushing Alignment Tool
83300494928 (BMW Tool # 334450) - E9X M3 Tension Rod Strap Set
83300496355 (BMW Tool # 315270) - E9X M3 Tension Rod Bearing Tool (used in conjunction with the tension strap set (83300494928) for pressing the bearing of the tension rod in and out.
Body Repair Tools:
- 83300494363 (BMW Tool # 513250) - Outside Door Handle Removal Tool -
83300496058 (BMW Tool # 510320) - E92 and E93 only Window Alignment Tool
(No image yet)
81490443166 (BMW Tool # _______) - Pneumatic Dispenser for Carbon Fiber Roof Adhesive = Cox PPA300A
83300496315 (BMW Tool # 413200) - Clamp Set for Gluing Carbon Fiber Roof to E92 (includes BMW Tool # 413201 (83300496201) Locking pliers, # 413202 (83300496317) G clamp, # 413203 (83300496318) Preformed sections, # 413204 (83300496 319) Preformed sections)
(No image yet)
Transmission and Differential Tools:
83300496583 (BMW Tool # ______) - DCT Clutch Pack Cage Removal and Installation Tool
83300496388 (BMW Tool # 330100) - E9X M3 Final Drive (Differential) Bushing Removal Tool
(No image yet)
Engine Rebuild Tools:
-83300491142 (BMW Tool # 122100) - Rod Bearing Screw Socket 12mm 12point (this is an off the shelf socket from Hazet, 880TZ-12)
- 83300495119 (BMW Tool # 115250) - Rod Pulling Guide Pins
- 83300491056 (BMW Tool # 115100) - Crankshaft Adapter Tool
83300490504 (BMW Tool # 009120) - Torque Angle Tool #00 9 120 = Hazet 6690
83300495108 (BMW Tool # 009130) - Magnetic Socket
83300496269 (BMW Tool # 119990) - Engine Brace
- 83300493938 (BMW Tool # 119260) - Flywheel Locking Tool [includes BMW Tool # 119261 Lock with Teeth, BMW Tool # 119263 Insert Bushing for Lock, BMW Tool # 119265 Spacer Bushing, BMW Tool # 119266 Spacer Bushing]
-83300495024 (BMW Tool # 114370) - Block Sealing Tool - Used to insert sealant into block of S65 motor
-83300493973 (BMW Tool # 119360) - Bedplate Sealant Injection Valve Install Tool
83300491018 (BMW Tool # 114180) - T60 Torx Flywheel Screws Removal Tool
-83300493843 (BMW Tool # 110280) - Vibration Damper Holder Tool
- 83300490856 (BMW Tool # 112 250) - Cylinder Head Bolt Socket E10 Torx (Custom tool made by Hazet, it is a 1/2" drive 117mm long extension with holding pin and an E10 socket with a ball bearing hold feature to hold the bolt in the socket. The socket is approximately 23mm long making the combined tool length approximately 140mm long).
-83300495102 (BMW Tool # 114470) - Cylinder Head Surfaces Cleaning Tool - NOGA SC1000 Scraper Handle with flat plastic blade 15mm wide plastic blade and 1.9mm thick.
- 83300495128 (BMW Tool # 115340) - Wrist Pin Removal and Installation Kit [includes BMW Tool # 115341, BMW Tool # 115342, BMW Tool # 115343 and BMW Tool # 115344]
-83302288154 (BMW Tool # 114492) - 90 degree bent Circlip Pliers (stamped Made in Germany, unknown brand) for Piston Wrist Pin Removal, internal circlip pliers with 1.5mm wide pins, a setting pin adjusted to stop the opening of the jaws no more than 7mm wide from the closed position.
83300493931 (BMW Tool # 119500) - Ring Compressor Pliers
83300493591 (BMW Tool # 112386) - Crankshaft Seal Removal Guide (Thrust Plate in BMW Terminology)
83300493247 (BMW Tool # 116360) - Crankshaft Seal Removal Tool
83300494737 (BMW Tool # 117231) - Crankshaft Seal Install Centering Cone NEW BMW Part # 83300493588
83300495127 (BMW Tool # 115330) - Crankshaft Seal Install Set [includes BMW Tool # 115331 Crankshaft Seal Install Guide Rod, BMW Tool # 115332 Crankshaft Seal Installer and BMW Tool # 115333 Crankshaft Seal Install Tool Nut]
83300491454 (BMW Tool# 230490) - Rear Main Seal Removal Tool
83300495125 (BMW Tool # 115310) - Rear Main Seal Installation Tool Set [includes BMW Tool #115311 Adapter Sleeve, BMW Tool # 115312 Rear Main Seal Install Tool Nut, BMW Tool # 115313 Rear Main Seal Install Cup]
83300490868 (BMW Tool # 112340) - Pilot Bearing Removal Tool
83300490811 (BMW Tool # 112016) - Pilot Bearing Removal Spindle
83300490475 (BMW Tool # 005500) - Pilot Bearing Install Handle
83300490873 (BMW Tool # 112350) - Pilot Bearing Install Bushing
83300490075 (BMW Tool # 000200) - Engine Support Bar Set [includes BMW Tool # 000202 Support Bar Spindle]
83300490561 (BMW Tool # 110000) - Engine Hoist Leveling Bar
83300495187 (BMW Tool # 002300) - Engine Stand
- 83300495120 (BMW Tool # 115260) - S65 Adapter Plate for Engine Stand
- 83300496270 (BMW Tool # 119970) - Camshaft and Timing Lock Tool Set [includes BMW Tools # 115290 (83300495123) tool to install bearing journals into timing chain cover, 115320 (83300495126) alignment pin to lock camshaft in top dead center position, 115370 (83300495131) tool to lock VANOS exhaust camshaft]
83300496346 (BMW Tool # 119950) - S65 Valve Spring Collar Tool Set (includes BMW Tool # 119951 (83300496347) Removal Tool, # 119952 (83300496348) Adapter, # 119953 (83300496349) Assembly Aid)
83300495122 (BMW Tool # 115280) - S65 Valve Spring Tool Set
(No image yet)
83300495117 (BMW Tool # 115230) - Pressure Test Fixture Set
___________ (BMW Tool # 115231) - Cylinder Head Pressure Test Water Jacket Cover
___________ (BMW Tool # 115233) - Cylinder Head Pressure Test Coolant Passage Cover
___________ (BMW Tool # 115235) - Cylinder Head Pressure Test Coolant Passage Cover
___________ (BMW Tool # 115237) - Cylinder Head Pressure Test Screw for Tool # 115235
83300496350 (BMW Tool # 119960) - S65 Leak Down Test Cover
_____?_____ (BMW Tool # 119961) - S65 Leak Down Test Cover
Appreciate 3
gnx759.50
m3post
