11-24-2016, 08:57 PM | #133 | |
27
Rep 72
2012 e92 dct / Dinan intake / bpm stage II tune / Akra Evolution / Brembo 380 F/R / KW Clubsport / Advan GT
11-25-2016, 04:38 PM | #134 | |
Save the manuals!
6031
Rep 6,753
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
11-25-2016, 04:49 PM | #135 |
152
Rep 984
Is there a trick to removing the M14 bolt that goes through the rear camber arm? Ive been trying to get the drivers sides one out for the last hour now and it doesn't want to come out. I'm even hammering it from the other side with a screwdriver and mallet and it still doesnt want to budge! Ive even raised the camber arm to different heights with a jack and nothing is working!
2004E46M36MTCBCinn 'Clubsport'
11-25-2016, 11:52 PM | #136 |
Save the manuals!
6031
Rep 6,753
Are you using hand tools? I found it very difficult with just a socket wrench. I just used my DeWalt electric impact driver. Came out in 2 seconds.
12-06-2016, 11:27 PM | #137 | |
Rep 142
Well, after several hours....the pics were meaningless... And I would consider myself mechanically inclined. Definitely not a mechanic. I did about 5 full suspension swaps on my RSX (one on my lunch hour....and I had time left over to eat), including trying to fix the geometry with inverted tie rods, roll center correction, etc. Intake, Exhaust, Cam swap, motor mounts, remote start/alarm. The only thing I can think of that I had somebody do was Final Drive/6th gear swap/Quaife and Hondata intake gasket. I even did all the tuning on Hondata myself. Yeah for me! After completing it, my suggestions would be: 1. Front: drop the entire strut. Seems like it would be more work, but you'll save a ton of time cuz you'll have space to work. If not, grab a buddy! 2. Rear: remove the inboard LCA bolt (leave the shock bolt and outboard LCA bolt intact). This will eliminate ALL alignment of that stupid LCA bolt!). The inboard bolt/bearing is cammed....but you'll need aligned after the spring swap anyway. So I wouldn't even worry about getting it situated correctly. Tighten under load. Use a sharpie if you want it close. I did start getting some noise over RR tracks on my passenger rear. I couldn't remember if I had tightened with the suspension loaded. I think I was sooo done and just tightened everything. So I went back and loosened, loaded, tightened and the noise went away. Which kinda tells me that bearing controls wheel hop and has nothing to do with maintaining geometry. BTW, getting aligned tomorrow....need it before the snow tires go on. Supposed to snow Thurs! |
12-07-2016, 07:21 PM | #138 | |
Save the manuals!
6031
Rep 6,753
09-06-2017, 08:57 AM | #139 |
314
Rep 1,453
I just did this last weekend by myself. 5 hours total (I could do it again in 3 hours)
Here are my thoughts. Fronts - No problems Rear - Yes the wheel carrier bolt is truly a pain in the ass. Jack up the arm 1/2 way up, wheel carrier swings in an arc - so this ensures the holes will align. Then Put the bolt in and place a screwdriver between the strut and wheel carrier - wiggle the bolt and screwdriver and push the bolt. Went in no problem. Other side went in 3 min. Good Luck Y'all. Thanks to Bill webspace for the step by step. http://billswebspace.com/M3HRSpringInstallation Springs - Swift Spec-R Spacers - 18MM Front 12MM Rear |
Theodore672.50 |
09-22-2019, 11:40 PM | #140 | |
25
Rep 134
I just spent 2 hrs doing the rear, and 80 percent of that was spent on getting the m14 bolt in on the driverside. I found the above post, and jacked it up until the hole aligned. Luckily I had a 2nd jack. Passenger side took a few min to get lined up and in. I'll be tackling the fronts tomorrow as that should be pretty straight forward. |
Stronie313.50 |
04-22-2020, 06:46 PM | #141 |
913
Rep 2,091
Great guide!! Saved me a lot of time.
Did the fronts on my own today, about 30 mins each side once the car was in the air with the wheels off. Definitely don't need a spring compressor!! That was the best part, just load up the suspension, take the top nut off and slowly lower it. I'll be doing the rears tomorrow
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD |
04-23-2020, 06:28 PM | #142 |
913
Rep 2,091
Followed OP's instructions and got the rears installed!
Went super smooth, few minutes each side. For the "trouble" bolt, you just need tot jack up the arm a tiny bit and wedge a wrench in-between the strut and the hub thing, just like in OP's pic. Bolt slides right in!
10-22-2021, 12:59 AM | #143 |
Rep 3
How to Install Aftermarket Springs?
The process is not difficult, so anyone with garage access and a little know-how can accomplish this modification. One of the most reputable platforms to buy auto parts from is Amazon and eBay. The actual price will vary depending on your vehicle, location, type of spring replaced, and whether you need additional services. Labor costs typically range between $133 and $168, while you may spend $217 to $254 for the parts.
How do I install a spring? Jack up the rear of the car and put it on car stands. Remove the rear wheels. Remove the shock nuts and bolts. (You can locate them by referring to the owner's manual.) ... Remove the springs. Install the new lowering springs. Replace the shock nuts and bolts. Replace the rear tires |
